[SOLVED] Problems during updates, very hard to fix!
Manu99
Contributor
So... after some headaches i found this forum. I hope i can find help here and contribute also. Now, the problem:
Winver: Microsoft Windows 10 Pro Build 1809 (17763.292) x64
Device: Surface Pro 2017 i5-256/8 model
Windows Update error: 0x80070002 (attempting to install KB4497934 - last cumulative update)
Error of in-place upgrade: safe_os phase with an error during replicate_oc
So guys. Some day ago i checked windows update and noted that i couldn't do the last upgrade, with the error referenced above. So i decided to wait until May to directly update the whole os, but it didn't work. I used the windows assistant downloadable from here: Scarica Windows 10
So I tryed to do an in-place upgrade with the last windows 10 iso, it didn't work neither. Then i tried to use the same iso version as my system version, to repair my windows installation. Nothing worked, it tries to install but after reboot and does a rollback. I always get the error shown above: "The installation failed in the SAFE_OS phase error during Replicate_OC operation".
Well, i tried sfc /scannow: nothing. I used dism (online, but offline also with a properly install.wim system image): nothing. So finally i tried the SFCFix.exe tool found here: nothing (see attached file).
I would like to not to do a clean install, but seems the only way 🙁. I tried all methods multiple times, so maybe cbs.log is a bit large.
Suggestions?
Hi softwaremaniac! I would try so but the panel of Windows optional features is literally empty and the Powershell command is irresponsive, it doesn't find hyper-v files, so I can't enable or disable it (and also I never enabled it I think). I use an Android emulator also that is a type 2 hypervisor and it works, so hyper-v should be already disabled. I think to have a very corrupted Windows installation and I don't even know why
Italian language pack. Actually on 1803 build it was english (main language) + italian (i downloaded it). After the update (to 1809, the actual build i have) the things changed (because when i updated the system i used an italian build. It worked even if i later found that it should not): italian was main language + english. So i removed english language, but the new update (to 1903) didn't work either. Then I tried to download an english build and update didn't work. So finally I checked in registry the language key and it is the italian language code. The fact is that i could try to modify manually it and then try upgrading with an english build but i'm not sure of doing so. Another thing: whenever i try to install any language packs it fails on downloading speech file, handwrite files, etc
Any though on what the problem could be? It's very strange to me that corruption:unsure:. I've also a wsl distro that actually runs but i can't disable the wsl feature, as hyper-v or any other feature! So sometime ago I also searched for viruses but actually nothing is found by windows defender and by MBAM.
Yes i can see this in logs unfortunately. But how this is even possible. I'm a math student actually and i didn't use this machine to work or make strange things. I hope this is still recoverable, if yes, manage my case after the other that i see are more important than mine. If not tell me, when I've time I'll do a clean installation. I don't want overload your work here!
Hi softwaremaniac! Here the result: as you see, it-it is main language as i said
Strumento Gestione e manutenzione immagini distribuzione
Versione: 10.0.17763.1
Versione immagine: 10.0.17763.292
Creazione rapporto impostazioni internazionali online in corso.
Lingua predefinita dell'interfaccia utente del sistema : it-IT
Fallback della lingua dell'interfaccia utente : en-US
Impostazioni locali del sistema : it-IT
Fuso orario predefinito : W. Europe Standard Time
Tastiere attive : 0410:00000452, 0410:00000410
Driver su più livelli per la tastiera : Non installato.
Lingue installate: en-GB
Tipo: lingua parzialmente localizzata, tipo MUI.
Lingue di fallback: en-US
Lingue installate: en-US
Tipo: lingua completamente localizzata.
Lingue installate: it-IT
Lingue installate: nl-NL
Lingue installate: pl-PL
Lingue installate: pt-PT
Lingue installate: sv-SE
Lingue installate: th-TH
Lingue installate: zh-TW
Operazione completata.
Despite the command, i've only italian installed at the moment:
Thanks.
Thanks! Here the log, waiting for more instructions!
Start time: 2019-07-06 10:38:04.553
Microsoft Windows 10 Build 17763 - amd64
Using .zip script file at C:\Users\Emanuele\Desktop\SFCFix.zip [0]
Successfully took permissions for file or folder C:\WINDOWS\Servicing\Packages
Failed to find any content under directory "C:\Users\Emanuele\AppData\Local\niemiro\Archive\WinSxS" in line ""C:\Users\Emanuele\AppData\Local\niemiro\Archive\WinSxS" C:\WINDOWS\WinSxS [DIR]".
Failed to find any content under directory "C:\Users\Emanuele\AppData\Local\niemiro\Archive\Manifests" in line ""C:\Users\Emanuele\AppData\Local\niemiro\Archive\Manifests" C:\WINDOWS\WinSxS\Manifests [DIR]".
