[SOLVED] /scannow issue, clean install did not fix it
TwinDenis
Hi, so I have this issue on sfc /scannow that I cannot fix corrupted files, I then try to healthrestore and it doesnt work either.
I tried to clean install windows but it was still there, I havent used sfc /scannow feature since before my ssd installation.
Any ideas?
Here is the error:
" "C:\Windows\system32>sfc /scannow
Verification 100% complete.
C:\Windows\system32>dism /online /cleanup-image /restorehealth
Version: 10.0.10586.0
Image Version: 10.0.10586.0
Error: 0x800f081f
Use the "Source" option to specify the location of the files that are required to restore the feature. For more information on specifying a source location, see Configure a Windows Repair Sourc.
C:\Windows\system32>" "
I also tried this:
https://www.sysnative.com/forums/wi...0-update-including-dism-error-0x800f081f.html
(p)	CSI Payload Corrupt			wow64_microsoft-windows-r..xwddmdriver-wow64-c_31bf3856ad364e35_10.0.10586.0_none_3dae054b56911c22\opencl.dll
Repair failed: Missing replacement payload.
Summary:
Operation: Detect and Repair
Operation result: 0x800f081f
Last Successful Step: Entire operation completes.
Total Detected Corruption:	1
	CBS Manifest Corruption:	0
	CBS Metadata Corruption:	0
	CSI Manifest Corruption:	0
	CSI Metadata Corruption:	0
	CSI Payload Corruption:	1
Total Repaired Corruption:	0
	CBS Manifest Repaired:	0
	CSI Manifest Repaired:	0
	CSI Payload Repaired:	0
	CSI Store Metadata refreshed:	True
Total Operation Time: 126 seconds.
This is a known issue and shouldn't cause any problems.
OpenCL is part of the graphics driver.
If you'd like to replace the file anyway, follow the instructions here: https://www.sysnative.com/forums/wi...tion-sfc-dism-windows-10-update-1511-th2.html
Summary:
Okay thanks I will look into that.
It is odd that microsoft did not know how to fix this or even troubleshoot it, they asked me for 150$ fee to do this or something, I dont know... anyway. I do not trust them the least.
Asked me first to just format/reset pc and so i did, without getting this fixed, then blamed my new SSD for some reason. Anyway.
Can I replace the file without sfc scan? Because I want to keep some useful registry changes I made to my PC.
Also whats up with the error Error: 0x800f081f on the second scan?
Yes, you can replace the file and then run DISM again if you would like :)
The error code indicates that DISM could not replace the file from an update or local source.
Okay so hopefully this will not restore/edit my registry right?
I mean, every time I run sfc scan it replaced my edits. So this time by using only health restore only it will not.
ps: I have already tried the sfcfix method, if thats what you suggest I got the error again.
Okay I managed to fix it. UsedFix->Scan->health restore->scan->restart.
No idea why it did not work on the first try so yeah... thanks.
Glad it worked for you :)
I'll mark the thread solved. If you encounter any problems, please post back and I'll continue to assist you.
