[SOLVED] SFC and DISM cannot fix files -Ran SFCfix - Need Help.
KTStick
Any help would be appreciated. Not sure what to do at this point.
Thanks - KT
My computer Hardware:
Acer Aspire Notebook
Intel i5-3317U CPU 1.7 GHz
6 GB RAM
500 GB SSD
Windows 8.1 Pro
SFCfix.txt below:
Start time: 2019-08-30 10:58:02.487
WARNING: Performed DISM repair due to manifest damage on component "amd64_3e084cfac154c6d9eea4d61f70b25a0d_31bf3856ad364e35_4.0.9600.20976_none_100e48872e5b6c36". See CBS logfile for more details.
WARNING: Performed DISM repair due to manifest damage on component "amd64_7e25d47607e16cac5089ac83a80b24a6_b77a5c561934e089_4.0.9600.20976_none_1ca88e29ca0afaa3". See CBS logfile for more details.
CORRUPT: C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ablenetworkgraphics_31bf3856ad364e35_11.0.9600.19431_none_f17c49e1f66a4fac\pngfilt.dll
CORRUPT: C:\WINDOWS\winsxs\x86_microsoft-windows-i..ablenetworkgraphics_31bf3856ad364e35_11.0.9600.19431_none_955dae5e3e0cde76\pngfilt.dll
CORRUPT: C:\WINDOWS\winsxs\amd64_microsoft-windows-ieframe_31bf3856ad364e35_11.0.9600.19431_none_68584758911fe506\ieframe.ptxml
CORRUPT: C:\WINDOWS\winsxs\amd64_microsoft-windows-msinfo32-exe_31bf3856ad364e35_6.3.9600.18728_none_9cdf8199cd713540\System Information.lnk
CORRUPT: C:\WINDOWS\winsxs\amd64_microsoft-windows-p..erandprintui-pmcppc_31bf3856ad364e35_6.3.9600.19293_none_fc1a8b8354b1fe52\Print Management.lnk
CORRUPT: C:\WINDOWS\winsxs\amd64_microsoft-windows-performancetoolsgui_31bf3856ad364e35_6.3.9600.18728_none_8d0cd8ee74b6dc18\Resource Monitor.lnk
CORRUPT: C:\WINDOWS\winsxs\amd64_microsoft-windows-performancetoolsgui_31bf3856ad364e35_6.3.9600.18728_none_8d0cd8ee74b6dc18\Performance Monitor.lnk
CORRUPT: C:\WINDOWS\winsxs\amd64_microsoft-windows-tabletpc-journal_31bf3856ad364e35_6.3.9600.18295_none_0865e9447896a7bc\Windows Journal.lnk
CORRUPT: C:\WINDOWS\winsxs\amd64_microsoft-windows-wordpad_31bf3856ad364e35_6.3.9600.19060_none_1e8a2de440d04365\Wordpad.lnk
CBS & SFC total detected corruption count: 21
Finish time: 2019-08-30 11:22:29.360
SFC Scan
Start time: 2019-09-01 12:16:01.707
Using .zip script file at C:\Users\admin\Desktop\SFCFix.zip [0]
Successfully took permissions for file or folder C:\WINDOWS\WinSxS\amd64_microsoft-windows-wordpad_31bf3856ad364e35_6.3.9600.19060_none_1e8a2de440d04365\Wordpad.lnk
Successfully took permissions for file or folder C:\WINDOWS\WinSxS\amd64_microsoft-windows-tabletpc-journal_31bf3856ad364e35_6.3.9600.18295_none_0865e9447896a7bc\Windows Journal.lnk
Successfully took permissions for file or folder C:\WINDOWS\WinSxS\amd64_microsoft-windows-performancetoolsgui_31bf3856ad364e35_6.3.9600.18728_none_8d0cd8ee74b6dc18\Performance Monitor.lnk
Successfully took permissions for file or folder C:\WINDOWS\WinSxS\amd64_microsoft-windows-performancetoolsgui_31bf3856ad364e35_6.3.9600.18728_none_8d0cd8ee74b6dc18\Resource Monitor.lnk
Successfully took permissions for file or folder C:\WINDOWS\WinSxS\amd64_microsoft-windows-p..erandprintui-pmcppc_31bf3856ad364e35_6.3.9600.19293_none_fc1a8b8354b1fe52\Print Management.lnk
Successfully took permissions for file or folder C:\WINDOWS\WinSxS\amd64_microsoft-windows-msinfo32-exe_31bf3856ad364e35_6.3.9600.18728_none_9cdf8199cd713540\System Information.lnk
Successfully took permissions for file or folder C:\WINDOWS\WinSxS\amd64_microsoft-windows-ieframe_31bf3856ad364e35_11.0.9600.19431_none_68584758911fe506\ieframe.ptxml
Successfully took permissions for file or folder C:\WINDOWS\WinSxS\amd64_microsoft-windows-i..ablenetworkgraphics_31bf3856ad364e35_11.0.9600.19431_none_f17c49e1f66a4fac\pngfilt.dll
Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-wordpad_31bf3856ad364e35_6.3.9600.19060_none_1e8a2de440d04365\Wordpad.lnk to C:\WINDOWS\WinSxS\amd64_microsoft-windows-wordpad_31bf3856ad364e35_6.3.9600.19060_none_1e8a2de440d04365\Wordpad.lnk.
Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-tabletpc-journal_31bf3856ad364e35_6.3.9600.18295_none_0865e9447896a7bc\Windows Journal.lnk to C:\WINDOWS\WinSxS\amd64_microsoft-windows-tabletpc-journal_31bf3856ad364e35_6.3.9600.18295_none_0865e9447896a7bc\Windows Journal.lnk.
Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-performancetoolsgui_31bf3856ad364e35_6.3.9600.18728_none_8d0cd8ee74b6dc18\Performance Monitor.lnk to C:\WINDOWS\WinSxS\amd64_microsoft-windows-performancetoolsgui_31bf3856ad364e35_6.3.9600.18728_none_8d0cd8ee74b6dc18\Performance Monitor.lnk.
Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-performancetoolsgui_31bf3856ad364e35_6.3.9600.18728_none_8d0cd8ee74b6dc18\Resource Monitor.lnk to C:\WINDOWS\WinSxS\amd64_microsoft-windows-performancetoolsgui_31bf3856ad364e35_6.3.9600.18728_none_8d0cd8ee74b6dc18\Resource Monitor.lnk.
Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-p..erandprintui-pmcppc_31bf3856ad364e35_6.3.9600.19293_none_fc1a8b8354b1fe52\Print Management.lnk to C:\WINDOWS\WinSxS\amd64_microsoft-windows-p..erandprintui-pmcppc_31bf3856ad364e35_6.3.9600.19293_none_fc1a8b8354b1fe52\Print Management.lnk.
Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-msinfo32-exe_31bf3856ad364e35_6.3.9600.18728_none_9cdf8199cd713540\System Information.lnk to C:\WINDOWS\WinSxS\amd64_microsoft-windows-msinfo32-exe_31bf3856ad364e35_6.3.9600.18728_none_9cdf8199cd713540\System Information.lnk.
Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-ieframe_31bf3856ad364e35_11.0.9600.19431_none_68584758911fe506\ieframe.ptxml to C:\WINDOWS\WinSxS\amd64_microsoft-windows-ieframe_31bf3856ad364e35_11.0.9600.19431_none_68584758911fe506\ieframe.ptxml.
Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-i..ablenetworkgraphics_31bf3856ad364e35_11.0.9600.19431_none_f17c49e1f66a4fac\pngfilt.dll to C:\WINDOWS\WinSxS\amd64_microsoft-windows-i..ablenetworkgraphics_31bf3856ad364e35_11.0.9600.19431_none_f17c49e1f66a4fac\pngfilt.dll.