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\HyperV-Compute-Host-onecore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\HyperV-Compute-Host-onecore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\HyperV-Compute-Host-onecore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\HyperV-Compute-Host-onecore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\HyperV-Compute-Host-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\HyperV-Compute-Host-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\HyperV-Compute-Host-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\HyperV-Compute-Host-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\HyperV-Compute-Host-VirtualMachines-onecore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\HyperV-Compute-Host-VirtualMachines-onecore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\HyperV-Compute-Host-VirtualMachines-onecore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\HyperV-Compute-Host-VirtualMachines-onecore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\HyperV-Compute-Host-VirtualMachines-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\HyperV-Compute-Host-VirtualMachines-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\HyperV-Compute-Host-VirtualMachines-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\HyperV-Compute-Host-VirtualMachines-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\HyperV-Compute-System-VmDirect-onecore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\HyperV-Compute-System-VmDirect-onecore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\HyperV-Compute-System-VmDirect-onecore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\HyperV-Compute-System-VmDirect-onecore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\HyperV-Compute-System-VmDirect-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\HyperV-Compute-System-VmDirect-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\HyperV-Compute-System-VmDirect-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\HyperV-Compute-System-VmDirect-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\HyperV-DynamicMemory-VirtualDevice-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\HyperV-DynamicMemory-VirtualDevice-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\HyperV-DynamicMemory-VirtualDevice-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\HyperV-DynamicMemory-VirtualDevice-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\HyperV-Feature-VirtualMachinePlatform-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\HyperV-Feature-VirtualMachinePlatform-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\HyperV-Feature-VirtualMachinePlatform-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\HyperV-Feature-VirtualMachinePlatform-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\HyperV-HvSocket-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\HyperV-HvSocket-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\HyperV-HvSocket-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\HyperV-HvSocket-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\HyperV-Hypervisor-minkernel-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\HyperV-Hypervisor-minkernel-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\HyperV-Hypervisor-minkernel-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\HyperV-Hypervisor-minkernel-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\HyperV-Hypervisor-onecore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\HyperV-Hypervisor-onecore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\HyperV-Hypervisor-onecore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\HyperV-Hypervisor-onecore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\HyperV-Hypervisor-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\HyperV-Hypervisor-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\HyperV-Hypervisor-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\HyperV-Hypervisor-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\HyperV-HypervisorPlatform-onecore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\HyperV-HypervisorPlatform-onecore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\HyperV-HypervisorPlatform-onecore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\HyperV-HypervisorPlatform-onecore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\HyperV-HypervisorPlatform-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\HyperV-HypervisorPlatform-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\HyperV-HypervisorPlatform-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\HyperV-HypervisorPlatform-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\HyperV-IntegrationComponents-VirtualDevice-Core-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\HyperV-IntegrationComponents-VirtualDevice-Core-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\HyperV-IntegrationComponents-VirtualDevice-Core-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\HyperV-IntegrationComponents-VirtualDevice-Core-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\HyperV-KMCL-Host-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\HyperV-KMCL-Host-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\HyperV-KMCL-Host-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\HyperV-KMCL-Host-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\HyperV-Networking-Containers-onecore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\HyperV-Networking-Containers-onecore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\HyperV-Networking-Containers-onecore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\HyperV-Networking-Containers-onecore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\HyperV-Networking-Containers-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\HyperV-Networking-Containers-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\HyperV-Networking-Containers-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\HyperV-Networking-Containers-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\HyperV-Networking-onecore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\HyperV-Networking-onecore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\HyperV-Networking-onecore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\HyperV-Networking-onecore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\HyperV-Networking-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\HyperV-Networking-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\HyperV-Networking-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\HyperV-Networking-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\HyperV-Networking-VirtualDevice-Synthetic-onecore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\HyperV-Networking-VirtualDevice-Synthetic-onecore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\HyperV-Networking-VirtualDevice-Synthetic-onecore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\HyperV-Networking-VirtualDevice-Synthetic-onecore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\HyperV-Networking-VirtualDevice-Synthetic-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\HyperV-Networking-VirtualDevice-Synthetic-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\HyperV-Networking-VirtualDevice-Synthetic-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\HyperV-Networking-VirtualDevice-Synthetic-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\HyperV-Primitive-VirtualMachine-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\HyperV-Primitive-VirtualMachine-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\HyperV-Primitive-VirtualMachine-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\HyperV-Primitive-VirtualMachine-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\HyperV-RDP4VS-onecore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\HyperV-RDP4VS-onecore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\HyperV-RDP4VS-onecore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\HyperV-RDP4VS-onecore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\HyperV-RDP4VS-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\HyperV-RDP4VS-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\HyperV-RDP4VS-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\HyperV-RDP4VS-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\HyperV-Storage-VirtualDevice-SCSI-onecore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\HyperV-Storage-VirtualDevice-SCSI-onecore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\HyperV-Storage-VirtualDevice-SCSI-onecore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\HyperV-Storage-VirtualDevice-SCSI-onecore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\HyperV-Storage-VirtualDevice-SCSI-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\HyperV-Storage-VirtualDevice-SCSI-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\HyperV-Storage-VirtualDevice-SCSI-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\HyperV-Storage-VirtualDevice-SCSI-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\HyperV-Storage-VirtualDevice-SMB-onecore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\HyperV-Storage-VirtualDevice-SMB-onecore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\HyperV-Storage-VirtualDevice-SMB-onecore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\HyperV-Storage-VirtualDevice-SMB-onecore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\HyperV-Storage-VirtualDevice-SMB-