[SOLVED] sfc can't fix problem...
Download SFCFix.zip from Sendspace.com - send big files the easy wa
here is the cbs.log fileView attachment 18934
SFCFix version 2.4.9.2 by niemiro.
Start time: 2016-02-06 07:06:59.136
Microsoft Windows 10 Build 10586 (Updates Deferred) - x86
Using .zip script file at C:\Users\cychen\Desktop\SFCFix.zip [0]
Successfully took permissions for file or folder C:\WINDOWS\WinSxS\x86_microsoft-windows-t..nbackgrounds-client_31bf3856ad364e35_10.0.10586.0_none_0d7dc068eb6b7eeb\img103.png
Successfully took permissions for file or folder C:\WINDOWS\WinSxS\x86_microsoft-windows-f..type-microsoftyahei_31bf3856ad364e35_10.0.10586.0_none_6b3a3f0522130c94\msyh.ttc
Successfully took permissions for file or folder C:\WINDOWS\WinSxS\x86_microsoft-windows-cmi_31bf3856ad364e35_10.0.10586.0_none_da35471d4c84a094\cmiv2.dll
Successfully took permissions for file or folder C:\WINDOWS\WinSxS\x86_microsoft-windows-3daudio-hrtfbins_31bf3856ad364e35_10.0.10586.0_none_74134b5a78540c07\DefaultHrtfs.bin
Successfully copied file C:\Users\cychen\AppData\Local\niemiro\Archive\WinSxS\x86_microsoft-windows-t..nbackgrounds-client_31bf3856ad364e35_10.0.10586.0_none_0d7dc068eb6b7eeb\img103.png to C:\WINDOWS\WinSxS\x86_microsoft-windows-t..nbackgrounds-client_31bf3856ad364e35_10.0.10586.0_none_0d7dc068eb6b7eeb\img103.png.
Failed to copy file C:\Users\cychen\AppData\Local\niemiro\Archive\WinSxS\x86_microsoft-windows-f..type-microsoftyahei_31bf3856ad364e35_10.0.10586.0_none_6b3a3f0522130c94\msyh.ttc to C:\WINDOWS\WinSxS\x86_microsoft-windows-f..type-microsoftyahei_31bf3856ad364e35_10.0.10586.0_none_6b3a3f0522130c94\msyh.ttc with error code 0x4C8.
Successfully copied file C:\Users\cychen\AppData\Local\niemiro\Archive\WinSxS\x86_microsoft-windows-cmi_31bf3856ad364e35_10.0.10586.0_none_da35471d4c84a094\cmiv2.dll to C:\WINDOWS\WinSxS\x86_microsoft-windows-cmi_31bf3856ad364e35_10.0.10586.0_none_da35471d4c84a094\cmiv2.dll.
Successfully copied file C:\Users\cychen\AppData\Local\niemiro\Archive\WinSxS\x86_microsoft-windows-3daudio-hrtfbins_31bf3856ad364e35_10.0.10586.0_none_74134b5a78540c07\DefaultHrtfs.bin to C:\WINDOWS\WinSxS\x86_microsoft-windows-3daudio-hrtfbins_31bf3856ad364e35_10.0.10586.0_none_74134b5a78540c07\DefaultHrtfs.bin.
Successfully restored ownership for C:\WINDOWS\WinSxS\x86_microsoft-windows-t..nbackgrounds-client_31bf3856ad364e35_10.0.10586.0_none_0d7dc068eb6b7eeb\img103.png
Successfully restored permissions on C:\WINDOWS\WinSxS\x86_microsoft-windows-t..nbackgrounds-client_31bf3856ad364e35_10.0.10586.0_none_0d7dc068eb6b7eeb\img103.png
Successfully restored ownership for C:\WINDOWS\WinSxS\x86_microsoft-windows-f..type-microsoftyahei_31bf3856ad364e35_10.0.10586.0_none_6b3a3f0522130c94\msyh.ttc
Successfully restored permissions on C:\WINDOWS\WinSxS\x86_microsoft-windows-f..type-microsoftyahei_31bf3856ad364e35_10.0.10586.0_none_6b3a3f0522130c94\msyh.ttc
Successfully restored ownership for C:\WINDOWS\WinSxS\x86_microsoft-windows-cmi_31bf3856ad364e35_10.0.10586.0_none_da35471d4c84a094\cmiv2.dll
Successfully restored permissions on C:\WINDOWS\WinSxS\x86_microsoft-windows-cmi_31bf3856ad364e35_10.0.10586.0_none_da35471d4c84a094\cmiv2.dll
Successfully restored ownership for C:\WINDOWS\WinSxS\x86_microsoft-windows-3daudio-hrtfbins_31bf3856ad364e35_10.0.10586.0_none_74134b5a78540c07\DefaultHrtfs.bin
Successfully restored permissions on C:\WINDOWS\WinSxS\x86_microsoft-windows-3daudio-hrtfbins_31bf3856ad364e35_10.0.10586.0_none_74134b5a78540c07\DefaultHrtfs.bin
PowerCopy:: directive failed to complete successfully.
