Random Latency and problem w/dolby
wiser
Hello! I seem to be having problems with latency spikes which usually happen when starting games/while playing/after loading which cause fps drop/slow downs(dota 2 to be precise but it effects other games)
This is how currently my pc is with dota 2 on the background playing+browsing Imgur gets worst as time goes (if I startup dota 2 it goes all to **** and it tells you the usual rubbish about how cpu is throttling and such but the culprits seem to be those 3 with the highest count Imgur
Also about the Dolby (I have plantronics 780) when I enable dolby I get this Imgur with the initial spike of starting the dolby and this is without dolby Imgur (I have uninstalled the programme that came with the headset and im using another pair of headphones with realtek hd audio *plantronics 780 did work without dolby though*
Mobo bios are latest
Realtek HD audio is latest
Here are the stats:
CONCLUSION
LatencyMon has been analyzing your system for 0:18:50 (h:mm:ss) on all processors.
SYSTEM INFORMATION
Computer name: ANON-PC
Hardware: All Series, ASUS, ASUSTeK COMPUTER INC., MAXIMUS VII HERO
CPU: GenuineIntel Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz
Logical processors: 8
Processor groups: 1
RAM: 16326 MB total
CPU SPEED
Reported CPU speed: 3997.0 MHz
Measured CPU speed: 4187.0 MHz (approx.)
Highest measured interrupt to process latency (µs): 325.559188
Average measured interrupt to process latency (µs): 1.736101
Highest measured interrupt to DPC latency (µs): 115.264858
Average measured interrupt to DPC latency (µs): 0.535630
REPORTED ISRs
Highest ISR routine execution time (µs): 67.628722
Highest reported total ISR routine time (%): 0.093054
Total time spent in ISRs (%) 0.141995
ISR count (execution time <250 µs): 2116091
REPORTED DPCs
Highest DPC routine execution time (µs): 259.939955
Driver with highest DPC routine execution time: nvlddmkm.sys - NVIDIA Windows Kernel Mode Driver, Version 350.12 , NVIDIA Corporation
Highest reported total DPC routine time (%): 0.033318
Total time spent in DPCs (%) 0.136154
DPC count (execution time <250 µs): 6785057
DPC count (execution time 500-999 µs): 1
REPORTED HARD PAGEFAULTS
Process with highest pagefault count: firefox.exe
Total number of hard pagefaults 1679
Hard pagefault count of hardest hit process: 775
Highest hard pagefault resolution time (µs): 3068.993245
Total time spent in hard pagefaults (%): 0.002954
Number of processes hit: 17
PER CPU DATA
CPU 0 Interrupt cycle time (s): 27.088202
CPU 0 ISR highest execution time (µs): 67.628722
CPU 0 ISR total execution time (s): 12.837620
CPU 0 ISR count: 2116091
CPU 0 DPC highest execution time (µs): 259.939955
CPU 0 DPC total execution time (s): 11.847695
CPU 0 DPC count: 6546582
CPU 1 Interrupt cycle time (s): 1.581797
CPU 1 ISR count: 0
CPU 1 DPC highest execution time (µs): 59.459595
CPU 1 DPC total execution time (s): 0.039492
CPU 1 DPC count: 14267
CPU 2 Interrupt cycle time (s): 2.355653
CPU 2 ISR count: 0
CPU 2 DPC highest execution time (µs): 57.840380
CPU 2 DPC total execution time (s): 0.102558
CPU 2 DPC count: 59559
CPU 3 Interrupt cycle time (s): 1.838126
CPU 3 ISR count: 0
CPU 3 DPC highest execution time (µs): 61.937453
CPU 3 DPC total execution time (s): 0.034224
CPU 3 DPC count: 16841
CPU 4 Interrupt cycle time (s): 1.555901
CPU 4 ISR count: 0
CPU 4 DPC highest execution time (µs): 61.224919
CPU 4 DPC total execution time (s): 0.034662
CPU 4 DPC count: 17112
CPU 5 Interrupt cycle time (s): 2.053545
CPU 5 ISR count: 0
CPU 5 DPC highest execution time (µs): 54.129597
CPU 5 DPC total execution time (s): 0.073937
CPU 5 DPC count: 42266
CPU 6 Interrupt cycle time (s): 1.490085
CPU 6 ISR count: 0
CPU 6 DPC highest execution time (µs): 61.039780
CPU 6 DPC total execution time (s): 0.038406
CPU 6 DPC count: 17987
CPU 7 Interrupt cycle time (s): 2.078742
CPU 7 ISR count: 0
CPU 7 DPC highest execution time (µs): 60.118089
CPU 7 DPC total execution time (s): 0.138518
CPU 7 DPC count: 70444
**Update on Main drivers at 42 mins in Imgur (just switching to another dota 2 game and nothing else )
Here are the stats just incase:
CONCLUSION
LatencyMon has been analyzing your system for 0:48:32 (h:mm:ss) on all processors.
