emerysteele
- Jun 11, 2015
- 7
Hello,
I'm having some issues with SFC corruption on my machine. Hoping someone is able to help me with an sfcfix.zip file. This is the log from SFCFix:
Start time: 2018-11-08 09:50:49.833
WARNING: Components hive failed load test and may be corrupt.
WARNING: Components hive failed final reload test with error code ERROR_ACCESS_DENIED and may be corrupt.
WARNING: Failed to get store name from identity name with return code 10002 for component Microsoft-Windows-Defrag-AdminUI and file dfrgui.exe. File is reported as corrupt by SFC.
CORRUPT: dfrgui.exe of component Microsoft-Windows-Defrag-AdminUI.
WARNING: Failed to get store name from identity name with return code 10002 for component Microsoft-Windows-NaturalLanguage6 and file NlsLexicons0007.dll. File is reported as corrupt by SFC.
CORRUPT: NlsLexicons0007.dll of component Microsoft-Windows-NaturalLanguage6.
WARNING: Failed to get store name from identity name with return code 10002 for component Microsoft-Windows-BTH-USER and file wshbth.dll. File is reported as corrupt by SFC.
CORRUPT: wshbth.dll of component Microsoft-Windows-BTH-USER.
WARNING: Failed to get store name from identity name with return code 10002 for component Microsoft-Windows-Active-Directory-Services-Interface-LDAP-Provider and file adsldp.dll. File is reported as corrupt by SFC.
CORRUPT: adsldp.dll of component Microsoft-Windows-Active-Directory-Services-Interface-LDAP-Provider.
WARNING: Failed to get store name from identity name with return code 10002 for component prnca00z.inf and file Amd64\CNBGRC41.GPD. File is reported as corrupt by SFC.
CORRUPT: Amd64\CNBGRC41.GPD of component prnca00z.inf.
CBS & SFC total detected corruption count: 5
Failed to process registry database in location 1.
Failed to load registry hive C:\Windows\System32\config\COMPONENTS into key HKEY_LOCAL_MACHINE\COMPONENTS with error code ERROR_ACCESS_DENIED.
Failed to process registry database in location 2 with error code ERROR_FILE_NOT_FOUND.
WARNING: Failed to process registry database in location 3 with error code ERROR_INVALID_HANDLE.
Failed to process registry database in location 4 with error code ERROR_INVALID_HANDLE.
Failed to process registry database in location 4 with error code ERROR_FILE_NOT_FOUND.
Finish time: 2018-11-08 10:13:30.280
