VenomRaven
- Sep 30, 2022
- 2
Hi there.
I have a really specific problem.
When I use my Roland Quad Capture interface for my DAW - it works.
When I use it for general usage and multitasking, the audio drops and stutters frequently. Often opening new tabs in chrome or steam can interrupt audio playback.
However - my system is at low usage when this is happening. 40% RAM 8% CPU. And it can be as simple as running chrome, itunes, steam at once.
I do not suffer these issues when I am only using the audio jack in the PC.
I ran Latencymon and it seemed to say HDAudioBus and NVIDEA windows drivers are the error
I will include LatencyMon report but my specs are:
Windows 10, 16GB RAM, Ryzen 5600G processor.
I would really appreciate any help on this.
CONCLUSION
LatencyMon has been analyzing your system for 0:07:00 (h:mm:ss) on all processors.
SYSTEM INFORMATION
Computer name: MARS
OS version: Windows 10, 10.0, version 2009, build: 19044 (x64)
Hardware: MS-7C91, Micro-Star International Co., Ltd.
BIOS: A.A0
CPU: AuthenticAMD AMD Ryzen 5 5600G with Radeon Graphics
Logical processors: 12
Processor groups: 1
Processor group size: 12
RAM: 14229 MB total
CPU SPEED
Reported CPU speed (WMI): 3901 MHz
Reported CPU speed (registry): 3893 MHz
Highest measured interrupt to process latency (µs): 700.90
Average measured interrupt to process latency (µs): 5.600815
Highest measured interrupt to DPC latency (µs): 698.30
Average measured interrupt to DPC latency (µs): 2.571348
REPORTED ISRs
Highest ISR routine execution time (µs): 144.529412
Highest reported total ISR routine time (%): 0.001397
Driver with highest ISR total time: Wdf01000.sys - Kernel Mode Driver Framework Runtime, Microsoft Corporation
Total time spent in ISRs (%) 0.002676
ISR count (execution time <250 µs): 91823
REPORTED DPCs
Highest DPC routine execution time (µs): 1232.952993
Driver with highest DPC routine execution time: nvlddmkm.sys - NVIDIA Windows Kernel Mode Driver, Version 517.48 , NVIDIA Corporation
Highest reported total DPC routine time (%): 0.071161
Driver with highest DPC total execution time: nvlddmkm.sys - NVIDIA Windows Kernel Mode Driver, Version 517.48 , NVIDIA Corporation
Total time spent in DPCs (%) 0.189809
DPC count (execution time <250 µs): 971919
DPC count (execution time 500-10000 µs): 73
DPC count (execution time 1000-2000 µs): 2
REPORTED HARD PAGEFAULTS
Process with highest pagefault count: latmon.exe
Total number of hard pagefaults 5199
Hard pagefault count of hardest hit process: 3629
Number of processes hit: 60
PER CPU DATA
CPU 0 Interrupt cycle time (s): 23.622774
CPU 0 ISR highest execution time (µs): 144.529412
CPU 0 ISR total execution time (s): 0.093732
CPU 0 ISR count: 50770
CPU 0 DPC highest execution time (µs): 1232.952993
CPU 0 DPC total execution time (s): 7.870403
CPU 0 DPC count: 626846
CPU 1 Interrupt cycle time (s): 5.907099
CPU 1 ISR highest execution time (µs): 25.40560
CPU 1 ISR total execution time (s): 0.040602
CPU 1 ISR count: 40479
CPU 1 DPC highest execution time (µs): 179.442076
CPU 1 DPC total execution time (s): 1.503749
CPU 1 DPC count: 287634
CPU 2 Interrupt cycle time (s): 0.767222
CPU 2 ISR highest execution time (µs): 3.215772
CPU 2 ISR total execution time (s): 0.000574
CPU 2 ISR count: 574
CPU 2 DPC highest execution time (µs): 79.362445
CPU 2 DPC total execution time (s): 0.074645
CPU 2 DPC count: 13435
CPU 3 Interrupt cycle time (s): 0.559136
CPU 3 ISR count: 0
CPU 3 DPC highest execution time (µs): 61.640637
CPU 3 DPC total execution time (s): 0.002257
CPU 3 DPC count: 652
CPU 4 Interrupt cycle time (s): 0.623144
CPU 4 ISR count: 0
CPU 4 DPC highest execution time (µs): 69.624968
CPU 4 DPC total execution time (s): 0.012853
CPU 4 DPC count: 3740
CPU 5 Interrupt cycle time (s): 0.626411
CPU 5 ISR count: 0
CPU 5 DPC highest execution time (µs): 64.676085
CPU 5 DPC total execution time (s): 0.011010
CPU 5 DPC count: 3498
CPU 6 Interrupt cycle time (s): 0.614839
CPU 6 ISR count: 0
CPU 6 DPC highest execution time (µs): 162.712047
CPU 6 DPC total execution time (s): 0.021432
CPU 6 DPC count: 24337
CPU 7 Interrupt cycle time (s): 0.628964
CPU 7 ISR count: 0
CPU 7 DPC highest execution time (µs): 49.789366
CPU 7 DPC total execution time (s): 0.002238
CPU 7 DPC count: 642
CPU 8 Interrupt cycle time (s): 0.551245
CPU 8 ISR count: 0
CPU 8 DPC highest execution time (µs): 61.730799
CPU 8 DPC total execution time (s): 0.006324
CPU 8 DPC count: 1379
CPU 9 Interrupt cycle time (s): 0.617958
CPU 9 ISR count: 0
CPU 9 DPC highest execution time (µs): 64.926535
CPU 9 DPC total execution time (s): 0.005961
CPU 9 DPC count: 1125
CPU 10 Interrupt cycle time (s): 0.675815
CPU 10 ISR count: 0
CPU 10 DPC highest execution time (µs): 93.968662
CPU 10 DPC total execution time (s): 0.028984
CPU 10 DPC count: 4517
CPU 11 Interrupt cycle time (s): 0.653456
CPU 11 ISR count: 0
CPU 11 DPC highest execution time (µs): 69.905471
CPU 11 DPC total execution time (s): 0.029003
CPU 11 DPC count: 4189
CONCLUSION
SYSTEM INFORMATION
Computer name: MARS
BIOS: A.A0
Processor groups: 1
RAM: 14229 MB total
CPU SPEED
REPORTED ISRs
REPORTED DPCs
PER CPU DATA
CPU 3 ISR count: 0
CPU 4 ISR count: 0
CPU 5 ISR count: 0
CPU 6 ISR count: 0
CPU 7 ISR count: 0
CPU 8 ISR count: 0
CPU 9 ISR count: 0
CPU 10 ISR count: 0
CPU 11 ISR count: 0
