[SOLVED] Please can someone help me with my scf /scannow failing to fix errors
dymmy
I have tried to fix the errors reported by sfc /scannow using DISM commands but despite reporting all is fixed the sfc /scannow fails again with the same error ('MSDTC error' this is from the CBS.log file ) I have attached it here and also my DISM log. I hope someone can help thx
2016-10-15 23:48:30, Info                  CSI    000058b7 [SR] Beginning Verify and Repair transaction
2016-10-15 23:48:30, Info                  CSI    000058b8 Hashes for file member \SystemRoot\WinSxS\amd64_microsoft-windows-com-dtc-runtime_31bf3856ad364e35_10.0.14393.0_none_46c76e6076b59fe9\MSDTC.LOG do not match actual file [l:9]'MSDTC.LOG' :
  Found: {l:32 VoTZEgibSlEn93tYzAtpMUjJUBp2DE+i0rgxNe36oDg=} Expected: {l:32 Q4htnI+yK+Jo0DJugTfqjq40IHkXFkIWyyAaDjFGEvo=}
2016-10-15 23:48:30, Info                  CSI    000058b9 [SR] Cannot repair member file [l:9]'MSDTC.LOG' of Microsoft-Windows-COM-DTC-Runtime, version 10.0.14393.0, arch amd64, nonSxS, pkt {l:8 b:31bf3856ad364e35} in the store, hash mismatch
2016-10-15 23:48:30, Info                  CSI    000058ba@2016/10/15:12:48:30.741 Primitive installers committed for repair
2016-10-15 23:48:30, Info                  CSI    000058bb Hashes for file member \SystemRoot\WinSxS\amd64_microsoft-windows-com-dtc-runtime_31bf3856ad364e35_10.0.14393.0_none_46c76e6076b59fe9\MSDTC.LOG do not match actual file [l:9]'MSDTC.LOG' :
2016-10-15 23:48:30, Info                  CSI    000058bc [SR] Cannot repair member file [l:9]'MSDTC.LOG' of Microsoft-Windows-COM-DTC-Runtime, version 10.0.14393.0, arch amd64, nonSxS, pkt {l:8 b:31bf3856ad364e35} in the store, hash mismatch
View attachment SFCFix.zip
you sir are a legend :)
Verification 100% complete.
Glad to help! :thumbsup2:
I'll mark the thread solved. Please post back if you encounter any problems and I will continue to assist you.
