sfc.exe found i still have problems
jericho beach
Start time: 2015-11-28 12:22:03.446
Microsoft Windows 8.1 - amd64 <--- FTR im using windows 10
WARNING: Failed to get store name from identity name with return code 2 for component Microsoft-Windows-iSCSI_Initiator_UI and file iSCSI Initiator.lnk. File is reported as corrupt by SFC.
CORRUPT: iSCSI Initiator.lnk of component Microsoft-Windows-iSCSI_Initiator_UI.
WARNING: Failed to get store name from identity name with return code 2 for component Microsoft-Windows-Microsoft-Data-Access-Components-(MDAC)-ODBC-Administrator and file ODBC Data Sources (64-bit).lnk. File is reported as corrupt by SFC.
CORRUPT: ODBC Data Sources (64-bit).lnk of component Microsoft-Windows-Microsoft-Data-Access-Components-(MDAC)-ODBC-Administrator.
WARNING: Failed to get store name from identity name with return code 2 for component Microsoft-Windows-Microsoft-Data-Access-Components-(MDAC)-ODBC-Administrator and file ODBC Data Sources (32-bit).lnk. File is reported as corrupt by SFC.
CORRUPT: ODBC Data Sources (32-bit).lnk of component Microsoft-Windows-Microsoft-Data-Access-Components-(MDAC)-ODBC-Administrator.
CBS & SFC total detected corruption count: 3
Finish time: 2015-11-28 12:23:45.766
that was after doing the drag and drop on the sfc exe which produced this:
Start time: 2015-11-28 12:28:44.501
Using .zip script file at C:\Users\siony_000\Desktop\SFCFix.zip [7]
Successfully took permissions for file or folder C:\WINDOWS\winsxs\x86_netfx-aspnet_regbrowser_files_b03f5f7f11d50a3a_6.1.7600.16385_none_458b87598810c725\mozilla.browser
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_netfx-aspnet_regbrowser_files_b03f5f7f11d50a3a_6.1.7600.16385_none_fdde508273949e1f\mozilla.browser
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-ehome-reg-inf_31bf3856ad364e35_6.1.7601.17514_none_535245f3d98ecb9a\desktop.ini
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-com-dtc-runtime_31bf3856ad364e35_6.1.7600.16385_none_7547f48c79b40229\MSDTC.LOG
WARNING: File C:\WINDOWS\winsxs\x86_netfx-aspnet_regbrowser_files_b03f5f7f11d50a3a_6.1.7600.16385_none_458b87598810c725\mozilla.browser was not backed up as that would replace the current backup.
Successfully copied file C:\Users\siony_000\AppData\Local\niemiro\Archive\winsxs\x86_netfx-aspnet_regbrowser_files_b03f5f7f11d50a3a_6.1.7600.16385_none_458b87598810c725\mozilla.browser to C:\WINDOWS\winsxs\x86_netfx-aspnet_regbrowser_files_b03f5f7f11d50a3a_6.1.7600.16385_none_458b87598810c725\mozilla.browser.
WARNING: File C:\WINDOWS\winsxs\amd64_netfx-aspnet_regbrowser_files_b03f5f7f11d50a3a_6.1.7600.16385_none_fdde508273949e1f\mozilla.browser was not backed up as that would replace the current backup.
Successfully copied file C:\Users\siony_000\AppData\Local\niemiro\Archive\winsxs\amd64_netfx-aspnet_regbrowser_files_b03f5f7f11d50a3a_6.1.7600.16385_none_fdde508273949e1f\mozilla.browser to C:\WINDOWS\winsxs\amd64_netfx-aspnet_regbrowser_files_b03f5f7f11d50a3a_6.1.7600.16385_none_fdde508273949e1f\mozilla.browser.
WARNING: File C:\WINDOWS\winsxs\amd64_microsoft-windows-ehome-reg-inf_31bf3856ad364e35_6.1.7601.17514_none_535245f3d98ecb9a\desktop.ini was not backed up as that would replace the current backup.
Successfully copied file C:\Users\siony_000\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-ehome-reg-inf_31bf3856ad364e35_6.1.7601.17514_none_535245f3d98ecb9a\desktop.ini to C:\WINDOWS\winsxs\amd64_microsoft-windows-ehome-reg-inf_31bf3856ad364e35_6.1.7601.17514_none_535245f3d98ecb9a\desktop.ini.
WARNING: File C:\WINDOWS\winsxs\amd64_microsoft-windows-com-dtc-runtime_31bf3856ad364e35_6.1.7600.16385_none_7547f48c79b40229\MSDTC.LOG was not backed up as that would replace the current backup.
Successfully copied file C:\Users\siony_000\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-com-dtc-runtime_31bf3856ad364e35_6.1.7600.16385_none_7547f48c79b40229\MSDTC.LOG to C:\WINDOWS\winsxs\amd64_microsoft-windows-com-dtc-runtime_31bf3856ad364e35_6.1.7600.16385_none_7547f48c79b40229\MSDTC.LOG.
Failed to reset file attributes for file or folder C:\WINDOWS\winsxs\x86_netfx-aspnet_regbrowser_files_b03f5f7f11d50a3a_6.1.7600.16385_none_458b87598810c725\mozilla.browser with error code ERROR_ACCESS_DENIED.
Successfully restored ownership for C:\WINDOWS\winsxs\x86_netfx-aspnet_regbrowser_files_b03f5f7f11d50a3a_6.1.7600.16385_none_458b87598810c725\mozilla.browser
Successfully restored permissions on C:\WINDOWS\winsxs\x86_netfx-aspnet_regbrowser_files_b03f5f7f11d50a3a_6.1.7600.16385_none_458b87598810c725\mozilla.browser
Failed to reset file attributes for file or folder C:\WINDOWS\winsxs\amd64_netfx-aspnet_regbrowser_files_b03f5f7f11d50a3a_6.1.7600.16385_none_fdde508273949e1f\mozilla.browser with error code ERROR_ACCESS_DENIED.
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_netfx-aspnet_regbrowser_files_b03f5f7f11d50a3a_6.1.7600.16385_none_fdde508273949e1f\mozilla.browser
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_netfx-aspnet_regbrowser_files_b03f5f7f11d50a3a_6.1.7600.16385_none_fdde508273949e1f\mozilla.browser
Failed to reset file attributes for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-ehome-reg-inf_31bf3856ad364e35_6.1.7601.17514_none_535245f3d98ecb9a\desktop.ini with error code ERROR_ACCESS_DENIED.
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-ehome-reg-inf_31bf3856ad364e35_6.1.7601.17514_none_535245f3d98ecb9a\desktop.ini
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-ehome-reg-inf_31bf3856ad364e35_6.1.7601.17514_none_535245f3d98ecb9a\desktop.ini
Failed to reset file attributes for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-com-dtc-runtime_31bf3856ad364e35_6.1.7600.16385_none_7547f48c79b40229\MSDTC.LOG with error code ERROR_ACCESS_DENIED.
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-com-dtc-runtime_31bf3856ad364e35_6.1.7600.16385_none_7547f48c79b40229\MSDTC.LOG
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-com-dtc-runtime_31bf3856ad364e35_6.1.7600.16385_none_7547f48c79b40229\MSDTC.LOG
Finish time: 2015-11-28 12:28:44.817
Script hash: jm3LBA9blWToFB3RWnU0IeNg3B5x8XvC07s8IiURr90=
Hi jericho beach :)
My name is Aura and I'll be assisting you with your issue. Follow the instructions below please.
System File Checker (SFC)
    Run as Administrator