SYSTEM INFORMATION
Processor groups: 1
RAM: 16326 MB total
CPU SPEED
Highest measured interrupt to process latency (µs): 598.352686
Average measured interrupt to process latency (µs): 1.745495
Highest measured interrupt to DPC latency (µs): 127.047488
Average measured interrupt to DPC latency (µs): 0.539250
REPORTED ISRs
Highest ISR routine execution time (µs): 87.675757
Highest reported total ISR routine time (%): 0.100246
Total time spent in ISRs (%) 0.149352
ISR count (execution time <250 µs): 5538091
REPORTED DPCs
Highest reported total DPC routine time (%): 0.035456
Total time spent in DPCs (%) 0.137138
DPC count (execution time <250 µs): 16820284
Total number of hard pagefaults 2154
Hard pagefault count of hardest hit process: 783
Highest hard pagefault resolution time (µs): 3242.091569
Total time spent in hard pagefaults (%): 0.001373
Number of processes hit: 19
PER CPU DATA
CPU 0 Interrupt cycle time (s): 71.440498
CPU 0 ISR highest execution time (µs): 87.675757
CPU 0 ISR total execution time (s): 34.794338
CPU 0 ISR count: 5538091
CPU 0 DPC total execution time (s): 30.612264
CPU 0 DPC count: 16093359
CPU 1 Interrupt cycle time (s): 4.398458
CPU 1 ISR count: 0
CPU 1 DPC highest execution time (µs): 59.771829
CPU 1 DPC total execution time (s): 0.113246
CPU 1 DPC count: 51148
CPU 2 Interrupt cycle time (s): 6.328740
CPU 2 ISR count: 0
CPU 2 DPC highest execution time (µs): 64.286215
CPU 2 DPC total execution time (s): 0.261358
CPU 2 DPC count: 154597
CPU 3 Interrupt cycle time (s): 5.107213
CPU 3 ISR count: 0
CPU 3 DPC total execution time (s): 0.105483
CPU 3 DPC count: 59653
CPU 4 Interrupt cycle time (s): 4.242158
CPU 4 ISR count: 0
CPU 4 DPC total execution time (s): 0.102639
CPU 4 DPC count: 56415
CPU 5 Interrupt cycle time (s): 5.659425
CPU 5 ISR count: 0
CPU 5 DPC highest execution time (µs): 60.181136
CPU 5 DPC total execution time (s): 0.212926
CPU 5 DPC count: 129228
CPU 6 Interrupt cycle time (s): 4.192509
CPU 6 ISR count: 0
CPU 6 DPC highest execution time (µs): 82.665999
CPU 6 DPC total execution time (s): 0.149137
CPU 6 DPC count: 73783
CPU 7 Interrupt cycle time (s): 5.709744
CPU 7 ISR count: 0
CPU 7 DPC highest execution time (µs): 63.570678
CPU 7 DPC total execution time (s): 0.391923
CPU 7 DPC count: 202102
Thanks in advance to who wishes to help a guy out.
