Problem with wifes notebook ;-)
frankhaas
hi, i have problems to update my wifes notebook for months :cool:
i tried sfc /scannow and dism ... (for more times) - but it ended with dism error 126.
i have the same error with another notebook, but this will be another thread.
THX for your help!
Hello frankhaas :-)
Thank you for your patience as we work through the various threads. We are all volunteers and work in our spare time.
Please can you zip up the complete CBS folder as instructed in step 4 of the posting instructions.
Thanks!
thx so much! i'm patient, but i really thought, it might be not to solve.
in the cbs-log-folder is just the cbs.log file. nothing else. (cbs.zip in post1).
if you need more - please tell me.
Do you have a cleaner program which is deleting log files? I would have expected more files with history going back further in time.
Please try and repeat the steps to rerun SFC and DISM in the posting instructions and then resubmit a new CBS folder.
maybe i cleaned the log directory when i started with this thread. i repeated the steps with sfc and dism (dism had error 126) - i zipped the whole log-directory (with cbs and dism and windows update ...)
thx for your help - and take as much time as you need. i'm not in hurry.
Hello frankhaas,
I've looked through the logs and can see that there are a number of files that could not be repaired.
2022-11-09 13:41:51, Info                  CSI    00000238 [SR] Cannot repair member file [l:21]'MusNotificationUx.exe' of Microsoft-Windows-Update-MusNotificationUxExe, version 10.0.18362.1411, arch amd64, nonSxS, pkt {l:8 b:31bf3856ad364e35} in the store, file cannot be checked
2022-11-09 13:41:51, Info                  CSI    00000239 [SR] Cannot repair member file [l:19]'MusNotification.exe' of Microsoft-Windows-Update-MusNotificationBroker, version 10.0.18362.1411, arch amd64, nonSxS, pkt {l:8 b:31bf3856ad364e35} in the store, file cannot be checked
2022-11-09 13:41:51, Info                  CSI    0000023a [SR] Cannot repair member file [l:13]'UsoClient.exe' of Microsoft-Windows-Update-UsoClient, version 10.0.18362.1411, arch amd64, nonSxS, pkt {l:8 b:31bf3856ad364e35} in the store, file cannot be checked
2022-11-09 13:41:51, Info                  CSI    0000023b [SR] Cannot repair member file [l:18]'WaaSAssessment.dll' of Microsoft-Windows-WaaSAssessment, version 10.0.18362.1411, arch amd64, nonSxS, pkt {l:8 b:31bf3856ad364e35} in the store, file cannot be checked
2022-11-09 13:41:51, Info                  CSI    0000023c [SR] Cannot repair member file [l:16]'WaaSMedicSvc.dll' of Microsoft-Windows-WaaSMedic, version 10.0.18362.1350, arch amd64, nonSxS, pkt {l:8 b:31bf3856ad364e35} in the store, file cannot be checked
2022-11-09 13:41:51, Info                  CSI    0000023d [SR] Cannot repair member file [l:15]'WaaSMedicPS.dll' of Microsoft-Windows-WaaSMedic, version 10.0.18362.1350, arch amd64, nonSxS, pkt {l:8 b:31bf3856ad364e35} in the store, file cannot be checked
2022-11-09 13:41:51, Info                  CSI    0000023e [SR] Cannot repair member file [l:13]'SIHClient.exe' of ServiceInitiatedHealing-Client, version 10.0.18362.1440, arch amd64, nonSxS, pkt {l:8 b:31bf3856ad364e35} in the store, file cannot be checked
2022-11-09 13:41:51, Info                  CSI    0000023f [SR] Cannot repair member file [l:21]'MusNotificationUx.exe' of Microsoft-Windows-Update-MusNotificationUxExe, version 10.0.18362.1411, arch amd64, nonSxS, pkt {l:8 b:31bf3856ad364e35} in the store, file cannot be checked
I have created a fix for these which you can apply by following the steps below:
  8. Attach the contents of this file into your next post for me to analyse please.
Afterwards please rerun steps 1, 2 and 4 from the posting instructions.
That SFCFix.txt file does not show the expected result. Did you drag the zip file over the exe file as instructed in step 5?
Please repeat the instructions in post #7
Thanks
uaaa - i'm such a fool - i upped the wrong log-file ... sorry for that. (a log when i started sfcfix.exe without script-file)
the right one attached. thanks for your patience with me.
Please run DISM again with Process Monitor running.
2. Run the DISM command.
3. Stop Process Monitor as soon as it fails. You can simply do this by clicking the square (CTRL +E) on the toolbar as shown below.
5. Zip up the LogFile.PML and upload it to WeTransfer - Send Large Files & Share Photos Online - Up to 2GB Free and provide the link.
Which of the following messages do you see after running DISM?
Error: 126 The driver store for the image could not be opened.
Error: 126 The specified module could not be found.
Please do the following to check a file.
The last script was only a file scan.
Open an elevated commandprompt and run the following commands. Copy and paste the result in your next post.
certutil -hashfile "%systemroot%\WinSxS\amd64_microsoft-windows-d..ing-management-core_31bf3856ad364e35_10.0.18362.1316_none_38cd7dd38da2984c\DismProv.dll" SHA256
certutil -hashfile "%systemroot%\System32\Dism\DismProv.dll" SHA256
C:\WINDOWS\system32>certutil -hashfile "%systemroot%\WinSxS\amd64_microsoft-windows-d..ing-management-core_31bf3856ad364e35_10.0.18362.1316_none_38cd7dd38da2984c\DismProv.dll" SHA256
SHA256-Hash von C:\WINDOWS\WinSxS\amd64_microsoft-windows-d..ing-management-core_31bf3856ad364e35_10.0.18362.1316_none_38cd7dd38da2984c\DismProv.dll:
53adc268be41f3f779a4e7776deb72d7b464eff40e2f76dd0cdc4c2f38033bfb
CertUtil: -hashfile-Befehl wurde erfolgreich ausgeführt.
C:\WINDOWS\system32>certutil -hashfile "%systemroot%\System32\Dism\DismProv.dll" SHA256
SHA256-Hash von C:\WINDOWS\System32\Dism\DismProv.dll:
Open an elevated command prompt and run the following command. Attach Dirlist.txt to your next post.
dir /s /a %systemroot%\System32\Dism > "%userprofile%\Desktop\Dirlist.txt"