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\HyperV-Storage-VirtualDevice-SMB-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\HyperV-Storage-VirtualDevice-SMB-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\HyperV-Storage-VirtualDevice-SMB-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\HyperV-Storage-VSP-onecore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\HyperV-Storage-VSP-onecore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\HyperV-Storage-VSP-onecore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\HyperV-Storage-VSP-onecore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\HyperV-Storage-VSP-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\HyperV-Storage-VSP-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\HyperV-Storage-VSP-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\HyperV-Storage-VSP-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\HyperV-VID-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\HyperV-VID-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\HyperV-VID-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\HyperV-VID-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\HyperV-VmBus-Host-onecore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\HyperV-VmBus-Host-onecore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\HyperV-VmBus-Host-onecore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\HyperV-VmBus-Host-onecore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\HyperV-VmBus-Host-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\HyperV-VmBus-Host-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\HyperV-VmBus-Host-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\HyperV-VmBus-Host-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\HyperV-VmBus-VirtualDevice-onecore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\HyperV-VmBus-VirtualDevice-onecore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\HyperV-VmBus-VirtualDevice-onecore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\HyperV-VmBus-VirtualDevice-onecore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\HyperV-VmBus-VirtualDevice-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\HyperV-VmBus-VirtualDevice-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\HyperV-VmBus-VirtualDevice-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\HyperV-VmBus-VirtualDevice-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\HyperV-VmChipset-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\HyperV-VmChipset-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\HyperV-VmChipset-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\HyperV-VmChipset-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\HyperV-VmSerial-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\HyperV-VmSerial-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\HyperV-VmSerial-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\HyperV-VmSerial-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\HyperV-VmUiDevices-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\HyperV-VmUiDevices-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\HyperV-VmUiDevices-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\HyperV-VmUiDevices-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\HyperV-Vpci-VirtualDevice-FlexIo-onecore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\HyperV-Vpci-VirtualDevice-FlexIo-onecore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\HyperV-Vpci-VirtualDevice-FlexIo-onecore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\HyperV-Vpci-VirtualDevice-FlexIo-onecore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\HyperV-Vpci-VirtualDevice-FlexIo-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\HyperV-Vpci-VirtualDevice-FlexIo-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\HyperV-Vpci-VirtualDevice-FlexIo-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\HyperV-Vpci-VirtualDevice-FlexIo-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\HyperV-Vpci-VirtualDevice-Gpup-onecore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\HyperV-Vpci-VirtualDevice-Gpup-onecore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\HyperV-Vpci-VirtualDevice-Gpup-onecore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\HyperV-Vpci-VirtualDevice-Gpup-onecore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\HyperV-Vpci-VirtualDevice-Gpup-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\HyperV-Vpci-VirtualDevice-Gpup-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\HyperV-Vpci-VirtualDevice-Gpup-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\HyperV-Vpci-VirtualDevice-Gpup-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\HyperV-Vpci-VSP-onecore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\HyperV-Vpci-VSP-onecore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\HyperV-Vpci-VSP-onecore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\HyperV-Vpci-VSP-onecore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\HyperV-Vpci-VSP-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\HyperV-Vpci-VSP-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\HyperV-Vpci-VSP-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\HyperV-Vpci-VSP-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\HyperV-Worker-onecore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\HyperV-Worker-onecore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\HyperV-Worker-onecore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\HyperV-Worker-onecore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\HyperV-Worker-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\HyperV-Worker-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\HyperV-Worker-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\HyperV-Worker-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Hyper-V-Hypervisor-onecore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Hyper-V-Hypervisor-onecore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Hyper-V-Hypervisor-onecore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Hyper-V-Hypervisor-onecore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Hyper-V-Hypervisor-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Hyper-V-Hypervisor-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Hyper-V-Hypervisor-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Hyper-V-Hypervisor-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Media-Foundation-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Media-Foundation-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Media-Foundation-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Media-Foundation-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Media-Foundation-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Media-Foundation-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Media-Foundation-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Media-Foundation-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-OneCore-Containers-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-Containers-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-OneCore-Containers-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-Containers-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-OneCore-IsolatedUserMode-minkernel-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-IsolatedUserMode-minkernel-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-OneCore-IsolatedUserMode-minkernel-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-IsolatedUserMode-minkernel-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-OneCore-IsolatedUserMode-onecore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-IsolatedUserMode-onecore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-OneCore-IsolatedUserMode-onecore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-IsolatedUserMode-onecore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-OneCore-IsolatedUserMode-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-IsolatedUserMode-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-OneCore-IsolatedUserMode-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-IsolatedUserMode-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-OneCore-Multimedia-CastingCommon-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-Multimedia-CastingCommon-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-OneCore-Multimedia-CastingCommon-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-Multimedia-CastingCommon-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-OneCore-Multimedia-CastingCommon-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-Multimedia-CastingCommon-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-OneCore-Multimedia-CastingCommon-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-Multimedia-CastingCommon-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-OneCore-Multimedia-CastingReceiver-Media-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-Multimedia-CastingReceiver-Media-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-OneCore-Multimedia-CastingReceiver-Media-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-Multimedia-CastingReceiver-Media-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-OneCore-Multimedia-CastingReceiver-Media-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-Multimedia-CastingReceiver-Media-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-OneCore-Multimedia-CastingReceiver-Media-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