Hi, i bought new laptop 3 months ago and until then i am fighting with audio dropouts when audio goes through usb audio interface Yamaha mw8cx. So, when audio is reproduced through laptop speaker everything is normal. I also tried different usb audio interface, steinberg ur22 and the dropouts still occurs. It happens no matter if audio is from youtube or my collection. I updated a lot of drivers, adjusted power options,etc. Dropouts are not freaquent, they come every ten minutes(sometimes longer, sometimes shorter).Also intersting is that when i connect my usb audio interface and dont install appropriate drivers, windows has some automatic drivers and i dont have dropouts but then i cant find my usb audio interface in DAW (music production)
My laptop is HP 470 G3- intel core i5-6200U 2.3 GHz, 8 gb ram, windows 7 professional (service pack 1)
So here is my latencymon check run for 30 minutes. I didnt updated my BIOS. I hope we will find solution to my problems! Cheers!
CONCLUSION
LatencyMon has been analyzing your system for 0:30:57 (h:mm:ss) on all processors.
SYSTEM INFORMATION
Computer name: JENA-HP
Hardware: HP ProBook 470 G3, HP, 8102
CPU: GenuineIntel Intel(R) Core(TM) i5-6200U CPU @ 2.30GHz
Logical processors: 4
Processor groups: 1
RAM: 8088 MB total
CPU SPEED
Reported CPU speed: 240 MHz
Highest measured interrupt to process latency (µs): 6804,712018
Average measured interrupt to process latency (µs): 3,610990
Highest measured interrupt to DPC latency (µs): 1184,745158
Average measured interrupt to DPC latency (µs): 0,893192
REPORTED ISRs
Highest ISR routine execution time (µs): 129,949167
Driver with highest ISR routine execution time: ACPI.sys - ACPI Driver for NT, Microsoft Corporation
Highest reported total ISR routine time (%): 0,057577
Driver with highest ISR total time: hal.dll - Hardware Abstraction Layer DLL, Microsoft Corporation
Total time spent in ISRs (%) 0,061740
ISR count (execution time <250 µs): 3740859
REPORTED DPCs
Highest DPC routine execution time (µs): 1988,303333
Driver with highest DPC routine execution time: ndis.sys - NDIS 6.20 driver, Microsoft Corporation
Highest reported total DPC routine time (%): 0,561444
Driver with highest DPC total execution time: iusb3xhc.sys - Intel(R) USB 3.0 eXtensible Host Controller Driver, Intel Corporation
Total time spent in DPCs (%) 1,058517
DPC count (execution time <250 µs): 18398703
DPC count (execution time 500-999 µs): 2203
DPC count (execution time 1000-1999 µs): 26
REPORTED HARD PAGEFAULTS
Process with highest pagefault count: avastsvc.exe
Total number of hard pagefaults 7749
Hard pagefault count of hardest hit process: 4491
Highest hard pagefault resolution time (µs): 500128,383333
Total time spent in hard pagefaults (%): 0,168840
Number of processes hit: 24
PER CPU DATA
CPU 0 Interrupt cycle time (s): 62,189731
CPU 0 ISR highest execution time (µs): 129,949167
CPU 0 ISR total execution time (s): 4,372851
CPU 0 ISR count: 3721033
CPU 0 DPC highest execution time (µs): 1988,303333
CPU 0 DPC total execution time (s): 34,343080
CPU 0 DPC count: 14564113
CPU 1 Interrupt cycle time (s): 79,638298
CPU 1 ISR highest execution time (µs): 128,604167
CPU 1 ISR total execution time (s): 0,214925
CPU 1 ISR count: 19826
CPU 1 DPC highest execution time (µs): 1040,931667
CPU 1 DPC total execution time (s): 42,646421
CPU 1 DPC count: 3485525
CPU 2 Interrupt cycle time (s): 14,167432
CPU 2 ISR count: 0
CPU 2 DPC highest execution time (µs): 528,6950
CPU 2 DPC total execution time (s): 0,557264
CPU 2 DPC count: 117429
CPU 3 Interrupt cycle time (s): 12,713152
CPU 3 ISR count: 0
CPU 3 DPC highest execution time (µs): 448,378333
CPU 3 DPC total execution time (s): 1,109778
CPU 3 DPC count: 233865
CONCLUSION
SYSTEM INFORMATION
Processor groups: 1
RAM: 8088 MB total
CPU SPEED
REPORTED ISRs
REPORTED DPCs
PER CPU DATA
CPU 2 ISR count: 0
CPU 3 ISR count: 0
