Let's take a look. Sorry for the delay. Please do the following. I'm having you re-run SFC so we have a fresh log.
SFC Scan
- Click on the Start
button and in the search box, type Command Prompt![]()
- When you see Command Prompt on the list, right-click on it and select Run as administrator
- When command prompt opens, copy and paste the following commands into it, press enter after each
copy %windir%\logs\cbs\cbs.log %userprofile%\Desktop\cbs.txt- This will create a file, cbs.txt on your Desktop. Please attach this to your next post.
Please Note:: if the file is too big to upload to your next post (or if you have issues attaching it) please upload via a service such as Dropbox or One Drive or SendSpace and just provide the link.
Please upload your file to SendSpace and then just provide the link here. How many beeps do you hear at startup? Also is it a long then short or multiple short beeps? Those all mean something different so let me know. Thanks.
2015-11-18 09:07:37, Info CSI 000005df Hashes for file member \SystemRoot\WinSxS\amd64_microsoft-windows-sidebar_31bf3856ad364e35_6.0.6001.18000_none_2afb4740df058c0c\settings.ini do not match actual file [l:24{12}]"settings.ini" :
Found: {l:32 b:PF+0oMOHeSdDaSy4ZFcNhoRrk9QOY+HBWL4HP5YUMUg=} Expected: {l:32 b:v6OQf2AJO5FVbRBJuIwXxkdkCoOaSk3y0ol6uTH491o=}
2015-11-18 09:07:37, Info CSI 000005e0 [SR] Cannot repair member file [l:24{12}]"settings.ini" of Microsoft-Windows-Sidebar, Version = 6.0.6001.18000, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2015-11-18 09:07:37, Info CSI 000005e1 Hashes for file member \SystemRoot\WinSxS\wow64_microsoft-windows-sidebar_31bf3856ad364e35_6.0.6001.18000_none_354ff19313664e07\settings.ini do not match actual file [l:24{12}]"settings.ini" :
Found: {l:32 b:f4a4oE6RZa4FZQ9vPyg3tlS0RBWPkbuQA3+d1SAOqUk=} Expected: {l:32 b:v6OQf2AJO5FVbRBJuIwXxkdkCoOaSk3y0ol6uTH491o=}
2015-11-18 09:07:37, Info CSI 000005e2 [SR] Cannot repair member file [l:24{12}]"settings.ini" of Microsoft-Windows-Sidebar, Version = 6.0.6001.18000, pA = PROCESSOR_ARCHITECTURE_IA32_ON_WIN64 (10), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2015-11-18 09:07:37, Info CSI 000005e3 Hashes for file member \SystemRoot\WinSxS\amd64_microsoft-windows-sidebar_31bf3856ad364e35_6.0.6001.18000_none_2afb4740df058c0c\settings.ini do not match actual file [l:24{12}]"settings.ini" :
2015-11-18 09:07:37, Info CSI 000005e4 [SR] Cannot repair member file [l:24{12}]"settings.ini" of Microsoft-Windows-Sidebar, Version = 6.0.6001.18000, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2015-11-18 09:07:37, Info CSI 000005e5 Hashes for file member \??\C:\Program Files\Windows Sidebar\settings.ini do not match actual file [l:24{12}]"settings.ini" :
2015-11-18 09:07:37, Info CSI 000005e6 Hashes for file member \SystemRoot\WinSxS\amd64_microsoft-windows-sidebar_31bf3856ad364e35_6.0.6001.18000_none_2afb4740df058c0c\settings.ini do not match actual file [l:24{12}]"settings.ini" :
2015-11-18 09:07:37, Info CSI 000005e7 [SR] Could not reproject corrupted file [ml:520{260},l:72{36}]"\??\C:\Program Files\Windows Sidebar"\[l:24{12}]"settings.ini"; source file in store is also corrupted
2015-11-18 09:07:37, Info CSI 000005e8 Hashes for file member \SystemRoot\WinSxS\wow64_microsoft-windows-sidebar_31bf3856ad364e35_6.0.6001.18000_none_354ff19313664e07\settings.ini do not match actual file [l:24{12}]"settings.ini" :
2015-11-18 09:07:37, Info CSI 000005e9 [SR] Cannot repair member file [l:24{12}]"settings.ini" of Microsoft-Windows-Sidebar, Version = 6.0.6001.18000, pA = PROCESSOR_ARCHITECTURE_IA32_ON_WIN64 (10), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2015-11-18 09:07:37, Info CSI 000005ea Hashes for file member \??\C:\Program Files (x86)\Windows Sidebar\settings.ini do not match actual file [l:24{12}]"settings.ini" :
2015-11-18 09:07:37, Info CSI 000005eb Hashes for file member \SystemRoot\WinSxS\wow64_microsoft-windows-sidebar_31bf3856ad364e35_6.0.6001.18000_none_354ff19313664e07\settings.ini do not match actual file [l:24{12}]"settings.ini" :
2015-11-18 09:07:37, Info CSI 000005ec [SR] Could not reproject corrupted file [ml:520{260},l:84{42}]"\??\C:\Program Files (x86)\Windows Sidebar"\[l:24{12}]"settings.ini"; source file in store is also corrupted
Brian, thanks for your help. The sfc scannow could not complete and the special fix tool at your site could not complete either. I also can't update service pack 1 either. I think it is a corrupt system file. I even reset the computer back to it's original settings and it helped but no taco. I made the cbs file but couldn't upload it to your site. I just tried again but I don't see it anywhere. I have ms security essentials and have run a scan with no detection's. explorer was (not responding) again too. Someone said it could be my motherboard. I think it's something that can be fixed. It started beeping at startup again as well. I attached the file. I don't know if you will get it.
SFC Scan
OK, no problem. Have the hardware guys check out the issue with the beeping you are having as that may be a serious issue. Then come back here and we'll continue.