SFCFix version 2.4.9.2 by niemiro has completed.
Finish time: 2016-02-06 07:07:03.371
Script hash: vSvZ4zFVApRFIYJXxM/hKgSzh37V8hM/fG8qXLNFJvY=
DISM /RestoreHealth Scan
  1. Right-click on the Start
  3. When DISM finishes scanning your component store, zip up and attach your CBS log to your next post:
    C:\Windows\Logs\CBS\CBS.log
the conmmand you give I got errors..it's the first cbs file
I then mount the windows 10 iso and use the source command(Dism /Online /Cleanup-Image /RestoreHealth /Source:wim:F:\sources\install.wim:1 /limitaccess)still got error,it's the second cbs.log file.
I include the dsm log file
Please reboot the computer and then run the fix script again.
Be sure no other applications are open when SFCFix is running.
It appears that the file copy failed because the font file was in use (possibly by Microsoft Office).
When SFCFix has completed, include the results from the log file so I can verify if the replacement was successful.
[SFCFix version 2.4.9.2 by niemiro.
Start time: 2016-02-16 13:03:14.508
Using .zip script file at C:\Users\cychen\Desktop\SFCFix.zip [4]
WARNING: File C:\WINDOWS\WinSxS\x86_microsoft-windows-t..nbackgrounds-client_31bf3856ad364e35_10.0.10586.0_none_0d7dc068eb6b7eeb\img103.png was not backed up as that would replace the current backup.
WARNING: File C:\WINDOWS\WinSxS\x86_microsoft-windows-f..type-microsoftyahei_31bf3856ad364e35_10.0.10586.0_none_6b3a3f0522130c94\msyh.ttc was not backed up as that would replace the current backup.
WARNING: File C:\WINDOWS\WinSxS\x86_microsoft-windows-cmi_31bf3856ad364e35_10.0.10586.0_none_da35471d4c84a094\cmiv2.dll was not backed up as that would replace the current backup.
WARNING: File C:\WINDOWS\WinSxS\x86_microsoft-windows-3daudio-hrtfbins_31bf3856ad364e35_10.0.10586.0_none_74134b5a78540c07\DefaultHrtfs.bin was not backed up as that would replace the current backup.
Finish time: 2016-02-16 13:03:17.680
still got the same results I think.I even boot to safemode to use the zip file
Hi xordin -
I'm working with zcomputerwiz and we would like you to try the following please.
FRST Fix
Note: You need to run the 32-bit Version so please ensure you download that one.
Note. It's important that both files, FRST and fixlist.txt are in the same location or the fix will not work (in this case...the desktop).
3. Run FRST by Right-Clicking on the file and choosing Run as administrator.
5. When finished FRST will generate a log on the Desktop (Fixlog.txt). Please post the contents of it in your reply.
Fix result of Farbar Recovery Scan Tool (x86) Version:07-02-2016
Ran by cychen (2016-02-17 07:47:11) Run:1
Running from C:\Users\cychen\Desktop
Loaded Profiles: cychen (Available Profiles: cychen & cychenhome & Administrator & DefaultAppPool)
Boot Mode: Normal
fixlist content:
C:\WINDOWS\WinSxS\x86_microsoft-windows-f..type-microsoftyahei_31bf3856ad364e35_10.0.10586.0_none_6b3a3f0522130c94 => moved successfully
==== End of Fixlog 07:47:11 ====
here is the results.
SFCFix.zip
Start time: 2016-02-18 06:24:05.717
Successfully created directory tree \\?\C:\WINDOWS\WinSxS\x86_microsoft-windows-f..type-microsoftyahei_31bf3856ad364e35_10.0.10586.0_none_6b3a3f0522130c94.
Successfully copied file C:\Users\cychen\AppData\Local\niemiro\Archive\WinSxS\x86_microsoft-windows-f..type-microsoftyahei_31bf3856ad364e35_10.0.10586.0_none_6b3a3f0522130c94\msyh.ttc to C:\WINDOWS\WinSxS\x86_microsoft-windows-f..type-microsoftyahei_31bf3856ad364e35_10.0.10586.0_none_6b3a3f0522130c94\msyh.ttc.
Finish time: 2016-02-18 06:24:22.546
Script hash: hXDfAD07Rfjm3q9xvdnJvSBFTYQRqOSPH9e/rbCaFFM=
PS C:\WINDOWS\system32> DISM /Online /Cleanup-Image /RestoreHealth /Source:ESD:C:\ESD\Windows\sources\install.esd:1
部署映像服務與管理工具
版本: 10.0.10586.0
映像版本: 10.0.10586.0
還原操作已順利完成。
操作順利完成。
PS C:\WINDOWS\system32> sfc /scannow
正在開始系統掃描。這將需要一些時間。
開始系統掃描的驗證階段。
驗證 100% 完成。
Windows 資源保護找不到任何完整性違規。
everything is fixed, you guys are awsome.
