[SOLVED] Problem with Update kb4467107
toddehb
the above mentioned update is giving me a very hard time. I is delivered via WSUS to on DC with 2008 R2. I tried everything possible to get it installed, from resetting Windows Update Components to manually downloading it. Nothing changed the situation. The error code is 8007371. In cbs.log I found this
Failed to pin deployment while resolving Update: 4074598-453_neutral_LDR from file: (null) [HRESULT = 0x80073701 - ERROR_SXS_ASSEMBLY_MISSING]
Then I tried to uninstall update kb4074598 as found from cbs entry, but "wusa /uninstall /kb:4074598" says, this update is not installed. Even installing it does not work, because it says that this update is not applicable. Digging further around I found a post in this forum indicating to use FRST64 to scan the registry. I did that und got a "search.txt", but actually this does not help me really, because there are so many entries and I don't know which fix to apply.
Does anybody can help me out with this? Thanks
Regards, toddehb
Hello and welcome!
Step#1 - FRST Fix