-Multimedia-CastingReceiver-Media-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-OneCore-Multimedia-CastingTransmitter-Media-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-Multimedia-CastingTransmitter-Media-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-OneCore-Multimedia-CastingTransmitter-Media-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-Multimedia-CastingTransmitter-Media-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-OneCore-Multimedia-MFPMP-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-Multimedia-MFPMP-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-OneCore-Multimedia-MFPMP-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-Multimedia-MFPMP-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-OneCore-Multimedia-MFPMP-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-Multimedia-MFPMP-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-OneCore-Multimedia-MFPMP-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-Multimedia-MFPMP-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-OneCore-VirtualizationBasedSecurity-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-VirtualizationBasedSecurity-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-OneCore-VirtualizationBasedSecurity-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-OneCore-VirtualizationBasedSecurity-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Shielded-VM-Service-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Shielded-VM-Service-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Shielded-VM-Service-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Shielded-VM-Service-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Client-Features-Package0010~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Client-Features-Package0010~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Client-Features-Package0010~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Client-Features-Package0010~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Client-Features-Package0011~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Client-Features-Package0011~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Client-Features-Package0011~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Client-Features-Package0011~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Client-Features-Package00~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Client-Features-Package00~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Client-Features-Package00~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Client-Features-Package00~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Client-Features-Package01~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Client-Features-Package01~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Client-Features-Package01~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Client-Features-Package01~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Client-Features-Package02~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Client-Features-Package02~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Client-Features-Package02~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Client-Features-Package02~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Client-Features-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Client-Features-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Client-Features-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Client-Features-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Client-Features-WOW64-Package00~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Client-Features-WOW64-Package00~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Client-Features-WOW64-Package00~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Client-Features-WOW64-Package00~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Client-Features-WOW64-Package01~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Client-Features-WOW64-Package01~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Client-Features-WOW64-Package01~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Client-Features-WOW64-Package01~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Client-Features-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Client-Features-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Client-Features-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Client-Features-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Client-LanguagePack-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Client-LanguagePack-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Client-LanguagePack-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Client-LanguagePack-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Client-Optional-Features-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Client-Optional-Features-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Client-Optional-Features-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Client-Optional-Features-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Common-Foundation-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Foundation-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Common-Foundation-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Common-Foundation-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-DirectPlay-OC-Opt-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-DirectPlay-OC-Opt-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-DirectPlay-OC-Opt-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-DirectPlay-OC-Opt-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-DirectPlay-OC-Opt-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-DirectPlay-OC-Opt-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-DirectPlay-OC-Opt-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-DirectPlay-OC-Opt-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-DirectPlay-OC-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-DirectPlay-OC-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-DirectPlay-OC-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-DirectPlay-OC-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-DirectPlay-OC-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-DirectPlay-OC-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-DirectPlay-OC-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-DirectPlay-OC-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Editions-Professional-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Editions-Professional-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Editions-Professional-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Editions-Professional-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Fax-Client-Feature-Opt-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Fax-Client-Feature-Opt-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Fax-Client-Feature-Opt-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Fax-Client-Feature-Opt-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-GroupPolicy-ClientTools-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-GroupPolicy-ClientTools-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-GroupPolicy-ClientTools-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-GroupPolicy-ClientTools-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-GroupPolicy-ClientTools-termsrv-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-GroupPolicy-ClientTools-termsrv-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-GroupPolicy-ClientTools-termsrv-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-GroupPolicy-ClientTools-termsrv-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-GroupPolicy-ClientTools-windows-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-GroupPolicy-ClientTools-windows-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-GroupPolicy-ClientTools-windows-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-GroupPolicy-ClientTools-windows-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Help-ClientUA-Enterprise-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Help-ClientUA-Enterprise-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Help-ClientUA-Enterprise-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Help-ClientUA-Enterprise-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Host-Guardian-Deployment-mergedcomponents-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Host-Guardian-Deployment-mergedcomponents-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Host-Guardian-Deployment-mergedcomponents-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Host-Guardian-Deployment-mergedcomponents-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Host-Guardian-Deployment-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Host-Guardian-Deployment-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Host-Guardian-Deployment-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Host-Guardian-Deployment-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Host-Guardian-Deployment-servercommon-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Host-Guardian-Deployment-servercommon-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Host-Guardian-Deployment-servercommon-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Host-Guardian-Deployment-servercommon-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-HyperV-OptionalFeature-HypervisorPlatform-Disabled-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