H HueCM Member Joined Dec 9, 2016 Posts 24 Mar 6, 2021 #1 Hi Guys, Can anyone help with the problems i have?..SFC could not repair corrupted files. I have attached the log. Thanks guys in advance. Attachments CBS.log 3 MB · Views: 8
X Xent Active member Joined Feb 5, 2021 Posts 25 Mar 7, 2021 #2 It seems that only the lnk-Files couldn't be repaired. Can you try this command and post the CBS.log again? Code: dism /online /cleanup-image /restorehealth
H HueCM Member Joined Dec 9, 2016 Posts 24 Mar 10, 2021 #3 Hi Xent, attached is the CBS.log which was generated after the SFC scan. It still shows there are still files which it cannot repair. The SFC scan was done after doing the online restorehealth, as suggested by you. Thank you, Hue Attachments CBS.log 3 MB · Views: 1
X Xent Active member Joined Feb 5, 2021 Posts 25 Mar 10, 2021 #4 It's still complaining about the same lnk files, So they didn't got repair from windows update. Do you you have any other issues except the error messages from sfc? Do windows updates work?
H HueCM Member Joined Dec 9, 2016 Posts 24 Mar 10, 2021 #5 Yes, I still have other issues - 1. Unable to update. It can download and install the updates. But after the restart, it will go into a loop and undo all the installed updates. 2. I also experience BSOD from an issue - 'KERNEL-POWER Event ID 41'. Appreciate if you can help. Thank you.
philc43 BSOD Forum Moderator, BSOD Academy Instructor, BSOD Kernel Dump Expert Staff member Joined Jul 7, 2017 Posts 1,962 Location Cambridge, UK Mar 10, 2021 #6 For the BSOD issues please start a thread and provide the SysnativeLogCollector files as instructed here: Blue Screen of Death (BSOD) Posting Instructions - Windows 10, 8.1, 8, 7 + Vista | Sysnative Forums
