[SOLVED] Need Help With Error Found In SFC
igneel
I'm new to these forums, but here's the cbs.txt in a zip archive.
The Error is found on line 45729.
To be clear, DISM runs fine after the SFC scan. It's just this one Error in CBS. I'll upload a dism.txt too, just in case. The parts to look for would be dated from yesterday onward.
Here's some PUI from the other logs in the Logs folder.
https://pastebin.com/raw/87uKvuhF
Please let me know if you need any of the other logs.
I also have SFCFix installed.
You're right. There are no errors present in the CBS.log now upon a new sfc scan. Another question. Is there a place on this website to report Windows error and status codes? I'm using the errorLookup utility provided by resplendence.com There's several error codes found present on my computer when using it.
Awesome!
No, and not every error code is important. Some are normal and expected. I will mark the thread as resolved unless there are further questions. :-)
Yeah, mark it as solved. I will see if any of the errors are unexpected and seek help from the Microsoft forums or Stack Overflow. Thanks for your help! 🥳
