DrJoeSanDiego
- Apr 24, 2015
- 44
Re:
Request for sfc Help WRP fail 12-30-16
"Windows Resource Protection could not perform the requested operation."
: CBSlog1230.txt 12/30/2016
: from: J DrJoeSanDiego
2016-12-30 12:55:25, Error CSI 00000307 (F) STATUS_DELETE_PENDING #10533682# from Windows::Rtl::SystemImplementation:
irectFileSystemProvider::SysCreateFile(flags = (AllowSharingViolation|AllowAccessDenied), handle = {provider=NULL, handle=0}, da = (FILE_GENERIC_READ|FILE_WRITE_ATTRIBUTES|FILE_WRITE_EA|FILE_APPEND_DATA|FILE_WRITE_DATA), oa = @0x102d1c0->OBJECT_ATTRIBUTES {s:48; rd:NULL; on:[59]"\SystemRoot\WinSxS\ManifestCache\548c1bd2e27235ea_blobs.bin"; a
OBJ_CASE_INSENSITIVE)}, iosb = @0x102d1f0, as = (null), fa = (FILE_ATTRIBUTE_NORMAL), sa = (FILE_SHARE_READ|FILE_SHARE_WRITE|FILE_SHARE_DELETE), cd = FILE_OPEN_IF, co = (FILE_NON_DIRECTORY_FILE|FILE_SYNCHRONOUS_IO_NONALERT|0x00004000), eab = NULL, eal = 0, disp = Invalid)
[gle=0xd0000056]
2016-12-30 12:55:25, Error CSI 00000308@2016/12/30:20:55:25.972 (F) d:\w7rtm\base\wcp\sil\merged\ntu\ntsystem.cpp(2057): Error STATUS_DELETE_PENDING originated in function Windows::Rtl::SystemImplementation:
irectFileSystemProvider::SysCreateFile expression: (null)
[gle=0x80004005]
2016-12-30 12:55:26, Error CSI 00000309 (F) STATUS_DELETE_PENDING #10533681# from Windows::Rtl::SystemImplementation::CDirectory::CreateNewFile(...)[gle=0xd0000056]
2016-12-30 12:55:26, Error CSI 0000030a (F) STATUS_DELETE_PENDING #10533588# from CCSDirectTransaction::OperateEnding at index 0 of 1 operations, disposition 0[gle=0xd0000056]
2016-12-30 13:22:01, Info CBS Loading offline registry hive: SOFTWARE, into registry key '{bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy4/Windows/System32/config/SOFTWARE' from path '\\?\GLOBALROOT\Device\HarddiskVolumeShadowCopy4\Windows\System32\config\SOFTWARE'.
2016-12-30 13:22:01, Info CBS Loading offline registry hive: SYSTEM, into registry key '{bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy4/Windows/System32/config/SYSTEM' from path '\\?\GLOBALROOT\Device\HarddiskVolumeShadowCopy4\Windows\System32\config\SYSTEM'.
2016-12-30 13:22:01, Info CBS Loading offline registry hive: SECURITY, into registry key '{bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy4/Windows/System32/config/SECURITY' from path '\\?\GLOBALROOT\Device\HarddiskVolumeShadowCopy4\Windows\System32\config\SECURITY'.
2016-12-30 13:22:01, Info CBS Loading offline registry hive: SAM, into registry key '{bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy4/Windows/System32/config/SAM' from path '\\?\GLOBALROOT\Device\HarddiskVolumeShadowCopy4\Windows\System32\config\SAM'.
2016-12-30 13:22:01, Info CBS Loading offline registry hive: COMPONENTS, into registry key '{bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy4/Windows/System32/config/COMPONENTS' from path '\\?\GLOBALROOT\Device\HarddiskVolumeShadowCopy4\Windows\System32\config\COMPONENTS'.
2016-12-30 13:22:01, Info CBS Loading offline registry hive: DEFAULT, into registry key '{bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy4/Windows/System32/config/DEFAULT' from path '\\?\GLOBALROOT\Device\HarddiskVolumeShadowCopy4\Windows\System32\config\DEFAULT'.
