This is a brand new computer, zbook17 with windows 7 professional, that was first used on 9/20/2015.
When sfc /scannow was run on the first day of use it found corruption.
Now when sfc /scannow is run it always find corruption.
SFCFix reported that no corruptions were detected.
DISM scanhealth always finds corruption.
In the links are images of administrative command prompt results for multiple sfc /scannow and DISM /online /cleanup-image /scanhealth
The first sfc /scannow found corrupt files but was unable to repair some of them.
The second sfc /scannow found corrupt files and successfully repaired them.
The third sfc /scannow found corrupt files and was unable to repair some of them.
The forth sfc /scannow found corrupt files and successfully repaired them.
The fifth sfc /scannow found corrupt files and was unable to repair some of them.
The result with sfc /scannow is always find corruption and to alternate between a successful repair and unable to repair some of them.
In windows 7 there is no DISM command to restorehealth but the scanhealth scan creates a CBS file to view corruption. The user then needs to find methods to repair the corruption. This is where I need your help.
In the links below are:
1) a snipping tool picture of the results in administrative command prompt
2) a C:\windows\logs\cbs\cbs.log
3) a C:\windows\logs\cbs\checksur.log
In the checksur log it always finds 2 corruptions:
Found 2 errors
CBS MUM Corrupt Total count: 2
The unavailable repair files are:
windows-IE-Hyphenation-Parent=Package-English
windows-IE-Spelling-Parent-Package-English
This is a brand new computer placed in use on 9/20/2015.
Next to this computer is a similar computer with a failed NVidia card.
This new computer is to replace the one with the failed video card.
The computer with the filed video card has had a sfc /scannow that has worked properly until the last few months. Immediately after a Microsoft windows update it found corruption. Instead of deleting this windows update file I waited for Microsoft to get feedback about the windows update producing sfc /scannow corruption. Within a few months Microsoft produced a windows update that fixed the problem with the prior windows update. The computer with the failed NVidia card when sfc /scannow is run has no corruption. In contrast the brand new computer always displays corruption. When sfc /scannow fixes the corruption the corruption that it fixes is only temporary as the next sfc /scannow reports that it was not able to fix the corruption. The next sfc /scannow will then fix the corruption. The computer can be reboot any time and the sfc /scannow results always display corruption.
If sfc /scan results are ignored with it displaying corruption on a new computer there may be sometime in the future where a serious corruption is missed. I would like to get this brand new computer fixed so that there is no corruption. I did not know how to locate the missing files in the log files. When reading the cbs log for the sfc /scannow using edit then find then entering "cannot" there was no result. When using the find and entering "corrupt" there were 18 results all looking for the same repair file. This file was different than the checksur log.
How does the sfc /scannow results get fixed so that windows resource protection permanently fixes the corruption?
https://www.dropbox.com/sh/b6rhh0aabmd2v2a/AABjpjld1iwVtWCMbDBmNfzqa?dl=0
Found 2 errors