-HyperV-OptionalFeature-HypervisorPlatform-Disabled-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-HyperV-OptionalFeature-HypervisorPlatform-Disabled-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-HyperV-OptionalFeature-HypervisorPlatform-Disabled-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-HyperV-OptionalFeature-HypervisorPlatform-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-HyperV-OptionalFeature-HypervisorPlatform-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-HyperV-OptionalFeature-HypervisorPlatform-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-HyperV-OptionalFeature-HypervisorPlatform-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-HyperV-OptionalFeature-VirtualMachinePlatform-Disabled-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-HyperV-OptionalFeature-VirtualMachinePlatform-Disabled-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-HyperV-OptionalFeature-VirtualMachinePlatform-Disabled-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-HyperV-OptionalFeature-VirtualMachinePlatform-Disabled-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-HyperV-OptionalFeature-VirtualMachinePlatform-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-HyperV-OptionalFeature-VirtualMachinePlatform-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-HyperV-OptionalFeature-VirtualMachinePlatform-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-HyperV-OptionalFeature-VirtualMachinePlatform-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Identity-Foundation-Opt-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Identity-Foundation-Opt-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Identity-Foundation-Opt-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Identity-Foundation-Opt-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Identity-Foundation-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Identity-Foundation-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Identity-Foundation-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Identity-Foundation-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-IIS-WebServer-AddOn-2-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-IIS-WebServer-AddOn-2-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-IIS-WebServer-AddOn-2-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-IIS-WebServer-AddOn-2-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-IIS-WebServer-AddOn-2-ServerCommon-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-IIS-WebServer-AddOn-2-ServerCommon-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-IIS-WebServer-AddOn-2-ServerCommon-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-IIS-WebServer-AddOn-2-ServerCommon-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-IIS-WebServer-AddOn-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-IIS-WebServer-AddOn-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-IIS-WebServer-AddOn-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-IIS-WebServer-AddOn-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-IIS-WebServer-AddOn-ServerCommon-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-IIS-WebServer-AddOn-ServerCommon-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-IIS-WebServer-AddOn-ServerCommon-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-IIS-WebServer-AddOn-ServerCommon-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-IIS-WebServer-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-IIS-WebServer-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-IIS-WebServer-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-IIS-WebServer-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-IIS-WebServer-ServerCommon-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-IIS-WebServer-ServerCommon-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-IIS-WebServer-ServerCommon-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-IIS-WebServer-ServerCommon-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Legacy-Components-OC-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Legacy-Components-OC-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Legacy-Components-OC-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Legacy-Components-OC-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Legacy-Components-OC-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Legacy-Components-OC-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Legacy-Components-OC-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Legacy-Components-OC-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Lxss-onecore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Lxss-onecore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Lxss-onecore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Lxss-onecore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Lxss-Optional-onecore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Lxss-Optional-onecore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Lxss-Optional-onecore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Lxss-Optional-onecore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Lxss-Optional-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Lxss-Optional-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Lxss-Optional-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Lxss-Optional-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Lxss-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Lxss-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Lxss-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Lxss-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Media-Format-multimedia-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Media-Format-multimedia-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Media-Format-multimedia-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Media-Format-multimedia-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Media-Format-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Media-Format-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Media-Format-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Media-Format-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Media-Format-windows-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Media-Format-windows-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Media-Format-windows-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Media-Format-windows-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Media-Format-WOW64-multimedia-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Media-Format-WOW64-multimedia-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Media-Format-WOW64-multimedia-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Media-Format-WOW64-multimedia-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Media-Format-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Media-Format-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Media-Format-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Media-Format-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Media-Format-WOW64-windows-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Media-Format-WOW64-windows-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Media-Format-WOW64-windows-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Media-Format-WOW64-windows-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Media-Streaming-avcore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Media-Streaming-avcore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Media-Streaming-avcore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Media-Streaming-avcore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Media-Streaming-multimedia-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Media-Streaming-multimedia-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Media-Streaming-multimedia-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Media-Streaming-multimedia-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Media-Streaming-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Media-Streaming-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Media-Streaming-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Media-Streaming-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Media-Streaming-windows-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Media-Streaming-windows-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Media-Streaming-windows-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Media-Streaming-windows-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Media-Streaming-WOW64-avcore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Media-Streaming-WOW64-avcore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Media-Streaming-WOW64-avcore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Media-Streaming-WOW64-avcore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Media-Streaming-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Media-Streaming-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Media-Streaming-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Media-Streaming-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Media-Streaming-WOW64-windows-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Media-Streaming-WOW64-windows-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Media-Streaming-WOW64-windows-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Media-Streaming-WOW64-windows-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