fullandby
- Nov 14, 2019
- 9
On 19Mar21 my laptop updated to Windows 10 home 2004 19041.867. I didn't realize it was doing this, just thought it was a normal security/bug update. Since then, I have been having trouble accessing other network resources. My NAS (mounted as a drive) I can connect to but if I try to create a file, a text file for instance, it doesn't show up in the folder until I back out and then come back into the file. I can't access other computer shares on the network. I am also having trouble trying to connect to my phone via Bluetooth to transfer files. Running the troubleshooter only says that no problem can be found. The Bluetooth troubleshooter turns the Bluetooth on, even though I can see that it is on, and still it doesn't connect. I have tried forgetting the device and the pairing it again. Sometimes it will connect, most often not. Also, occasionally I can get to a network share on another computer but that is infrequently. I thought I would see if I could get pointed in a direction to check here. I am at the point that I am going to restore to the previous state, though if there is something I can do to correct it that would seem better. Thanks.
