Problem: Additional Lamguage Pack Installation fails (English)
philip
Dear all,
we have a major problem on Windows 2008 R2 server enviroment for a customer. We installed the OS in German. Afterwards we tried to install the English language as a additonal language but it fails. The wizard closed after a few minutes without any error message.
In the event log you find the following entry:
"Das Sprachpaket für en-US kann von CBS nicht installiert werden. Zurückgegebener CBS-Fehlercode: 0x80070002."
Is it possible to download the correct lp.cab and install it manually? Error Code is erverytime the same.
Thank you very much.
SCP
Start time: 2015-11-17 15:50:08.380
Microsoft Windows Server 2008 R2 Service Pack 1 - amd64
Finish time: 2015-11-17 15:53:05.902
Best regards
Philip
Hi and welcome to Sysnative. Can you please do the following?
SFC Scan
  1. Click on the Start