-MediaPlayback-OC-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-MediaPlayback-OC-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-MediaPlayback-OC-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-MediaPlayback-OC-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-MediaPlayer-Payload-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-MediaPlayer-Payload-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-MediaPlayer-Payload-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-MediaPlayer-Payload-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-MobilePC-Client-Premium-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-MobilePC-Client-Premium-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-MobilePC-Client-Premium-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-MobilePC-Client-Premium-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-MSMQ-Client-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-MSMQ-Client-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-MSMQ-Client-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-MSMQ-Client-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Multimedia-MF-avcore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Multimedia-MF-avcore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Multimedia-MF-avcore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Multimedia-MF-avcore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Multimedia-MF-multimedia-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Multimedia-MF-multimedia-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Multimedia-MF-multimedia-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Multimedia-MF-multimedia-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Multimedia-MF-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Multimedia-MF-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Multimedia-MF-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Multimedia-MF-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Multimedia-MF-WOW64-avcore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Multimedia-MF-WOW64-avcore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Multimedia-MF-WOW64-avcore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Multimedia-MF-WOW64-avcore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Multimedia-MF-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Multimedia-MF-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Multimedia-MF-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Multimedia-MF-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Multimedia-RestrictedCodecs-avcore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Multimedia-RestrictedCodecs-avcore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Multimedia-RestrictedCodecs-avcore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Multimedia-RestrictedCodecs-avcore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Multimedia-RestrictedCodecs-multimedia-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Multimedia-RestrictedCodecs-multimedia-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Multimedia-RestrictedCodecs-multimedia-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Multimedia-RestrictedCodecs-multimedia-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Multimedia-RestrictedCodecs-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Multimedia-RestrictedCodecs-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Multimedia-RestrictedCodecs-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Multimedia-RestrictedCodecs-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Multimedia-RestrictedCodecs-WOW64-avcore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Multimedia-RestrictedCodecs-WOW64-avcore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Multimedia-RestrictedCodecs-WOW64-avcore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Multimedia-RestrictedCodecs-WOW64-avcore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Multimedia-RestrictedCodecs-WOW64-multimedia-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Multimedia-RestrictedCodecs-WOW64-multimedia-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Multimedia-RestrictedCodecs-WOW64-multimedia-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Multimedia-RestrictedCodecs-WOW64-multimedia-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Multimedia-RestrictedCodecs-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Multimedia-RestrictedCodecs-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Multimedia-RestrictedCodecs-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Multimedia-RestrictedCodecs-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-MultiPoint-Connector-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-MultiPoint-Connector-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-MultiPoint-Connector-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-MultiPoint-Connector-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-NetFx-Shared-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-NetFx-Shared-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-NetFx-Shared-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-NetFx-Shared-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-NetFx-Shared-WPF-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-NetFx-Shared-WPF-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-NetFx-Shared-WPF-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-NetFx-Shared-WPF-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-NetFx2-OC-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-NetFx2-OC-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-NetFx2-OC-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-NetFx2-OC-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-NetFx3-OC-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-NetFx3-OC-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-NetFx3-OC-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-NetFx3-OC-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-NetFx3-OnDemand-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-NetFx3-OnDemand-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-NetFx3-OnDemand-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-NetFx3-OnDemand-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-NetFx3-WCF-OC-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-NetFx3-WCF-OC-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-NetFx3-WCF-OC-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-NetFx3-WCF-OC-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-NetFx4-US-OC-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-NetFx4-US-OC-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-NetFx4-US-OC-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-NetFx4-US-OC-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-NetFx4-WCF-US-OC-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-NetFx4-WCF-US-OC-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-NetFx4-WCF-US-OC-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-NetFx4-WCF-US-OC-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-NFS-ClientSKU-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-NFS-ClientSKU-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-NFS-ClientSKU-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-NFS-ClientSKU-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-PAW-Feature-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-PAW-Feature-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-PAW-Feature-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-PAW-Feature-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-PAW-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-PAW-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-PAW-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-PAW-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-PAW-servercommon-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-PAW-servercommon-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-PAW-servercommon-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-PAW-servercommon-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-PhotoBasic-Feature-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-PhotoBasic-Feature-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-PhotoBasic-Feature-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-PhotoBasic-Feature-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-PhotoBasic-Feature-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-PhotoBasic-Feature-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-PhotoBasic-Feature-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-PhotoBasic-Feature-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-PhotoBasic-multimedia-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-PhotoBasic-multimedia-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-PhotoBasic-multimedia-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-PhotoBasic-multimedia-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-PhotoBasic-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-PhotoBasic-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-PhotoBasic-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-PhotoBasic-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-PhotoBasic-PictureTools-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-PhotoBasic-PictureTools-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-PhotoBasic