[SOLVED] Problems with Sfc.exe
Lanneret
Hi - help needed:
System: Windows 7 Home Premium Service Pack 1 64-bit
Problem that started it all was Win Explorer acting oddly, had two instances of all desktop icons disappearing. Thought at first it was third party GUI enhancement software, but eliminated that. Wanted to check system files for corruption, so tried to run sfc.exe.
I am having difficulties getting sfc.exe to correct suspected corrupt system files. Have tried from elevated command prompt as well as booting from HP repair disk (created from this system) and from downloaded .iso (Win7_HomePrem_SP1_English_x64) burned to DVD. From elev. cmd prompt I consistently says Verification 100% complete but refuses to correct anything: "Windows Resource Protection could not start the repair service".
I then ran CheckSUR Scan
CheckSUR log:
Checking Component Store
(f) CSI Missing Winning Component Key 0x00000000 amd64_policy.14.0.avg.vc140.mfc_f92d94485545da78_14.0.25325.0_none_882c42cee4e7ea43
(f) CSI Unexpected Failure 0x00000005 14.0.25325.0 amd64_policy.14.0.avg.vc140.mfc_f92d94485545da78_14.0.25325.0_none_882c42cee4e7ea43 Error deleting winners map value.
(f) CSI Missing Winning Component Key 0x00000000 x86_policy.14.0.avg.vc140.crt_f92d94485545da78_14.0.25325.0_none_d7585f6ff4959666
(f) CSI Unexpected Failure 0x00000005 14.0.25325.0 x86_policy.14.0.avg.vc140.crt_f92d94485545da78_14.0.25325.0_none_d7585f6ff4959666 Error deleting winners map value.
(f) CSI Missing Winning Component Key 0x00000000 amd64_policy.14.0.avg.vc140.crt_f92d94485545da78_14.0.25325.0_none_8fab2898e0196d60
(f) CSI Unexpected Failure 0x00000005 14.0.25325.0 amd64_policy.14.0.avg.vc140.crt_f92d94485545da78_14.0.25325.0_none_8fab2898e0196d60 Error deleting winners map value.
(f) CSI Missing Winning Component Key 0x00000000 amd64_avg.vc140.mfc_f92d94485545da78_14.0.25325.0_none_643e18eddbf60d95
(f) CSI Unexpected Failure 0x00000005 14.0.25325.0 amd64_avg.vc140.mfc_f92d94485545da78_14.0.25325.0_none_643e18eddbf60d95 Error deleting winners map value.
(f) CSI Missing Winning Component Key 0x00000000 x86_avg.vc140.mfc_f92d94485545da78_14.0.25325.0_none_abeb4fc4f072369b
(f) CSI Unexpected Failure 0x00000005 14.0.25325.0 x86_avg.vc140.mfc_f92d94485545da78_14.0.25325.0_none_abeb4fc4f072369b Error deleting winners map value.
(f) CSI Missing Winning Component Key 0x00000000 x86_policy.14.0.avg.vc140.mfc_f92d94485545da78_14.0.25325.0_none_cfd979a5f9641349
(f) CSI Unexpected Failure 0x00000005 14.0.25325.0 x86_policy.14.0.avg.vc140.mfc_f92d94485545da78_14.0.25325.0_none_cfd979a5f9641349 Error deleting winners map value.
(f) CSI Missing Winning Component Key 0x00000000 x86_avg.vc140.crt_f92d94485545da78_14.0.25325.0_none_b36a358eeba3b9b8
(f) CSI Unexpected Failure 0x00000005 14.0.25325.0 x86_avg.vc140.crt_f92d94485545da78_14.0.25325.0_none_b36a358eeba3b9b8 Error deleting winners map value.
(f) CSI Missing Winning Component Key 0x00000000 amd64_avg.vc140.crt_f92d94485545da78_14.0.25325.0_none_6bbcfeb7d72790b2
(f) CSI Unexpected Failure 0x00000005 14.0.25325.0 amd64_avg.vc140.crt_f92d94485545da78_14.0.25325.0_none_6bbcfeb7d72790b2 Error deleting winners map value.
