deleted01012020
- Jan 6, 2015
- 6
A month ago, I installed KB3000850. Because I had Avast, it bricked my system and I was able to System restore out of that, delete avast and use my system. However after system restore, I can no longer install KB3000850 again - it fails every time with the 800700A1 error code. I tried to follow some of the local threads (my problem is super similar), but since there are some minor differences, I don't wanna take any chances:
https://www.sysnative.com/forums/wi...e-checker-scannow-cant-fix-corrupt-files.html
https://www.sysnative.com/forums/wi...te-kb3000850-fails-with-error-0x800700a1.html
I tried to run "sfc /scannow" with the following output:
Then I tried to run SFCFix.exe with
and got this output:
Then I executed SFCFix second time without any arguments, with the following output:
The file "c:\Windows\WinSxS\amd64_microsoft-windows-com-dtc-runtime_31bf3856ad364e35_6.3.9600.16384_none_0a1162f033fa01f6\MSDTC.LOG" is a 12-byte file which seems ridiculously small. Can you please help me fix this corruption and install KB3000850? Thank you.
2015-01-06 12:48:57, Info CSI 000000d6 [SR] Cannot repair member file [l:18{9}]"MSDTC.LOG" of Microsoft-Windows-COM-DTC-Runtime, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, file cannot be decompressed
2015-01-06 12:49:02, Info CSI 000000e9 [SR] Cannot repair member file [l:18{9}]"MSDTC.LOG" of Microsoft-Windows-COM-DTC-Runtime, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, file cannot be decompressed
2015-01-06 12:49:02, Info CSI 000000ea [SR] This component was referenced by [l:326{163}]"Microsoft-Windows-Client-Features-Package-AutoMerged-com~31bf3856ad364e35~amd64~~6.3.9600.16384.Microsoft-Windows-Client-Features-Package-AutoMerged-com-Deployment"
2015-01-06 12:57:37, Info CSI 0000083d [SR] Cannot repair member file [l:18{9}]"MSDTC.LOG" of Microsoft-Windows-COM-DTC-Runtime, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, file cannot be decompressed
2015-01-06 12:57:41, Info CSI 00000840 [SR] Cannot repair member file [l:18{9}]"MSDTC.LOG" of Microsoft-Windows-COM-DTC-Runtime, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, file cannot be decompressed
2015-01-06 12:57:41, Info CSI 00000841 [SR] This component was referenced by [l:326{163}]"Microsoft-Windows-Client-Features-Package-AutoMerged-com~31bf3856ad364e35~amd64~~6.3.9600.16384.Microsoft-Windows-Client-Features-Package-AutoMerged-com-Deployment"
FileScan::
MSDTC.LOG
Start time: 2015-01-06 13:20:06.652
Using .txt script file at C:\Users\Pavel\Desktop\SFCFixScript.txt [0]
FileScan::
[0: 1] C:\Windows\WinSxS\amd64_microsoft-windows-com-dtc-runtime_31bf3856ad364e35_6.3.9600.16384_none_0a1162f033fa01f6\MSDTC.LOG
File is untraceable.
Found: SD6OMNd/nMSy7P0Ob02ZGPT4cYglTnq4Gz0i2cQTLNo=
Version number not available.
Trace not available.
[1: 1] C:\Windows\System32\MsDtc\MSDTC.LOG
Found: xoDcML2emANIvEr+C/SC4csKKzGgqO3vYg/+H/t9d/Y=
[2: 1] C:\Windows\WinSxS\amd64_microsoft-windows-com-dtc-runtime_31bf3856ad364e35_6.3.9600.17415_none_0a5dfdcc33c06e7e\MSDTC.LOG
Found: Q4htnI+yK+Jo0DJugTfqjq40IHkXFkIWyyAaDjFGEvo=
Finish time: 2015-01-06 13:21:11.292
Script hash: yqmxX1j/+8ZyX3y6rPOmoWChAp9FEXuZ4bDqiXrV6rc=
Start time: 2015-01-06 13:24:57.601
CORRUPT: C:\WINDOWS\winsxs\amd64_microsoft-windows-com-dtc-runtime_31bf3856ad364e35_6.3.9600.16384_none_0a1162f033fa01f6\MSDTC.LOG
CORRUPT: C:\WINDOWS\winsxs\wow64_microsoft-windows-com-dtc-runtime_31bf3856ad364e35_6.3.9600.16384_none_14660d42685ac3f1\MSDTC.LOG
CBS & SFC total detected corruption count: -2
Finish time: 2015-01-06 13:33:30.194
