Problem with DirectX (i guess)
zenithilia
Since 3 days, I can only launch very few games, the rest, when I start these games, I get this error message:
Failed to initialize Direct3D.
Make sure you have at least DirectX 9.0c installed, have drivers for your graphics card and have not disabled 3D acceleration in display settings.
InitializeEngineGraphics failed
And I also have the error code "887a0004, 0" with Wallpaper Engine
I updated my graphics drivers but nothing is done about it, and I have DirectX 12, with 3D acceleration enabled... Is there any way to fix this?
Hi!
SFC Scan
