When you run the update, what is your memory (RAM) usage?
Please also do the following:
ChkDsk Repair
1. Click your Start Orb in the lower left of your computer and type cmd in the search box.
2. Once the cmd program is found, right-click on it with your mouse and select Run as administrator as shown below.
3. Answer
Yes when asked to allow.
4. You should now have a black window open that you can type in to.
5. Please type chkdsk /R and then press enter. Note: There is a space after the command chkdsk and before the forward slash
6. You will get a prompt telling you chkdsk cannot run because the volume is in use. Answer Y and hit enter to schedule the run at next boot.
7. Reboot your computer and chkdsk will run. Let it complete please.
8. Download ListChkdskResult.exe by SleepyDude and save it on your desktop. If it's already downloaded to your desktop, just skip this step.
9. Right-click this file and select Run as administrator (Allow if prompted)and a text file will open (and also be saved on the desktop as ListChkdskResult.txt).
Please copy the contents of this file and paste into your next post.
When you say run the update, do you mean attempt the uninstall of the IE11 update or do I need to actually try to 'run' anything?
I do have the text file from the Chkdsk but I might mention it gave me a launching error from the missing ole32 and advapi32 .dll, so it might not have done something correctly because my computer did not restart after:
------< Log generate on 6/7/2018 9:36:42 AM >------
Category: 0
Computer Name: ReaperEOD-PC
Event Code: 1001
Record Number: 31634
Time Written: 06-08-2017 @ 02:06:57
Event Type: Information
User:
Message:
Checking file system on C:
that you continue.
CHKDSK is verifying files (stage 1 of 3)...
481024 file records processed.
File verification completed.
4631 large file records processed.
0 bad file records processed.
4 EA records processed.
94 reparse records processed.
CHKDSK is verifying indexes (stage 2 of 3)...
623148 index entries processed.
Index verification completed.
0 unindexed files scanned.
0 unindexed files recovered.
CHKDSK is verifying security descriptors (stage 3 of 3)...
481024 file SDs/SIDs processed.
Cleaning up 165 unused index entries from index $SII of file 0x9.
Cleaning up 165 unused index entries from index $SDH of file 0x9.
Cleaning up 165 unused security descriptors.
71063 data files processed.
35520096 USN bytes processed.
Correcting errors in the Volume Bitmap.
250056703 KB total disk space.
238335076 KB in 396175 files.
272672 KB in 71064 indexes.
0 KB in bad sectors.
594251 KB in use by the system.
10854704 KB available on disk.
62514175 total allocation units on disk.
2713676 allocation units available on disk.
Internal Info:
00 57 07 00 31 21 07 00 05 67 0d 00 00 00 00 00 .W..1!...g......
61 22 01 00 5e 00 00 00 00 00 00 00 00 00 00 00 a"..^...........
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
Category: 0
Event Code: 1001
Record Number: 30422
Time Written: 05-01-2017 @ 02:20:53
User:
Message:
that you continue.
Cleaning up instance tags for file 0x3652d.
Cleaning up instance tags for file 0x44c38.
480000 file records processed.
4509 large file records processed.
619756 index entries processed.
480000 file SDs/SIDs processed.
Cleaning up 596 unused index entries from index $SII of file 0x9.
Cleaning up 596 unused index entries from index $SDH of file 0x9.
Cleaning up 596 unused security descriptors.
69879 data files processed.
34883648 USN bytes processed.
CHKDSK discovered free space marked as allocated in the volume bitmap.
239272424 KB in 391376 files.
269828 KB in 69880 indexes.
592231 KB in use by the system.
9922220 KB available on disk.
2480555 allocation units available on disk.
Internal Info:
00 53 07 00 d2 09 07 00 b2 3e 0d 00 00 00 00 00 .S.......>......
48 24 01 00 5e 00 00 00 00 00 00 00 00 00 00 00 H$..^...........
