[SOLVED] problems related to Internet Explorer dlls
Dom7894
I have a problem related to Internet Explorer dlls.
Internet Explorer is not installed so I tried installing it, but it did not change anything.
A software (ForgeUI) can't start because "IEShims.dll or one of its dependencies" is missing.
and sfc /scannow finds a file it cannot repair : "Cannot repair member file [l:24{12}]"webcheck.dll" (...) file is missing"
Can someone help, please?
  • Download
Click the Start button and then type cmd in the search box. Right-click on cmd that comes up in the search results and select Run as administrator.
A User Account Control dialog may come up asking for approval. If it does go ahead and allow.
A command prompt window will open. Copy and paste the following into the command-prompt and hit enter.
dir c:\windows\winsxs\amd64_Microsoft-Windows-IE-OfflineFavorites_*.* > "%USERPROFILE%\desktop\dirlist.txt"
4. After the command runs there will be a file on your desktop named dirlist.txt.
5. Attach this file to your next reply.
Restart the machine.
Run the command sfc /scannow in an elevated commandprompt and report the result.
If it fails, copy the file C:\Windows\Logs\CBS\cbs.log to your desktop.
Great. It looks like this machine hasn't been updated for a long time, approx. 11 years. If your goal is to install IE11 on this machine that might be a problem.
Should we continue fixing or not ?
The software I wanted to use (ForgeUI) still reports a missing dependency of a dll (c10_cuda.dll), and Dependency Walker still tell me that it's "IESHIMS.DLL" missing.
I do not especially want to install Internet Explorer, I just wanted to fix this problem. I expected it to be fixed now but it isn't. Any idea why?
The file IESHIMS.DLL is part of Internet Explorer so you need to have Internet Explorer installed.
Try to install the default Internet Explorer in Windows 7:
  • Go to Control Panel - Programs
  • Click the link Turn Windows features on or off.
  • Put a checkmark at Internet Explorer 11
  • Click OK
Does that install Internet Explorer 11 successful or not ?
It offers me to install Internet Explorer 8. I tried, restarted, but nothing changed.
I installed Internet Explorer 11 and the necessary updates.
I also installed all visual c++ redist from 2005 to 2022.
Six dlls were still missing according to Dependency Walker. I downloaded them from dll-files.com and copied them in windows/system32/. (I don't like to do that) And now it asks for even more dlls...
Should I download all these dlls or is there something wrong?
Don't do that. You'll never know if you have the right one.
Please do following only:
These are the dlls I downloaded. All I found about them was to install visual c++ redist 2015 and an update but both were already installed.
sfc /scannow said it found no problem.
Okay, that is good to start with.
Install following update only.
Install Update with DISM
  1. Download the update MSU here: https://catalog.s.download.windowsu..._0ba5ac38d4e1c9588a1e53ad390d23c1e4ecd04d.msu
    cd C:\temp
    expand windows6.1-kb2533552-x64_0ba5ac38d4e1c9588a1e53ad390d23c1e4ecd04d.msu -f:* C:\temp
    DISM.exe /Online /Add-Package /PackagePath:C:\temp\windows6.1-kb2533552-x64.cab
Please be patient. This was just a first step.
  1. Download the update MSU here: https://catalog.s.download.windowsu..._42467e48b4cfeb44112d819f50b0557d4f9bbb2f.msu
    cd C:\temp
    expand windows6.1-kb3177467-x64_42467e48b4cfeb44112d819f50b0557d4f9bbb2f.msu -f:* C:\temp
    DISM.exe /Online /Add-Package /PackagePath:C:\temp\windows6.1-kb3177467-x64.cab
Next one.
  1. Download the update MSU here: http://download.windowsupdate.com/c..._d3de52d6987f7c8bdc2c015dca69eac96047c76e.msu
    cd C:\temp
    expand windows6.1-kb4490628-x64_d3de52d6987f7c8bdc2c015dca69eac96047c76e.msu -f:* C:\temp
    DISM.exe /Online /Add-Package /PackagePath:C:\temp\windows6.1-kb4490628-x64.cab
