[SOLVED] SFC scannow didn't fix all problems
Hi and welcome to Sysnative. Are you encountering any issue besides the message about being unable to fix corrupt files? The reason I ask is that the corruptions you have are a known issue and Microsoft will be providing a fix. The corruptions don't cause any Windows Update issues.
More info on this is below. If you are not encountering any Windows Update errors then the errors you currently have can safely be ignored.
https://support.microsoft.com/en-us/kb/3022345
Originally Posted by Microsoft
This update enables the Diagnostics Tracking Service in Windows 8.1, Windows Server 2012 R2, Windows 7 Service Pack 1 (SP1), and Windows Server 2008 R2 SP1. This tracking service collects data about functional issues in Windows.
This update contains the following two manifests that are occasionally updated by the Diagnostic Tracking Service:
telemetry.ASM-WindowsDefault.json
utc.app.json
The two files are marked as static files in the update. When an advanced user runs the System File Checker Tool (sfc.exe), the files are unintentionally flagged as corrupted. There is no impact or corruption on a device that is running this update, and this issue will be fixed in a later service update.
