Problem installing Windowws 7 SP1
denismcapple
Active member
Hi Guys,
First off, having read through a number of threads on this forum, you guys seems to really know what you're at! So hopefully you can assist me.
I am trying to install Win 7 SP1 onto a computer - it keeps failing during the install.
The error I have been receiving is in relation to a missing component.
In the CBS Log, I see the following
[SIZE=2]2015-07-20 17:36:37, Info                  CBS    Exec: Resolving Package: Microsoft-Windows-Branding-Ultimate-Client-Package~31bf3856ad364e35~amd64~en-US~6.1.7601.17514, Update: BUC Namespace, PinDeployment: amd64_microsoft-windows-b..oyment-languagepack_31bf3856ad364e35_6.1.7600.16385_en-us_cfca0194ff453bb0
2015-07-20 17:36:37, Error                 CSI    0000036b@2015/7/20:16:36:37.920 (F) d:\win7sp1_gdr\base\wcp\componentstore\csd_locking.cpp(324): Error STATUS_SXS_ASSEMBLY_MISSING originated in function CCSDirectTransaction::LockComponent expression: (null)
[gle=0x80004005]
2015-07-20 17:36:38, Error                 CSI    0000036c (F) STATUS_SXS_ASSEMBLY_MISSING #1485549# from CCSDirectTransaction::OperateEnding at index 0 of 1 operations, disposition 2[gle=0xd015000c]
2015-07-20 17:36:38, Error                 CSI    0000036d (F) HRESULT_FROM_WIN32(ERROR_SXS_ASSEMBLY_MISSING) #1485434# from Windows::ServicingAPI::CCSITransaction::ICSITransaction_PinDeployment(Flags = 0, a = Microsoft-Windows-Branding-Ultimate-Deployment-LanguagePack, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture = [l:10{5}]"en-US", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral, cb = (null), s = (null), rid = [108]"Microsoft-Windows-Branding-Ultimate-Client-Package~31bf3856ad364e35~amd64~en-US~6.1.7601.17514.BUC Namespace", rah = (null), manpath = (null), catpath = (null), ed = 0, disp = 0)[gle=0x80073701]
[/SIZE]
I have run your tool SFCFix.exe and it has identified a number of errors, which were also picked up by the Windows Update Readiness Tool. (Log attached)
Can you advise on how to correct these errors?
Thanks a million!
Hi There,
It is failing about 75% way through the install of Service Pack 1.
I am not sure where the copy of Windows came from as this machine belongs to a non-techy friend of mine who I am trying to help out - I 'think' the install was from VLK Media - Its Win7 Pro 64 Bit if that helps?
I have just started another attempt to install SP1 again, it takes about 30 minutes to get to the point where it crashes out - I will take some screenshots at this point and post them in my next reply, once I have them.
Thanks!
Attached are two screenshots, one during the install (very shortly before the error) - and one of the error itself.
Thanks
Hi and welcome to Sysnative. Let's see if we can get you sorted out. Can you provide me the following logs please? Zip them up and attach them. If they are too large ( >7MB) then please upload to SendSpace and provide a link.
C:\Windows\Logs\CBS\CheckSUR.log
C:\Windows\Inf\Setupapi.dev.log
C:\Windows\Setupact.log
C:\Windows\Setuperr.log
Thanks.
I see a couple things that likely need fixed before SP1 will install. Here's the first one from the setupapi.dev.log.
!!!  sto: Failed to find driver update 'C:\Windows\WinSxS\amd64_winusb.inf_31bf3856ad364e35_6.1.7600.16385_none_53e9d62d2f5260f8\winusb.inf' in Driver Store. Error = 0x00000490
To try to remedy this, please do the following.
Install Driver Manually
1. Click your Start button and type cmd in the search box.
2. Right-click on cmd that appears in the search results and select Run as administrator. Click Yes to the User Account Control dialog if it appears.
3. Copy/Paste the following into the command-prompt window and then hit enter on the keyboard. Note: You will need to right-click your mouse and select paste in order to paste into the window. You can't use the keyboard shortcut.
pnputil -a C:\Windows\WinSxS\amd64_winusb.inf_31bf3856ad364e35_6.1.7600.16385_none_53e9d62d2f5260f8\winusb.inf
4. You will likely get a prompt that looks like the following. Please click "Install this driver software anyway".
5. If all goes well, in the command prompt window you should see text that resembles "Driver package added successfully".
Let me know how this step goes please. Thanks.
Thanks!
I ran that and it seems to work fine. See attached screenshot.
Should I try install SP1 now?
I see another few items that may need to be resolved before SP1 can install but I say go for it. Let me know the results.
OK Great, I've started the install - It will be about 20-30 minutes before we know the result.
Thanks
I suspected it might. Let's fix the other things I saw. Please do the following.
1. Download and run the following file. If you already have it downloaded you can use that one.
4. Please attach the log from the following location. C:\Windows\Logs\CBS\CheckSUR.log. Also, please attach a fresh copy of C:\Windows\Inf\setupapi.dev.log
Thanks. The driver issue is verified to be resolved so now I need the following log.
SFC Scan
  1. Click on the Start
Hi Brian,
Apologies for the delay in getting this one over to you, I was AFK for an hour there.
It ran and detected some errors that it couldnt fix.
C:\Users\Philip>sfc /scannow
Verification 100% complete.
Windows Resource Protection found corrupt files but was unable to fix some of th
em.
Details are included in the CBS.Log windir\Logs\CBS\CBS.log. For example
C:\Windows\Logs\CBS\CBS.log
C:\Users\Philip>
Here is the log file.
Thanks,
OK, so now we just have the original error that you reported in your initial post to correct.
2015-07-22 16:12:19, Error                 CSI    000001b7 (F) HRESULT_FROM_WIN32(ERROR_SXS_ASSEMBLY_MISSING) #601393# from Windows::ServicingAPI::CCSITransaction::ICSITransaction_PinDeployment(Flags = 0, a = Microsoft-Windows-Branding-Ultimate-Deployment-LanguagePack, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture = [l:10{5}]"en-US", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral, cb = (null), s = (null), rid = [108]"Microsoft-Windows-Branding-Ultimate-Client-Package~31bf3856ad364e35~amd64~en-US~6.1.7601.17514.BUC Namespace", rah = (null), manpath = (null), catpath = (null), ed = 0, disp = 0)[gle=0x80073701]
2015-07-22 16:12:19, Info                  CBS    [COLOR=#ff0000]Failed to pin deployment [/COLOR]while resolving Update: BUC Namespace from file: (null) [HRESULT = 0x80073701 - ERROR_SXS_ASSEMBLY_MISSING]
2015-07-22 16:12:19, Info                  CBS    Failed to resolve item[0] in Package: Microsoft-Windows-Branding-Ultimate-Client-Package~31bf3856ad364e35~amd64~en-US~6.1.7601.17514, Update: BUC Namespace [HRESULT = 0x80073701 - ERROR_SXS_ASSEMBLY_MISSING]
I think a registry key is missing and we need to add it. To verify this I will need your COMPONENTS hive. Please do the following.
Retrieve Components Hive
Thank you. I need another piece of your registry please.
Step#1 - Export CBS Registry Key
    button and in the search box, type regedit
  5. Change the Save as type: to Registry Hive Files (*.*)
  6. Name this file CBS (with no file extension) and save it to your Desktop.
Once done please upload this file via Dropbox or One Drive or SendSpace.
