Need help with the DISM error
aaa839
I'm using the Windows 11 Pro Build 22616.1 Insider Dev Channel.I can't update my build nor install any cumulative update.
I found a weried error of DISM showing 0X80070032.Not sure why it happen and which update cause such error...
Trying the Dism /online /cleanup-image /restorehealth,Sfc /scannow
SFC no error found.
(Due to this error both Inplace repaire and upgrade build not work too)
DISM kept reporting 0X80070032
Any help I'm apperciate.
Here is the DISM,CBS and SFC log
SFC no error found.
Reupload that
sorry can anyone help??
Did I need to attach more logs??
You "bumped" your thread in less than 24 hours. Please be patient. We're not a paid support forum and are run by volunteers.
Could you please open an elevated command prompt and then enter the following command:
fsutil resource setautoreset true %systemdrive%\
Afterwards, please reboot the machine and then run DISM again. If it fails with the same error code, then please follow these instructions:
Capture Process Monitor Trace
2. Try running DISM just like you have in the past.
3. Stop Process Monitor as soon as it fails. You can simply do this by clicking the square icon on the toolbar as shown below.
5. Zip up and provide the link to the LogFile.PML file as well as your CBS.log Examples of services to upload to are Dropbox or OneDrive or WeTransfer.
Please note you are running a dev build and it will have bugs.
thank you so much for reply.
I'm sorry being too pushy about that. this problem had been frustrated me about a week...
anyway I try your command is showing as the request not supported.
I need to use the below command
(It just weried why the TXF log got corruption but never notified me about that)
fsutil behavior set disabletxf C:\ 0
and retyping it to reenable
fsutil behavior set disabletxf C:\ 1
it turn back normal.
