[SOLVED] Problem installing .NET rollup
Remy
I got some problems installing the 2022-05 .NET rollup update. It fails with error 8000FFFF.
SFC en DISM are healthy.
I hope you can help me with this problem.
Regards,
Remy
Goodmorning support,
Can you help me with this problem? Do i need to upload some logs or screens to make clear what the problem is?
Regards,
Remy
Download the
Microsoft .NET Framework Repair tool and save it to your Desktop.
  • Right-click on NetFxRepairTool.exe and select Run as Administrator.
  • Agree with the license terms "I have read and accept the license terms" and click Next.
  • After checking, the tool will indicate which problems need to be fixed.
  • Click on Next to continue, when this process is finished click Next.
  • The tool will now collect the log files... > when completed the following file is created: FixDotNet****.cab.
  • Click on Finish to close the tool.
  • Right-click on the file FixDotNet****.cab and choose Send to > Compressed (zipped) folder.
  • Attach the ZIP file in your next reply.
Export CBS (Component Based Servicing) hive
  • Click on the Start button and type regedit
  • Name this file ComponentBasedServicing (with no file extension) and save it to your Desktop.
  • Right-click on the saved file and choose Send > Compressed (zipped) Folder.
2022-05-20 13:50:02, Info                  CBS    Registry value for 7367db5c\4fd4b97d\17 is not a dword type. [HRESULT = 0x8007000d - ERROR_INVALID_DATA]
2022-05-20 13:50:02, Info                  CBS    Failed to enumerate values in store object. [HRESULT = 0x8007000d - ERROR_INVALID_DATA]
(p)    CBS Registry Error    0x8007000d        Package_63_for_KB5012670~31bf3856ad364e35~amd64~~0.0.0.0
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageIndex\Package_63_for_KB5012670~31bf3856ad364e35~amd64~~0.0.0.0]
"7367db5c\\4fd4b97d\\17"=""
Download the
  • Press the Fix button.
Restoring the corrupt reg key failed, please try the following.
Download
Now it has succeeded, please try to install the latest updates. If it failes, please post the KB number of the failed update and attach a new copy of the CBS log.
  • Click the Start button and in the search box, type CMD
  • Copy and paste the following command into it, then press enter.
  • This command will create cbs.txt on your Desktop. Zip this file and attach the zipped cbs.txt to your next post.
Upload your COMPONENTS hive.
Nice, i updated the KB without problems. The system is healthy again.
Thanks for the good work and helping me out!
Regards,
Remy
Your welcome. Glad to hear that the update is installed whithout problems. (y)
I'll mark this thread as solved!
