[SOLVED] sfc /scannow problem
fraXis
Hello,
Can someone please tell me how to either fix my problem or tell me what I should do?
My computer blue screened (Windows 8.1), and since then it has been running very slow and my gadgets no longer display on my desktop (using the Windows 7 gadget trick).
Thanks so much.
Start time: 2015-01-19 16:12:38.370
FIXED: Performed DISM repair on file Amd64\CNBJ2530.DPB of version 6.3.9600.17415.
CORRUPT: C:\Windows\winsxs\amd64_microsoft-windows-timedate-mui-callback_31bf3856ad364e35_6.3.9600.17415_none_e5795e3008d3e7b3\TimeDateMUICallback.dll
CORRUPT: C:\Windows\winsxs\x86_microsoft-windows-timedate-mui-callback_31bf3856ad364e35_6.3.9600.17415_none_895ac2ac5076767d\TimeDateMUICallback.dll
CBS & SFC total fixed corruption count: 1
Finish time: 2015-01-19 16:20:05.424
Hello fraXis and welcome to the forum.
Sorry for the delay in responding to your thread, I have been rather unwell.
SFCFix script
  2. Go to your desktop and right click on the background -> Select New -> Text Document -> Name this file SFCFixScript.txt.
  3. Open up SFCFixScript.txt and copy all of the following text inside the code box below and paste it into SFCFixScript.txt.
    Trace::
  4. Click on File -> Save. Close out of SFCFixScript.txt.
  5. Save any open documents and close all open windows.
  6. On your Desktop, you should see two files: SFCFix.exe and SFCFixScript.txt.
  7. Drag the file SFCFixScript.txt onto the file SFCFix.exe and release it.
  8. SFCFix will now process the script.
  9. Upon completion, a file should be created on your Desktop: SFCFix.txt.
  10. Copy (Ctrl+C) and Paste (Ctrl+V) the contents of this file into your next post for me to analyse please - put [CODE][/CODE] tags around the log to break up the text.
Thanks so much for your help. My problem is fixed now. :dance:
SFCFix script
    Trace::
That's good to hear, but the post I provided you wouldn't of actually fixed anything :)
What was strange was when I ran SFCFix the first time it did this repair:
But then other two *timedate* files failed.
Then the next day after restarting my computer I ran "SFC /ScanNow" and it reported that all my files were fine.
So your post did not actually fix the problem, but I guess SFCFix along with the combination of the reboot somehow fixed the problem.
I just ran SFC /ScanNow again now and all is still good. :-)
Very strange.
