sfc /scannow (not fix)
dragongv
I have been trying to fix the corrupted files from SFC for several days now, and these are the last files i can't fix.
The log (SFCFix.txt) is as follows:
SFCFix version 2.4.3.0 by niemiro.
Start time: 2015-05-19 13:00:38.282
CORRUPT: C:\Windows\winsxs\amd64_microsoft-windows-ehome-samplemedia_31bf3856ad364e35_6.1.7600.16385_none_b6b9b223710b3802\desktop.ini
CORRUPT: C:\Windows\winsxs\amd64_microsoft-windows-ehome-samplemedia_31bf3856ad364e35_6.1.7600.16385_none_b6b9b223710b3802\win7_scenic-demoshort_raw.wtv
CORRUPT: C:\Windows\winsxs\amd64_microsoft-windows-musicsamples_31bf3856ad364e35_6.1.7600.16385_none_06495209cbd8e93b\Kalimba.mp3
CORRUPT: C:\Windows\winsxs\amd64_microsoft-windows-musicsamples_31bf3856ad364e35_6.1.7600.16385_none_06495209cbd8e93b\desktop.ini
CORRUPT: C:\Windows\winsxs\amd64_microsoft-windows-musicsamples_31bf3856ad364e35_6.1.7600.16385_none_06495209cbd8e93b\Maid with the Flaxen Hair.mp3
CORRUPT: C:\Windows\winsxs\amd64_microsoft-windows-musicsamples_31bf3856ad364e35_6.1.7600.16385_none_06495209cbd8e93b\Sleep Away.mp3
CORRUPT: C:\Windows\winsxs\amd64_microsoft-windows-photosamples_31bf3856ad364e35_6.1.7600.16385_none_f36e0e659b8042be\Koala.jpg
CORRUPT: C:\Windows\winsxs\amd64_microsoft-windows-photosamples_31bf3856ad364e35_6.1.7600.16385_none_f36e0e659b8042be\Jellyfish.jpg
CORRUPT: C:\Windows\winsxs\amd64_microsoft-windows-photosamples_31bf3856ad364e35_6.1.7600.16385_none_f36e0e659b8042be\SampleRes.dll
CORRUPT: C:\Windows\winsxs\amd64_microsoft-windows-photosamples_31bf3856ad364e35_6.1.7600.16385_none_f36e0e659b8042be\desktop.ini
CORRUPT: C:\Windows\winsxs\amd64_microsoft-windows-photosamples_31bf3856ad364e35_6.1.7600.16385_none_f36e0e659b8042be\Desert.jpg
CORRUPT: C:\Windows\winsxs\amd64_microsoft-windows-photosamples_31bf3856ad364e35_6.1.7600.16385_none_f36e0e659b8042be\Lighthouse.jpg
CORRUPT: C:\Windows\winsxs\amd64_microsoft-windows-photosamples_31bf3856ad364e35_6.1.7600.16385_none_f36e0e659b8042be\Tulips.jpg
CORRUPT: C:\Windows\winsxs\amd64_microsoft-windows-photosamples_31bf3856ad364e35_6.1.7600.16385_none_f36e0e659b8042be\Chrysanthemum.jpg
CORRUPT: C:\Windows\winsxs\amd64_microsoft-windows-photosamples_31bf3856ad364e35_6.1.7600.16385_none_f36e0e659b8042be\Hydrangeas.jpg
CORRUPT: C:\Windows\winsxs\amd64_microsoft-windows-photosamples_31bf3856ad364e35_6.1.7600.16385_none_f36e0e659b8042be\Penguins.jpg
CORRUPT: C:\Windows\winsxs\amd64_microsoft-windows-videosamples_31bf3856ad364e35_6.1.7600.16385_none_51a21f033003affd\desktop.ini
CORRUPT: C:\Windows\winsxs\amd64_microsoft-windows-videosamples_31bf3856ad364e35_6.1.7600.16385_none_51a21f033003affd\Wildlife.wmv
CBS & SFC total detected corruption count: 18
SURT total detected corruption count: 18
SFCFix version 2.4.3.0 by niemiro has completed.
Finish time: 2015-05-19 13:07:15.224
thx all
Hello and welcome to the forum
SFC /SCANNOW
  1. Click on the
  4. Please wait for this to Finish before continuing with the rest of the steps.
Convert CBS.log to CBS.txt
  1. Click on the
    button => Inside the search box copy and paste the following command:
  2. Press Enter
  3. Once this has completed please go to your Desktop and you will find CBS.txt, please rename this file to CBS_{Insert forum username here}_{insert todays Date here}.txt For example "CBS_Go The Power_1803.txt"
  4. Please upload CBS_{Username}_{Date}.txt to this thread.
Please Note:: if the file is too big to upload to you next post please upload via Dropbox or One Drive