Successfully restored ownership for C:\WINDOWS\WinSxS\amd64_microsoft-windows-wordpad_31bf3856ad364e35_6.3.9600.19060_none_1e8a2de440d04365\Wordpad.lnk
Successfully restored permissions on C:\WINDOWS\WinSxS\amd64_microsoft-windows-wordpad_31bf3856ad364e35_6.3.9600.19060_none_1e8a2de440d04365\Wordpad.lnk
Successfully restored ownership for C:\WINDOWS\WinSxS\amd64_microsoft-windows-tabletpc-journal_31bf3856ad364e35_6.3.9600.18295_none_0865e9447896a7bc\Windows Journal.lnk
Successfully restored permissions on C:\WINDOWS\WinSxS\amd64_microsoft-windows-tabletpc-journal_31bf3856ad364e35_6.3.9600.18295_none_0865e9447896a7bc\Windows Journal.lnk
Successfully restored ownership for C:\WINDOWS\WinSxS\amd64_microsoft-windows-performancetoolsgui_31bf3856ad364e35_6.3.9600.18728_none_8d0cd8ee74b6dc18\Performance Monitor.lnk
Successfully restored permissions on C:\WINDOWS\WinSxS\amd64_microsoft-windows-performancetoolsgui_31bf3856ad364e35_6.3.9600.18728_none_8d0cd8ee74b6dc18\Performance Monitor.lnk
Successfully restored ownership for C:\WINDOWS\WinSxS\amd64_microsoft-windows-performancetoolsgui_31bf3856ad364e35_6.3.9600.18728_none_8d0cd8ee74b6dc18\Resource Monitor.lnk
Successfully restored permissions on C:\WINDOWS\WinSxS\amd64_microsoft-windows-performancetoolsgui_31bf3856ad364e35_6.3.9600.18728_none_8d0cd8ee74b6dc18\Resource Monitor.lnk
Successfully restored ownership for C:\WINDOWS\WinSxS\amd64_microsoft-windows-p..erandprintui-pmcppc_31bf3856ad364e35_6.3.9600.19293_none_fc1a8b8354b1fe52\Print Management.lnk
Successfully restored permissions on C:\WINDOWS\WinSxS\amd64_microsoft-windows-p..erandprintui-pmcppc_31bf3856ad364e35_6.3.9600.19293_none_fc1a8b8354b1fe52\Print Management.lnk
Successfully restored ownership for C:\WINDOWS\WinSxS\amd64_microsoft-windows-msinfo32-exe_31bf3856ad364e35_6.3.9600.18728_none_9cdf8199cd713540\System Information.lnk
Successfully restored permissions on C:\WINDOWS\WinSxS\amd64_microsoft-windows-msinfo32-exe_31bf3856ad364e35_6.3.9600.18728_none_9cdf8199cd713540\System Information.lnk
Successfully restored ownership for C:\WINDOWS\WinSxS\amd64_microsoft-windows-ieframe_31bf3856ad364e35_11.0.9600.19431_none_68584758911fe506\ieframe.ptxml
Successfully restored permissions on C:\WINDOWS\WinSxS\amd64_microsoft-windows-ieframe_31bf3856ad364e35_11.0.9600.19431_none_68584758911fe506\ieframe.ptxml
Successfully restored ownership for C:\WINDOWS\WinSxS\amd64_microsoft-windows-i..ablenetworkgraphics_31bf3856ad364e35_11.0.9600.19431_none_f17c49e1f66a4fac\pngfilt.dll
Successfully restored permissions on C:\WINDOWS\WinSxS\amd64_microsoft-windows-i..ablenetworkgraphics_31bf3856ad364e35_11.0.9600.19431_none_f17c49e1f66a4fac\pngfilt.dll
Currently storing 8 datablocks.
Finish time: 2019-09-01 12:16:02.333
Script hash: jMcuMgWZu+F8cbc+92dznm4xh6bw/0jquOifx2NcF2Y=
Thanks for your help - wait for next step.
KT
Thanks.
Retrieve Components Hive
OK ran it.
Start time: 2019-09-02 02:17:01.480
Using .zip script file at C:\Users\admin\Desktop\SFCFix..zip [0]
Successfully took permissions for file or folder C:\WINDOWS\Winsxs\Manifests\amd64_3e084cfac154c6d9eea4d61f70b25a0d_31bf3856ad364e35_4.0.9600.20976_none_100e48872e5b6c36.manifest
Successfully took permissions for file or folder C:\WINDOWS\Winsxs\Manifests\amd64_7e25d47607e16cac5089ac83a80b24a6_b77a5c561934e089_4.0.9600.20976_none_1ca88e29ca0afaa3.manifest
Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_3e084cfac154c6d9eea4d61f70b25a0d_31bf3856ad364e35_4.0.9600.20976_none_100e48872e5b6c36.manifest to C:\WINDOWS\Winsxs\Manifests\amd64_3e084cfac154c6d9eea4d61f70b25a0d_31bf3856ad364e35_4.0.9600.20976_none_100e48872e5b6c36.manifest.
Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_7e25d47607e16cac5089ac83a80b24a6_b77a5c561934e089_4.0.9600.20976_none_1ca88e29ca0afaa3.manifest to C:\WINDOWS\Winsxs\Manifests\amd64_7e25d47607e16cac5089ac83a80b24a6_b77a5c561934e089_4.0.9600.20976_none_1ca88e29ca0afaa3.manifest.
Successfully restored ownership for C:\WINDOWS\Winsxs\Manifests\amd64_3e084cfac154c6d9eea4d61f70b25a0d_31bf3856ad364e35_4.0.9600.20976_none_100e48872e5b6c36.manifest
Successfully restored permissions on C:\WINDOWS\Winsxs\Manifests\amd64_3e084cfac154c6d9eea4d61f70b25a0d_31bf3856ad364e35_4.0.9600.20976_none_100e48872e5b6c36.manifest
Successfully restored ownership for C:\WINDOWS\Winsxs\Manifests\amd64_7e25d47607e16cac5089ac83a80b24a6_b77a5c561934e089_4.0.9600.20976_none_1ca88e29ca0afaa3.manifest
Successfully restored permissions on C:\WINDOWS\Winsxs\Manifests\amd64_7e25d47607e16cac5089ac83a80b24a6_b77a5c561934e089_4.0.9600.20976_none_1ca88e29ca0afaa3.manifest
Currently storing 10 datablocks.
Finish time: 2019-09-02 02:17:01.747
Script hash: alwrl63Z+WQnbCLDx40Ws4h6imYHAajvWNXVkeTHXdc=
Thank you,
KT
Thanks.
2. Try updating the system just like you have in the past.
Hi!
SFCFixScript.txt
  8. Copy (Ctrl+C) and Paste (Ctrl+V) the contents of this into your next post for me to analyse please - put [CODE][/CODE] tags around the log to break up the text.[/list]
Start time: 2019-09-02 17:44:02.769
Using .txt script file at C:\Users\admin\Desktop\SFCFixScript.txt [0]
Trace::
Successfully traced component amd64_d8a3b84a4adf0d3a25112181172f2a43_b03f5f7f11d50a3a_6.3.9600.21003_none_e386f91be0bfa71c.
Package_2_for_KB4040981~31bf3856ad364e35~amd64~~6.3.1.0.4040981-21_neutral_LDR4
Finish time: 2019-09-02 17:44:03.362
Script hash: mpU4P3mkZx55u/w7SBydUCpHs/ckZ04Xp69X8lWpF0Y=
Thanks,
KT
Here you are.
Start time: 2019-09-03 06:58:27.066
Using .zip script file at C:\Users\admin\Desktop\SFCFix (3).zip [0]
Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_d8a3b84a4adf0d3a25112181172f2a43_b03f5f7f11d50a3a_6.3.9600.21003_none_e386f91be0bfa71c.manifest to C:\WINDOWS\Winsxs\Manifests\amd64_d8a3b84a4adf0d3a25112181172f2a43_b03f5f7f11d50a3a_6.3.9600.21003_none_e386f91be0bfa71c.manifest.
Currently storing 11 datablocks.
Finish time: 2019-09-03 06:58:51.700
Script hash: 9fxMKRmSRuALWjfIkXh5aAUMDIAlT4IqZKTRp6Xo5hY=
Thanks,
KT
Start time: 2019-09-03 14:35:29.336
Successfully copied file C:\Users\admin\AppData\Local\niemiro\Archive\Manifests\amd64_f07c8d9844713ae4b14f4f29c2f57226_b03f5f7f11d50a3a_6.3.9600.21003_none_247ab12ecb05322c.manifest to C:\WINDOWS\Winsxs\Manifests\amd64_f07c8d9844713ae4b14f4f29c2f57226_b03f5f7f11d50a3a_6.3.9600.21003_none_247ab12ecb05322c.manifest.
Finish time: 2019-09-03 14:35:50.808
Script hash: Xny4onPC/ZzvjZfbpnE+gydXeASyHaz5D9pfcYAX8zQ=