2016-12-30 13:22:01, Info CBS Loading offline registry hive: ntuser.dat, into registry key '{bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy4/Users/default/ntuser.dat' from path '\\?\GLOBALROOT\Device\HarddiskVolumeShadowCopy4\Users\default\ntuser.dat'.
2016-12-30 13:22:01, Info CBS Loading offline registry hive: schema.dat, into registry key '{bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy4/Windows/system32/smi/store/Machine/schema.dat' from path '\\?\GLOBALROOT\Device\HarddiskVolumeShadowCopy4\Windows\system32\smi\store\Machine\schema.dat'.
2016-12-30 13:22:01, Info CBS Offline image is: read-only
2016-12-30 13:22:01, Info CBS Disabling manifest caching, because the image is not writeable.
2016-12-30 13:22:01, Info CSI 0000030b CSI Store 112169008 (0x0000000006af9030) initialized
2016-12-30 13:22:01, Info CBS Session: 5740_19288650 initialized by client SPP.
2016-12-30 13:22:48, Info CBS Unloading offline registry hive: {bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy4/Windows/System32/config/SOFTWARE
2016-12-30 13:22:48, Info CBS Unloading offline registry hive: {bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy4/Windows/System32/config/SYSTEM
2016-12-30 13:22:49, Info CBS Unloading offline registry hive: {bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy4/Windows/System32/config/SECURITY
2016-12-30 13:22:49, Info CBS Unloading offline registry hive: {bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy4/Windows/System32/config/SAM
2016-12-30 13:22:49, Info CBS Unloading offline registry hive: {bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy4/Windows/System32/config/COMPONENTS
2016-12-30 13:22:49, Info CBS Unloading offline registry hive: {bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy4/Windows/System32/config/DEFAULT
2016-12-30 13:22:49, Info CBS Unloading offline registry hive: {bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy4/Users/default/ntuser.dat
2016-12-30 13:22:49, Info CBS Unloading offline registry hive: {bf1a281b-ad7b-4476-ac95-f47682990ce7}GLOBALROOT/Device/HarddiskVolumeShadowCopy4/Windows/system32/smi/store/Machine/schema.dat
2016-12-30 16:48:36, Error CSI 0000030c (F) STATUS_DELETE_PENDING #11298737# from Windows::Rtl::SystemImplementation:
[gle=0xd0000056]
2016-12-30 16:48:36, Error CSI 0000030d@2016/12/31:00:48:36.382 (F) d:\w7rtm\base\wcp\sil\merged\ntu\ntsystem.cpp(2057): Error STATUS_DELETE_PENDING originated in function Windows::Rtl::SystemImplementation:
[gle=0x80004005]
2016-12-30 16:48:37, Error CSI 0000030e (F) STATUS_DELETE_PENDING #11298736# from Windows::Rtl::SystemImplementation::CDirectory::CreateNewFile(...)[gle=0xd0000056]
2016-12-30 16:48:37, Error CSI 0000030f (F) STATUS_DELETE_PENDING #11298643# from CCSDirectTransaction::OperateEnding at index 0 of 1 operations, disposition 0[gle=0xd0000056]
: End CBS.log
: CBSlog1230.txt ( was: CBS.log ) 12/30/2016
: NOTE:
sfc /SCANNOW
: NOTE:
December 30, 2016
I just got help (from BrianDrab) the other day - all was fine.
But today I ran sfc /SCANNOW
& got err:
: PS I verified I do have directories (emptied by me) :
: C:\Windows\winsxs\Temp\PendingDeletes& PendingRenames
: ran sfc /SCANNOW ~ 5 times; googling yielded no fuitful ideas
I postponed the suggestion to run regedit
per{ SFC Windows Resource Protection could not perform the requested operation FIX! }.
Their suggestion would be to change all the:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\ProgramFilesDir
keys from e.g. "%ProgramFiles%" to "C:\Program Files" { and they reported that the scan completed successfully}.
Please help:
:huh:
J
[gle=0xd0000056]
[gle=0x80004005]
[gle=0xd0000056]
[gle=0x80004005]
: End CBS.log
: NOTE:
sfc /SCANNOW
: NOTE:
December 30, 2016
& got err:
Please help:
:huh:
J