-PictureTools-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-PhotoBasic-PictureTools-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-PhotoBasic-PictureTools-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-PhotoBasic-PictureTools-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-PhotoBasic-PictureTools-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-PhotoBasic-PictureTools-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-PhotoBasic-WOW64-multimedia-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-PhotoBasic-WOW64-multimedia-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-PhotoBasic-WOW64-multimedia-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-PhotoBasic-WOW64-multimedia-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-PhotoBasic-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-PhotoBasic-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-PhotoBasic-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-PhotoBasic-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Portable-Devices-multimedia-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Portable-Devices-multimedia-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Portable-Devices-multimedia-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Portable-Devices-multimedia-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Portable-Devices-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Portable-Devices-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Portable-Devices-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Portable-Devices-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Portable-Devices-windows-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Portable-Devices-windows-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Portable-Devices-windows-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Portable-Devices-windows-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Portable-Devices-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Portable-Devices-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Portable-Devices-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Portable-Devices-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Portable-Devices-WOW64-windows-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Portable-Devices-WOW64-windows-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Portable-Devices-WOW64-windows-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Portable-Devices-WOW64-windows-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-PowerShell-V2-Client-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-PowerShell-V2-Client-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-PowerShell-V2-Client-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-PowerShell-V2-Client-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Presentation-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Presentation-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Presentation-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Presentation-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Printing-Foundation-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Printing-Foundation-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Printing-Foundation-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Printing-Foundation-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Printing-InternetPrinting-Client-Opt-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Printing-InternetPrinting-Client-Opt-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Printing-InternetPrinting-Client-Opt-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Printing-InternetPrinting-Client-Opt-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Printing-LPDPrintService-Opt-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Printing-LPDPrintService-Opt-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Printing-LPDPrintService-Opt-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Printing-LPDPrintService-Opt-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Printing-LPRPortMonitor-Opt-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Printing-LPRPortMonitor-Opt-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Printing-LPRPortMonitor-Opt-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Printing-LPRPortMonitor-Opt-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Printing-PrintToPDF-Opt-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Printing-PrintToPDF-Opt-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Printing-PrintToPDF-Opt-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Printing-PrintToPDF-Opt-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Printing-PrintToPDFServices-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Printing-PrintToPDFServices-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Printing-PrintToPDFServices-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Printing-PrintToPDFServices-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Printing-XpsDocumentWriter-Opt-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Printing-XpsDocumentWriter-Opt-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Printing-XpsDocumentWriter-Opt-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Printing-XpsDocumentWriter-Opt-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Printing-XPSServices-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Printing-XPSServices-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-Printing-XPSServices-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-Printing-XPSServices-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-RemoteAssistance-Package-Client~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-RemoteAssistance-Package-Client~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-RemoteAssistance-Package-Client~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-RemoteAssistance-Package-Client~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-SecConfig-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-SecConfig-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-SecConfig-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-SecConfig-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-SecureStartup-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-SecureStartup-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-SecureStartup-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-SecureStartup-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-SecureStartup-Subsystem-base-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-SecureStartup-Subsystem-base-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-SecureStartup-Subsystem-base-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-SecureStartup-Subsystem-base-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-SecureStartup-Subsystem-onecore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-SecureStartup-Subsystem-onecore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-SecureStartup-Subsystem-onecore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-SecureStartup-Subsystem-onecore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-SecureStartup-Subsystem-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-SecureStartup-Subsystem-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-SecureStartup-Subsystem-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-SecureStartup-Subsystem-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-SecureStartup-Subsystem-WOW64-base-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-SecureStartup-Subsystem-WOW64-base-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-SecureStartup-Subsystem-WOW64-base-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-SecureStartup-Subsystem-WOW64-base-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-SecureStartup-Subsystem-WOW64-onecore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-SecureStartup-Subsystem-WOW64-onecore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-SecureStartup-Subsystem-WOW64-onecore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-SecureStartup-Subsystem-WOW64-onecore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-SecureStartup-Subsystem-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-SecureStartup-Subsystem-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-SecureStartup-Subsystem-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-SecureStartup-Subsystem-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-ServicingStack-Base-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Base-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-ServicingStack-Base-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-ServicingStack-Base-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-SimpleTCP-Opt-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-SimpleTCP-Opt-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-SimpleTCP-Opt-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-SimpleTCP-Opt-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-SimpleTCP-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-SimpleTCP-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-SimpleTCP-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-SimpleTCP-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-TerminalServices-CommandLineTools-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-TerminalServices-CommandLineTools-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-TerminalServices