nukyalur Member Joined Jun 13, 2019 Posts 20 Aug 24, 2019 #1 I got a crash playing an old game, rebooted, and after a forced windows repair, I was back at the desktop. The problem with the game persisted, but I had the inkling to run sfc, SURT, and sfcfix Here are my logs Attachments SFCFix.txt 2.4 KB · Views: 1 CheckSUR.log 1.3 KB · Views: 1 CBS.zip 537.9 KB · Views: 0
S Sysnative Windows Update Inactive Joined Oct 9, 2014 Posts 773 Aug 24, 2019 #2 Hi! SFCFix Script Warning: this fix is specific to the user in this thread. No one else should follow these instructions as it may cause more harm than good. If you are after assistance, please start a thread of your own. Download SFCFix.exe (by niemiro) and save this to your Desktop. Download the file below, SFCFix.zip, and save this to your Desktop. Ensure that this file is named SFCFix.zip - do not rename it. Save any open documents and close all open windows. On your Desktop, you should see two files: SFCFix.exe and SFCFix.zip. Drag the file SFCFix.zip onto the file SFCFix.exe and release it. SFCFix will now process the script. Upon completion, a file should be created on your Desktop: SFCFix.txt. Copy (Ctrl+C) and Paste (Ctrl+V) the contents of this file into your next post for me to analyse please - put [CODE][/CODE] tags around the log to break up the text. SFC Scan Click on the Start button and in the search box, type Command Prompt When you see Command Prompt on the list, right-click on it and select Run as administrator When command prompt opens, copy and paste the following commands into it, press enter after each sfc /scannow Wait for this to finish before you continue copy %windir%\logs\cbs\cbs.log "%userprofile%\Desktop\cbs.txt" This will create a file, cbs.txt on your Desktop. Please attach this to your next post. Attachments SFCFix.zip 5.5 MB · Views: 2
nukyalur Member Joined Jun 13, 2019 Posts 20 Aug 25, 2019 #3 Thanks a bunch for the quick reply Code: SFCFix version 3.0.2.1 by niemiro. Start time: 2019-08-24 23:42:27.010 Microsoft Windows 7 Service Pack 1 - amd64 Using .zip script file at C:\Users\Jarly\Desktop\SFCFix.zip [0] PowerCopy:: Successfully took permissions for file or folder C:\Windows\WinSxS\x86_microsoft.vc90.mfc_1fc8b3b9a1e18e3b_9.0.30729.1_none_dcc7eae99ad0d9cf\mfc90.dll Successfully took permissions for file or folder C:\Windows\WinSxS\wow64_microsoft-windows-a..ence-mitigations-c1_31bf3856ad364e35_6.1.7601.24351_none_74f7fa1e568dd100\sysmain.sdb Successfully took permissions for file or folder C:\Windows\WinSxS\amd64_microsoft.vc90.mfc_1fc8b3b9a1e18e3b_9.0.30729.1_none_951ab4128654b0c9\mfc90.dll Successfully took permissions for file or folder C:\Windows\Temp\CheckSur\WinSxS\Manifests WARNING: File C:\Windows\WinSxS\x86_microsoft.vc90.mfc_1fc8b3b9a1e18e3b_9.0.30729.1_none_dcc7eae99ad0d9cf\mfc90.dll was not backed up as that would replace the current backup. Successfully copied file C:\Users\Jarly\AppData\Local\niemiro\Archive\WinSxS\x86_microsoft.vc90.mfc_1fc8b3b9a1e18e3b_9.0.30729.1_none_dcc7eae99ad0d9cf\mfc90.dll to C:\Windows\WinSxS\x86_microsoft.vc90.mfc_1fc8b3b9a1e18e3b_9.0.30729.1_none_dcc7eae99ad0d9cf\mfc90.dll. WARNING: File C:\Windows\WinSxS\wow64_microsoft-windows-a..ence-mitigations-c1_31bf3856ad364e35_6.1.7601.24351_none_74f7fa1e568dd100\sysmain.sdb was not backed up as that