Update* this is of today while watching youtube and opening some programmes Imgur
CONCLUSION
LatencyMon has been analyzing your system for 0:17:08 (h:mm:ss) on all processors.
SYSTEM INFORMATION
Processor groups: 1
RAM: 16326 MB total
CPU SPEED
Measured CPU speed: 4189.0 MHz (approx.)
Highest measured interrupt to process latency (µs): 182.886908
Average measured interrupt to process latency (µs): 0.985056
Highest measured interrupt to DPC latency (µs): 181.350043
Average measured interrupt to DPC latency (µs): 0.393598
REPORTED ISRs
Highest ISR routine execution time (µs): 229.782337
Highest reported total ISR routine time (%): 0.048303
Total time spent in ISRs (%) 0.091443
ISR count (execution time <250 µs): 1360105
REPORTED DPCs
Highest DPC routine execution time (µs): 190.191644
Driver with highest DPC routine execution time: dxgkrnl.sys - DirectX Graphics Kernel, Microsoft Corporation
Highest reported total DPC routine time (%): 0.022968
Driver with highest DPC total execution time: nvlddmkm.sys - NVIDIA Windows Kernel Mode Driver, Version 350.12 , NVIDIA Corporation
Total time spent in DPCs (%) 0.076159
DPC count (execution time <250 µs): 4768640
DPC count (execution time 500-999 µs): 0
Process with highest pagefault count: dllhost.exe
Total number of hard pagefaults 3590
Hard pagefault count of hardest hit process: 964
Highest hard pagefault resolution time (µs): 51358.772079
Total time spent in hard pagefaults (%): 0.013590
Number of processes hit: 13
PER CPU DATA
CPU 0 Interrupt cycle time (s): 15.835355
CPU 0 ISR highest execution time (µs): 229.782337
CPU 0 ISR total execution time (s): 7.520495
CPU 0 ISR count: 1360105
CPU 0 DPC highest execution time (µs): 190.191644
CPU 0 DPC total execution time (s): 5.967066
CPU 0 DPC count: 4620647
CPU 1 Interrupt cycle time (s): 1.412424
CPU 1 ISR count: 0
CPU 1 DPC highest execution time (µs): 59.989992
CPU 1 DPC total execution time (s): 0.020233
CPU 1 DPC count: 5459
CPU 2 Interrupt cycle time (s): 1.284525
CPU 2 ISR count: 0
CPU 2 DPC highest execution time (µs): 38.723042
CPU 2 DPC total execution time (s): 0.038735
CPU 2 DPC count: 23965
CPU 3 Interrupt cycle time (s): 1.420589
CPU 3 ISR count: 0
CPU 3 DPC highest execution time (µs): 51.130348
CPU 3 DPC total execution time (s): 0.027203
CPU 3 DPC count: 7703
CPU 4 Interrupt cycle time (s): 1.174862
CPU 4 ISR count: 0
CPU 4 DPC highest execution time (µs): 40.582437
CPU 4 DPC total execution time (s): 0.029453
CPU 4 DPC count: 8756
CPU 5 Interrupt cycle time (s): 1.517512
CPU 5 ISR count: 0
CPU 5 DPC highest execution time (µs): 45.648236
CPU 5 DPC total execution time (s): 0.054843
CPU 5 DPC count: 20980
CPU 6 Interrupt cycle time (s): 1.291513
CPU 6 ISR count: 0
CPU 6 DPC highest execution time (µs): 47.619715
CPU 6 DPC total execution time (s): 0.045728
CPU 6 DPC count: 19217
CPU 7 Interrupt cycle time (s): 0.799154
CPU 7 ISR count: 0
CPU 7 DPC highest execution time (µs): 49.892419
CPU 7 DPC total execution time (s): 0.080240
CPU 7 DPC count: 61913
and I have no idea why its linking to imgur xD must of pressed something by mistake