-CommandLineTools-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-TerminalServices-CommandLineTools-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-TerminalServices-Publishing-WMIProvider-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-TerminalServices-Publishing-WMIProvider-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-TerminalServices-Publishing-WMIProvider-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-TerminalServices-Publishing-WMIProvider-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-TerminalServices-RemoteApplications-Client-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-TerminalServices-RemoteApplications-Client-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-TerminalServices-RemoteApplications-Client-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-TerminalServices-RemoteApplications-Client-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-TerminalServices-UsbRedirector-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-TerminalServices-UsbRedirector-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-TerminalServices-UsbRedirector-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-TerminalServices-UsbRedirector-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-TerminalServices-WMIProvider-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-TerminalServices-WMIProvider-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-TerminalServices-WMIProvider-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-TerminalServices-WMIProvider-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-WebcamExperience-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-WebcamExperience-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-WebcamExperience-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-WebcamExperience-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-WebcamExperience-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-WebcamExperience-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-WebcamExperience-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-WebcamExperience-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-WindowsMediaPlayer-Troubleshooters-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-WindowsMediaPlayer-Troubleshooters-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-WindowsMediaPlayer-Troubleshooters-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-WindowsMediaPlayer-Troubleshooters-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-WMPNetworkSharingService-Opt-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-WMPNetworkSharingService-Opt-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-WMPNetworkSharingService-Opt-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-WMPNetworkSharingService-Opt-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-WMPNetworkSharingService-Opt-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-WMPNetworkSharingService-Opt-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-WMPNetworkSharingService-Opt-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-WMPNetworkSharingService-Opt-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-WMPNetworkSharingService-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-WMPNetworkSharingService-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-WMPNetworkSharingService-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-WMPNetworkSharingService-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-WMPNetworkSharingService-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-WMPNetworkSharingService-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-WMPNetworkSharingService-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-WMPNetworkSharingService-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-WPD-LegacyWmdmFeature-Feature-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-WPD-LegacyWmdmFeature-Feature-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-WPD-LegacyWmdmFeature-Feature-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-WPD-LegacyWmdmFeature-Feature-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-WPD-LegacyWmdmFeature-Feature-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-WPD-LegacyWmdmFeature-Feature-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-WPD-LegacyWmdmFeature-Feature-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-WPD-LegacyWmdmFeature-Feature-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-WPD-UltimatePortableDeviceFeature-Feature-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-WPD-UltimatePortableDeviceFeature-Feature-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-WPD-UltimatePortableDeviceFeature-Feature-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-WPD-UltimatePortableDeviceFeature-Feature-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-WPD-UltimatePortableDeviceFeature-Feature-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-WPD-UltimatePortableDeviceFeature-Feature-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Microsoft-Windows-WPD-UltimatePortableDeviceFeature-Feature-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Microsoft-Windows-WPD-UltimatePortableDeviceFeature-Feature-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Multimedia-MFCore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Multimedia-MFCore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Multimedia-MFCore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Multimedia-MFCore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Multimedia-MFCore-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Multimedia-MFCore-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Multimedia-MFCore-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Multimedia-MFCore-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Multimedia-RestrictedCodecsCore-Full-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Multimedia-RestrictedCodecsCore-Full-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Multimedia-RestrictedCodecsCore-Full-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Multimedia-RestrictedCodecsCore-Full-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Multimedia-RestrictedCodecsCore-Full-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Multimedia-RestrictedCodecsCore-Full-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Multimedia-RestrictedCodecsCore-Full-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Multimedia-RestrictedCodecsCore-Full-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Multimedia-RestrictedCodecsCore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Multimedia-RestrictedCodecsCore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Multimedia-RestrictedCodecsCore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Multimedia-RestrictedCodecsCore-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Multimedia-RestrictedCodecsCore-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Multimedia-RestrictedCodecsCore-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Multimedia-RestrictedCodecsCore-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Multimedia-RestrictedCodecsCore-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Multimedia-RestrictedCodecsExt-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Multimedia-RestrictedCodecsExt-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Multimedia-RestrictedCodecsExt-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Multimedia-RestrictedCodecsExt-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Multimedia-RestrictedCodecsExt-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Multimedia-RestrictedCodecsExt-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Multimedia-RestrictedCodecsExt-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Multimedia-RestrictedCodecsExt-WOW64-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\MultiPoint-Help-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\MultiPoint-Help-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\MultiPoint-Help-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\MultiPoint-Help-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\RemoteDesktopServices-Base-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\RemoteDesktopServices-Base-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\RemoteDesktopServices-Base-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\RemoteDesktopServices-Base-Package~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Server-Help-Package.ClientEnterprise~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat to C:\WINDOWS\Servicing\Packages\Server-Help-Package.ClientEnterprise~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.cat.
Successfully copied file C:\Users\Emanuele\AppData\Local\niemiro\Archive\Packages\Server-Help-Package.ClientEnterprise~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum to C:\WINDOWS\Servicing\Packages\Server-Help-Package.ClientEnterprise~31bf3856ad364e35~amd64~nb-NO~10.0.17763.1.mum.
Successfully restored ownership for C:\WINDOWS\Servicing\Packages
Successfully restored permissions on C:\WINDOWS\Servicing\Packages
Finish time: 2019-07-06 10:38:39.393
Script hash: 7YXrTNQyxvPqp8uTQAlNwYxM7QRAAj/Z4BfFLrpmmYo=
wooops little error CBS.log, however all went good, i'll update to 1903 now. I'll sure donate something to sysnative and thanks for your great support :)
Hey man I've updated to 1903, from WU it didn't work initially so I've done it manually from the media creation tool and everything is ok now (y). Thanks again!
