Johnfinity
- Jul 19, 2015
- 3
Hi guys,
Hi and welcome to Sysnative. Let's see if this gets you fixed up.
Step#1 - SFCFix Script
- Download SFCFix.exe (by niemiro) and save this to your Desktop. If you still have this on your desktop from downloading previously, you don't need to re-download.
- Download the file below, SFCFix.zip, and save this to your Desktop. Ensure that this file is named SFCFix.zip - do not rename it.
- Save any open documents and close all open windows.
- On your Desktop, you should see two files: SFCFix.exe and SFCFix.zip.
- Drag the file SFCFix.zip onto the file SFCFix.exe and release it.
- SFCFix will now process the script.
- Upon completion, a file should be created on your Desktop: SFCFix.txt.
- Copy (Ctrl+C) and Paste (Ctrl+V) the contents of this file into your next post for me to analyse please
Step#2 - SFC Scan
- Click on the Start
button and in the search box, type Command Prompt![]()
- When you see Command Prompt on the list, right-click on it and select Run as administrator
- When command prompt opens, copy and paste the following commands into it, press enter after each
copy %windir%\logs\cbs\cbs.log %userprofile%\Desktop\cbs.txt- This will create a file, cbs.txt on your Desktop. Please attach this to your next post.
Items for your next post
1. SFCFix.txt
2. CBS.txt