would replace the current backup. Successfully copied file C:\Users\Jarly\AppData\Local\niemiro\Archive\WinSxS\wow64_microsoft-windows-a..ence-mitigations-c1_31bf3856ad364e35_6.1.7601.24351_none_74f7fa1e568dd100\sysmain.sdb to C:\Windows\WinSxS\wow64_microsoft-windows-a..ence-mitigations-c1_31bf3856ad364e35_6.1.7601.24351_none_74f7fa1e568dd100\sysmain.sdb. WARNING: File C:\Windows\WinSxS\amd64_microsoft.vc90.mfc_1fc8b3b9a1e18e3b_9.0.30729.1_none_951ab4128654b0c9\mfc90.dll was not backed up as that would replace the current backup. Successfully copied file C:\Users\Jarly\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft.vc90.mfc_1fc8b3b9a1e18e3b_9.0.30729.1_none_951ab4128654b0c9\mfc90.dll to C:\Windows\WinSxS\amd64_microsoft.vc90.mfc_1fc8b3b9a1e18e3b_9.0.30729.1_none_951ab4128654b0c9\mfc90.dll. Successfully copied file C:\Users\Jarly\AppData\Local\niemiro\Archive\Manifests\amd64_microsoft-windows-ie-internetexplorer_31bf3856ad364e35_11.2.9600.19431_none_11bab88b2f0b0fd4.manifest to C:\Windows\Temp\CheckSur\WinSxS\Manifests\amd64_microsoft-windows-ie-internetexplorer_31bf3856ad364e35_11.2.9600.19431_none_11bab88b2f0b0fd4.manifest. Successfully copied file C:\Users\Jarly\AppData\Local\niemiro\Archive\Manifests\x86_microsoft-windows-i..tocolimplementation_31bf3856ad364e35_11.2.9600.19356_none_882f6f13fe78c69d.manifest to C:\Windows\Temp\CheckSur\WinSxS\Manifests\x86_microsoft-windows-i..tocolimplementation_31bf3856ad364e35_11.2.9600.19356_none_882f6f13fe78c69d.manifest. Successfully restored ownership for C:\Windows\WinSxS\x86_microsoft.vc90.mfc_1fc8b3b9a1e18e3b_9.0.30729.1_none_dcc7eae99ad0d9cf\mfc90.dll Successfully restored permissions on C:\Windows\WinSxS\x86_microsoft.vc90.mfc_1fc8b3b9a1e18e3b_9.0.30729.1_none_dcc7eae99ad0d9cf\mfc90.dll Successfully restored ownership for C:\Windows\WinSxS\wow64_microsoft-windows-a..ence-mitigations-c1_31bf3856ad364e35_6.1.7601.24351_none_74f7fa1e568dd100\sysmain.sdb Successfully restored permissions on C:\Windows\WinSxS\wow64_microsoft-windows-a..ence-mitigations-c1_31bf3856ad364e35_6.1.7601.24351_none_74f7fa1e568dd100\sysmain.sdb Successfully restored ownership for C:\Windows\WinSxS\amd64_microsoft.vc90.mfc_1fc8b3b9a1e18e3b_9.0.30729.1_none_951ab4128654b0c9\mfc90.dll Successfully restored permissions on C:\Windows\WinSxS\amd64_microsoft.vc90.mfc_1fc8b3b9a1e18e3b_9.0.30729.1_none_951ab4128654b0c9\mfc90.dll Successfully restored ownership for C:\Windows\Temp\CheckSur\WinSxS\Manifests Successfully restored permissions on C:\Windows\Temp\CheckSur\WinSxS\Manifests PowerCopy:: directive completed successfully. Successfully processed all directives. SFCFix version 3.0.2.1 by niemiro has completed. Currently storing 41 datablocks. Finish time: 2019-08-24 23:42:28.187 Script hash: F/Y9aqUXdsVAiPvyCzcY59SXicK6VgVRMlLr9rOd4UA= ----------------------EOF----------------------- Attachments cbs .zip 621.3 KB · Views: 1
S Sysnative Windows Update Inactive Joined Oct 9, 2014 Posts 773 Aug 25, 2019 #4 No problem. Run System Update Readiness Tool again and attach CheckSUR.log once done.
nukyalur Member Joined Jun 13, 2019 Posts 20 Aug 25, 2019 #5 Seems like we're good, found 2, fixed 2 Attachments CheckSUR.log 1.5 KB · Views: 1
S Sysnative Windows Update Inactive Joined Oct 9, 2014 Posts 773 Aug 25, 2019 #6 Yes. Glad to have been of assistance!
