Thanks John for assistance i have an update net frame work 3.5.1 that won't update and the turn windows features on or off when click on the box stays empty.
Hi and welcome. Let's see if we can get you fixed up. Please do the following first so I can get some info.
Step#1 - Gather Info 1. Download SFCFix.exe and save this to your Desktop.
2. Save any open documents and close all open windows.
3. Double click on SFCFix.exe to open it.
4. Follow all on screen instructions and upon completion, a file should be created on your Desktop named SFCFix.txt.
5. Please post the contents of this log in your next post. Thank you.
okay here it isSFCFix version 2.4.5.0 by niemiro.Start time: 2015-12-15 17:15:39.208
Finish time: 2015-12-15 17:22:58.103
4. Please attach the log from the following location. C:\Windows\Logs\CBS\CheckSUR.log Please Note:: if the file is too big to upload to your next post please upload via a service such as Dropbox or One Drive or SendSpace and just provide the link.
Binary Version 6.1.7601.22471
Package Version 26.0
2015-12-15 17:46
(f) CBS MUM Corrupt 0x800F0900 servicing\Packages\Package_10_for_KB2937610~31bf3856ad364e35~amd64~~6.1.1.3.mum Line 1:
(f) CBS Catalog Corrupt 0x800B0100 servicing\Packages\Package_10_for_KB2937610~31bf3856ad364e35~amd64~~6.1.1.3.cat
(f) CBS MUM Corrupt 0x800F0900 servicing\Packages\Package_56_for_KB2937610~31bf3856ad364e35~amd64~~6.1.1.3.mum Line 1:
(f) CBS Catalog Corrupt 0x800B0100 servicing\Packages\Package_56_for_KB2937610~31bf3856ad364e35~amd64~~6.1.1.3.cat
Checking Package Watchlist
Checking Component Watchlist
Checking Packages
Checking Component Store
Summary:
Seconds executed: 1693
Found 4 errors
CBS MUM Corrupt Total count: 2
CBS Catalog Corrupt Total count: 2
Step#1 - SFCFix Script Warning: this fix is specific to the user in this thread. No one else should follow these instructions as it may cause more harm than good. If you are after assistance, please start a thread of your own.
Download SFCFix.exe (by niemiro) and save this to your Desktop. If you still have this on your desktop from downloading previously, you don't need to re-download.
Download the file below, SFCFix.zip, and save this to your Desktop. Ensure that this file is named SFCFix.zip - do not rename it.
Copy (Ctrl+C) and Paste (Ctrl+V) the contents of this file into your next post for me to analyse please
here is the reportSFCFix version 2.4.5.0 by niemiro.Start time: 2015-12-15 18:52:43.554
SURT total detected corruption count: 4
Finish time: 2015-12-15 18:56:36.469
sorry Brian the order got messed up but here it is SFCFix version 2.4.5.0 by niemiro.Start time: 2015-12-15 19:07:10.725
Using .zip script file at C:\Users\Owner\Desktop\SFCFix.zip [0]
Successfully took permissions for file or folder C:\Windows\Temp\CheckSur\Servicing\Packages
Successfully copied file C:\Users\Owner\AppData\Local\niemiro\Archive\Packages\Package_10_for_KB2937610~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_10_for_KB2937610~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Owner\AppData\Local\niemiro\Archive\Packages\Package_10_for_KB2937610~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_10_for_KB2937610~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Owner\AppData\Local\niemiro\Archive\Packages\Package_56_for_KB2937610~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_56_for_KB2937610~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Owner\AppData\Local\niemiro\Archive\Packages\Package_56_for_KB2937610~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_56_for_KB2937610~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully restored ownership for C:\Windows\Temp\CheckSur\Servicing\Packages
Successfully restored permissions on C:\Windows\Temp\CheckSur\Servicing\Packages
Finish time: 2015-12-15 19:07:14.890
Script hash: ymcg0GH7Znqd7yZxwHGFRJ+sUs9T0uyG+GBlTtI0qzQ=
2015-12-15 19:32
(fix) CBS MUM Corrupt CBS File Replaced Package_10_for_KB2937610~31bf3856ad364e35~amd64~~6.1.1.3.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab4.cab.
(fix) CBS Paired File CBS File also Replaced Package_10_for_KB2937610~31bf3856ad364e35~amd64~~6.1.1.3.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab4.cab.
(fix) CBS MUM Corrupt CBS File Replaced Package_56_for_KB2937610~31bf3856ad364e35~amd64~~6.1.1.3.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab4.cab.
(fix) CBS Paired File CBS File also Replaced Package_56_for_KB2937610~31bf3856ad364e35~amd64~~6.1.1.3.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab4.cab.
Checking Packages
Summary:
Seconds executed: 1373
Found 2 errors
Fixed 2 errors
Fixed: CBS MUM Corrupt. Total count: 2
Fixed: CBS Paired File. Total count: 2
