Finish time: 2022-09-09 16:17:54.471
Start time: 2022-09-12 15:58:12.677
Microsoft Windows Server 2012 R2 Update 3 - amd64
Using .zip script file at C:\Users\Administrator\Desktop\Temp\SFCFix.zip [2]
Successfully took permissions for file or folder C:\Windows\WinSxS\x86_microsoft-windows-ie-ratings_31bf3856ad364e35_11.0.9600.20512_none_584ee9f3a1101072\icrav03.rat
Successfully took permissions for file or folder C:\Windows\WinSxS\amd64_microsoft-windows-ie-ratings_31bf3856ad364e35_11.0.9600.20512_none_b46d8577596d81a8\icrav03.rat
WARNING: File C:\Windows\WinSxS\x86_microsoft-windows-ie-ratings_31bf3856ad364e35_11.0.9600.20512_none_584ee9f3a1101072\icrav03.rat was not backed up as that would replace the current backup.
Successfully copied file C:\Users\Administrator\AppData\Local\niemiro\Archive\WinSxS\x86_microsoft-windows-ie-ratings_31bf3856ad364e35_11.0.9600.20512_none_584ee9f3a1101072\icrav03.rat to C:\Windows\WinSxS\x86_microsoft-windows-ie-ratings_31bf3856ad364e35_11.0.9600.20512_none_584ee9f3a1101072\icrav03.rat.
WARNING: File C:\Windows\WinSxS\amd64_microsoft-windows-ie-ratings_31bf3856ad364e35_11.0.9600.20512_none_b46d8577596d81a8\icrav03.rat was not backed up as that would replace the current backup.
Successfully copied file C:\Users\Administrator\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft-windows-ie-ratings_31bf3856ad364e35_11.0.9600.20512_none_b46d8577596d81a8\icrav03.rat to C:\Windows\WinSxS\amd64_microsoft-windows-ie-ratings_31bf3856ad364e35_11.0.9600.20512_none_b46d8577596d81a8\icrav03.rat.
Successfully restored ownership for C:\Windows\WinSxS\x86_microsoft-windows-ie-ratings_31bf3856ad364e35_11.0.9600.20512_none_584ee9f3a1101072\icrav03.rat
Successfully restored permissions on C:\Windows\WinSxS\x86_microsoft-windows-ie-ratings_31bf3856ad364e35_11.0.9600.20512_none_584ee9f3a1101072\icrav03.rat
Successfully restored ownership for C:\Windows\WinSxS\amd64_microsoft-windows-ie-ratings_31bf3856ad364e35_11.0.9600.20512_none_b46d8577596d81a8\icrav03.rat
Successfully restored permissions on C:\Windows\WinSxS\amd64_microsoft-windows-ie-ratings_31bf3856ad364e35_11.0.9600.20512_none_b46d8577596d81a8\icrav03.rat
And after running again sfcfix again to check if the isuue resolved
Start time: 2022-09-12 17:18:01.680
Finish time: 2022-09-12 17:32:52.123
Thank you in advance for your time.
Please post the latest CBS log and a copy of the COMPONENTS hive.
Upload your COMPONENTS hive.
Navigate to C:\Windows\System32\Config and locate the COMPONENTS file.
Please copy this file to your desktop.
Right-click on this file on your desktop and select Send To > Compressed (zipped) folder. This will create a file named COMPONENTS.ZIP on your desktop.
If the file is too large to upload here, upload the file to www.wetransfer.com and post the link in your next reply.
Start time: 2022-09-12 23:23:37.355
Using .zip script file at C:\Users\Administrator\Desktop\SFCFix.zip [0]
RegistryScript::
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\amd64_microsoft-windows-ie-ratings_31bf3856ad364e35_11.0.9600.20512_none_b46d8577596d81a8.
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\213959a747a..db93c77177c_31bf3856ad364e35_11.0.9600.20512_89ee54f15469cca4.
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\x86_microsoft-windows-ie-ratings_31bf3856ad364e35_11.0.9600.20512_none_584ee9f3a1101072.
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\417a8c3559b..4d347ddd4b8_31bf3856ad364e35_11.0.9600.20512_8f3d5d04bb3447ca.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\amd64_microsoft-windows-ie-ratings_31bf3856ad364e35_11.0.9600.20512_none_b46d8577596d81a8.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\213959a747a..db93c77177c_31bf3856ad364e35_11.0.9600.20512_89ee54f15469cca4.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\x86_microsoft-windows-ie-ratings_31bf3856ad364e35_11.0.9600.20512_none_584ee9f3a1101072.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\417a8c3559b..4d347ddd4b8_31bf3856ad364e35_11.0.9600.20512_8f3d5d04bb3447ca.
Currently storing 6 datablocks.
Finish time: 2022-09-12 23:23:40.583
Script hash: cqME0iq8JCxKmoL0jpRDBoBA7hBEy1EFVNsQ1Sa1bsw=
Microsoft Windows [Version 6.3.9600]
(c) 2013 Microsoft Corporation. All rights reserved.
C:\Windows\System32>sfc /scannow
Verification 100% complete.
And this ia a small gift for my appreciation for your help
