Random BSOD's please help
boosted
Hi everyone, my computer is a pretty recent build (12 months ago) and I occasionally get random BSOD's with different error messages every time. This has been occuring while I am doing different things e.g. while gaming, while browsing, when attempting to shutdown/restart. So I'm trying to figure out what the problem is. I thought it might be my GPU driver but I recently updated them from the manufacturers website and still I am getting BSOD's. I have attached the files required, hope soemone can help :)
System specs:
http://speccy.piriform.com/results/3DfQC1zxJigDF5w2xdWot1N
Hi Boosted,
Welcome to Sysnative forums.
The crashes look to be all over the place, but the event logs give some troubling signs for the Windows partition.
I recommend checking your SSD for problems with chkdsk and check Samsung Magician for firmware updates. To run chkdsk, simply open an admin command prompt and run the command "chkdsk /r" which fixes errors and looks for bad areas on the SSD and addresses them accordingly.
I also suggest running MemTest86 twice. You want to run it twice, because we generally recommend running MemTest86 for 8 passes, but the free version's max passes has been limited to 4.
   2021-11-01T05:15:17.1260000Z        Volume C: (\Device\HarddiskVolume3) needs to be taken offline to perform a Full Chkdsk.  Please run "CHKDSK /F" locally via the command line, or run "REPAIR-VOLUME <drive:>" locally or remotely via PowerShell.
   2021-11-01T05:15:17.1660000Z        A corruption was discovered in the file system structure on volume C:.
The exact nature of the corruption is unknown.  The file system structures need to be scanned and fixed offline.
   2021-11-01T15:11:02.6810000Z        Volume C: (\Device\HarddiskVolume3) needs to be taken offline to perform a Full Chkdsk.  Please run "CHKDSK /F" locally via the command line, or run "REPAIR-VOLUME <drive:>" locally or remotely via PowerShell.
   2021-11-01T19:07:12.7880000Z        Volume ?? (\Device\HarddiskVolumeShadowCopy3) needs to be taken offline to perform a Full Chkdsk.  Please run "CHKDSK /F" locally via the command line, or run "REPAIR-VOLUME <drive:>" locally or remotely via PowerShell.
   2021-11-02T01:30:49.5190000Z        Volume C: (\Device\HarddiskVolume3) needs to be taken offline to perform a Full Chkdsk.  Please run "CHKDSK /F" locally via the command line, or run "REPAIR-VOLUME <drive:>" locally or remotely via PowerShell.
   2021-11-02T14:41:40.6690000Z        Volume C: (\Device\HarddiskVolume3) needs to be taken offline to perform a Full Chkdsk.  Please run "CHKDSK /F" locally via the command line, or run "REPAIR-VOLUME <drive:>" locally or remotely via PowerShell.
   2021-11-03T15:28:44.6340000Z        Volume C: (\Device\HarddiskVolume3) needs to be taken offline to perform a Full Chkdsk.  Please run "CHKDSK /F" locally via the command line, or run "REPAIR-VOLUME <drive:>" locally or remotely via PowerShell.
   2021-11-03T20:45:05.7980000Z        Volume C: (\Device\HarddiskVolume3) needs to be taken offline to perform a Full Chkdsk.  Please run "CHKDSK /F" locally via the command line, or run "REPAIR-VOLUME <drive:>" locally or remotely via PowerShell.
   2021-11-03T20:45:05.8560000Z        Dump file creation failed due to error during dump creation.
   2021-11-03T21:28:46.5900000Z        Volume ?? (\Device\HarddiskVolumeShadowCopy4) needs to be taken offline to perform a Full Chkdsk.  Please run "CHKDSK /F" locally via the command line, or run "REPAIR-VOLUME <drive:>" locally or remotely via PowerShell.
   2021-11-03T21:38:09.6470000Z        Volume C: (\Device\HarddiskVolume3) needs to be taken offline to perform a Full Chkdsk.  Please run "CHKDSK /F" locally via the command line, or run "REPAIR-VOLUME <drive:>" locally or remotely via PowerShell.
   2021-11-04T18:09:17.8110000Z        Volume C: (\Device\HarddiskVolume3) needs to be taken offline to perform a Full Chkdsk.  Please run "CHKDSK /F" locally via the command line, or run "REPAIR-VOLUME <drive:>" locally or remotely via PowerShell.
   2021-11-05T18:22:57.7380000Z        Volume C: (\Device\HarddiskVolume3) needs to be taken offline to perform a Full Chkdsk.  Please run "CHKDSK /F" locally via the command line, or run "REPAIR-VOLUME <drive:>" locally or remotely via PowerShell.
   2021-11-05T22:07:39.9450000Z        Volume C: (\Device\HarddiskVolume3) needs to be taken offline to perform a Full Chkdsk.  Please run "CHKDSK /F" locally via the command line, or run "REPAIR-VOLUME <drive:>" locally or remotely via PowerShell.
