Problems with DISM and SFC
Lazyluna678
I've been trying to install Windows Update 2004 when I kept on getting the 0x800700c1 error. I proceeded to run a DISM and SFC scan, both of which had the WOF driver encounter a corrupt file in the compressed table. Please help me!
Hi!
GSmartControl
Ok it is running I'll get back to you in 3 and a half hours
1589997852780.pngSorry took way longer than I expected. Weirdly, it has come back without error. I'll be off my computer for 12 hours now but I will run any extra tests tomorrow. Also, all attributes are fine too
Please do the following:
SFC Scan
It's probably because I'm in the slow ring of the Insider program. I got the ISO from the Windows website
I would recommend that you reinstall the latest stable OS version. That is 1909 at the time of typing this, but there is a new version coming out today or tomorrow most likely.
Ok thank you, although I’m not sure it will work as it doesn’t seem to like the smaller updates at the moment. I’ll use an ISO if 2004 doesn’t work. Thanks for all your help :)
1591178488605.pngI have tried being in the insider program, out of the insider program, downloading from an ISO, downloading from Windows Assistant and downloading through windows update, and all of them show up with 0x800700c1. Can you see if you can help please?
