Re: How to Diagnose and Fix High DPC Latency Issues with WPA ?!?!
You don't
have to use that specific directory. If you want, you can specify any other directory besides
%userprofile%\Desktop\to dump the capture at. You don't have to use
trace.etl as the name of the file either, just make sure it at least has the .etl extension in it.
Also, you may wanna use the following instead of
DiagEasy for what may be a more appropriate capture for this:
xperf -on PROC_THREAD+LOADER+PROFILE+DRIVERS -stackwalk Profile
It may end up creating a folder with stuff in it as well as the .ETL capture file, both in the same directory. You'll want to zip up both the file and the folder to provide us. If it's too big, upload to like Mirrorcreator.com or some other similar site.
