Hello. Try to get help from you. I have dell power edge r720, with two Xeon E5-2630v2 and 32 RAM and some ssd/hdd raid. OS Windows Server 2012 R2 Standard. The problem is that the network adapter is very slow. In the global network speed test I have 15-30Mbps. Local speed have same problems. Large data packets are installed from the server, which greatly slows down the process. I tried to put a clean system on the same hardware and there was no such problem. But there is software that I cannot reinstall at the moment, so I want to fix the system, and not reinstall it.
tried DISM.exe /Online /Cleanup-image /Restorehealth
Maybe someone can point me in the right direction...
Just in case:
Start time: 2023-04-10 09:06:12.686
Microsoft Windows Server 2012 R2 Update 3 - amd64
Finish time: 2023-04-10 09:07:54.089