Summary:
Seconds executed: 201
Found 16 errors
CSI Unexpected Failure Total count: 8
CSI Missing Winning Component Key Total count: 8
Ran SFCFix without much success - here is log:
Start time: 2018-05-08 18:55:39.830
CORRUPT: C:\windows\winsxs\amd64_microsoft-windows-t..teconnectionmanager_31bf3856ad364e35_6.1.7601.18637_none_ecb2935b6af13c52\termsrv.dll
CORRUPT: C:\windows\winsxs\wow64_microsoft-windows-ie-sysprep_31bf3856ad364e35_11.2.9600.16428_none_083dd731036b79d4\iesysprep.dll
SURT total detected corruption count: 16
Finish time: 2018-05-08 19:00:38.204
My CBS folder was zipped up after the above operations and is on Google drive:
CBS.zip - Google Drive
I have used sfc going back to XP, but tried running DISM.exe for the first time after googling what to do when sfc.exe fails. I really don't want to do a format and reinstall. If all else fails, I'm considering trying a non-destructive restore of the system files but would really like to repair sfc.exe and correct the corrupted files. Any help appreciated.
Hello and welcome to Sysnative!
SFC Scan
Here is content of SFCFix.txt:
Start time: 2018-05-10 16:21:52.923
Using .zip script file at C:\Users\dbridges\Desktop\SFCFix.zip [0]
Successfully took permissions for file or folder C:\windows\winsxs\wow64_microsoft-windows-ie-sysprep_31bf3856ad364e35_11.2.9600.16428_none_083dd731036b79d4\iesysprep.dll
Successfully took permissions for file or folder C:\windows\winsxs\amd64_microsoft-windows-t..teconnectionmanager_31bf3856ad364e35_6.1.7601.18637_none_ecb2935b6af13c52\termsrv.dll
Successfully copied file C:\Users\dbridges\AppData\Local\niemiro\Archive\winsxs\wow64_microsoft-windows-ie-sysprep_31bf3856ad364e35_11.2.9600.16428_none_083dd731036b79d4\iesysprep.dll to C:\windows\winsxs\wow64_microsoft-windows-ie-sysprep_31bf3856ad364e35_11.2.9600.16428_none_083dd731036b79d4\iesysprep.dll.
Successfully copied file C:\Users\dbridges\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-t..teconnectionmanager_31bf3856ad364e35_6.1.7601.18637_none_ecb2935b6af13c52\termsrv.dll to C:\windows\winsxs\amd64_microsoft-windows-t..teconnectionmanager_31bf3856ad364e35_6.1.7601.18637_none_ecb2935b6af13c52\termsrv.dll.
Successfully restored ownership for C:\windows\winsxs\wow64_microsoft-windows-ie-sysprep_31bf3856ad364e35_11.2.9600.16428_none_083dd731036b79d4\iesysprep.dll
Successfully restored permissions on C:\windows\winsxs\wow64_microsoft-windows-ie-sysprep_31bf3856ad364e35_11.2.9600.16428_none_083dd731036b79d4\iesysprep.dll
Successfully restored ownership for C:\windows\winsxs\amd64_microsoft-windows-t..teconnectionmanager_31bf3856ad364e35_6.1.7601.18637_none_ecb2935b6af13c52\termsrv.dll
Successfully restored permissions on C:\windows\winsxs\amd64_microsoft-windows-t..teconnectionmanager_31bf3856ad364e35_6.1.7601.18637_none_ecb2935b6af13c52\termsrv.dll
Finish time: 2018-05-10 16:21:56.308
Script hash: skr6+GtcWwkpAAE3/ni7rvJ8Aupeody4kz/BsSJQm8w=
I have uploaded "cbs.txt".
SFC Scan
2. Open an elevated Command Prompt and try SFC Scan just like you have in the past.
OK, softwaremaniac....I really appreciate your help. "CBS.zip" is attached. "Logfile.zip" is on my google drive:
Logfile.zip - Google Drive
Thanks again !
Hi - help needed:
CheckSUR log:
Summary:
Found 16 errors
Can you go to: C:\Windows\System32\SearchIndexer.exe. Right-click it, go to the Security tab and verify that TrustedInstaller has everything set to allow except Special Premissions. Ideally provide screenshots of every user's status.
OK, obviously the settings shown in screenshots are incorrect - should TrustedInstaller have ownership ? ?
Run Windows Repairs
  1. Download Windows Repair (All-in-One) Portable to your desktop.
  2. Once the file is downloaded, right-click on the file on your desktop and choose Extract All...
  3. Keep the defaults and click the Extract button.
  4. A folder named tweaking.com_windows_repair_aio will be extracted to the desktop. Once the extraction is complete the folder will open.
  5. Inside this folder, there is a folder named Tweaking.com - Windows Repair. Open this folder as well.
  6. Double-click on Repair_Windows.exe to open. Note: Please make sure all of your programs are closed and anything you were working on is saved as we will be rebooting.
  7. When the program opens, click the Reboot to Safe Mode button at the bottom of the screen. Answer Yes to allow.
  8. Once rebooted into Safe Mode, open the program again. When the program opens, click the Repairs tab and click the Open Repairs button.
  9. A backup of your registry will be made. After a few moments you will have many options from which you can choose.
10. Please click the Unselect All button and then click to enable only the following ones:
Reset Registry Permissions
Reset File Permissions
Remove Policies Set by Infections
11. Ensure the Restart check box is selected and click the Start Repairs button in the lower right of the screen. This may take some time to run so be patient.
12. Once the fixes are complete you will be prompted to restart your machine. Answer Yes.
OK, after running Repair_Windows.exe and a restart, the properties of SearchIndexer.exe remain unchanged:
When I click on the Owner tab of the Adv. security settings of SearchIndexer.exe and then choose edit, I can't look at any options for either Administrators or dbridges (see screenshots):
OK, I created test user account with administrator privileges and ran sfc scan with same result - Windows Resource Protection could not perform...etc. Have uploaded new cbs log as cbsnew.zip.
Can you create a test user account with admin privileges, log in and try SFC from there?
SFC Scan
Start time: 2018-05-11 21:43:46.757
Successfully took permissions for file or folder C:\windows\Sysnative
Failed to read file attributes for file C:\windows\System32\SearchIndexer.exe.
Failed to copy file C:\Users\dbridges\AppData\Local\niemiro\Archive\System32\SearchIndexer.exe to C:\windows\System32\SearchIndexer.exe with error code ERROR_ACCESS_DENIED.
Successfully restored ownership for C:\windows\Sysnative
Successfully restored permissions on C:\windows\Sysnative
PowerCopy:: directive failed to complete successfully.
Finish time: 2018-05-11 21:43:53.060
Script hash: p0XTVckchOe4I11z4I4k/lzM2GsFtz/4VGdJW7+XcJA=
cbs zip file attached.
SFC Scan
sorry, here it is..
Also noticed that 3 files in C:\Windows\System32 have much newer file modified dates than all the others:
FRST Fix
1. Please download Farbar Recovery Scan Tool and save it to your Desktop (you may use the one you already have downloaded).
6. Also, please attach the file named perms that is located on your desktop.
As requested:
Fix result of Farbar Recovery Scan Tool (x64) Version: 12.05.2018
Ran by dbridges (12-05-2018 10:12:20) Run:1
Running from C:\Users\dbridges\Desktop
Loaded Profiles: dbridges & AdminX & test_user & Administrator (Available Profiles: dbridges & AdminX & test_user & Administrator)
Boot Mode: Normal
fixlist content:
cmd: icacls C:\windows\System32\SearchIndexer.exe
cmd: icacls c:\windows\System32 /save %userprofile%\desktop\perms
========= icacls C:\windows\System32\SearchIndexer.exe =========
C:\windows\System32\SearchIndexer.exe: Access is denied.
Successfully processed 0 files; Failed processing 1 files
========= icacls c:\windows\System32 /save %userprofile%\desktop\perms =========
processed file: c:\windows\System32
Successfully processed 1 files; Failed processing 0 files
==== End of Fixlog 10:12:20 ====
This is a tough one.
  1. Download Process Explorer from here
  2. Open Process Explorer, running as administrator.
  3. On the toolbar, find the gunsight icon on the right (shown highlighted in the figure shown below).
  4. Drag the icon and drop it on C:\windows\System32\SearchIndexer.exe that is locked.
  5. The executable that is using the file will be highlighted in the Process Explorer main display list.
Let me know which executable is identified.
