[SOLVED] need help with cbs.log
willi
strange behaviour (100% hardisk use). i ran a sfc /scannow and received notice that some problems could not be repaired.
attached is the cbs.log. the CbsPersist_20150209215418.log is some 140MB.
not sure what's best to do. thank you for your help.
henryk
Hello and welcome
Please download and run SFCFix from >Here<
It will take about 15 minutes to process. Once the scan has completed a notepad file will launch with the results. Please copy and paste the entire contents of the results and post them back into this thread. Please put [CODE][/CODE] tags around the log to break up the text.
thank you. below the log of sfcfix:
SFCFix version 2.4.2.1 by niemiro.
Start time: 2015-02-11 16:57:24.632
FIXED: Performed DISM repair on file Amd64\CNBJ2530.DPB of version 6.3.9600.17415.
SFCFix version 2.4.2.1 by niemiro has completed.
Finish time: 2015-02-11 17:24:50.910
it seems to have worked already. i think windows modules installer worker (tiworker.exe) was responsible for the hd use.
That looks good :)
Lets just do a double check that SFC is clean.
SFC /SCANNOW
  1. Right click on the
    button
Convert CBS.log to CBS.txt
    button
  2. Click on Run => Inside the run box copy and paste the following command:
  3. Press Enter
Please Note:: if the file is too big to upload to you next post please upload via Dropbox or One Drive
Alex
Thanks Henryk I can see the error is still present:
\SystemRoot\WinSxS\amd64_prncacla.inf_31bf3856ad364e35_6.3.9600.17415_none_95dd5540d57f8c01\Amd64\CNBJ2530.DPB
We will manually repair this one now.
SFC /SCANNOW
    button
    button
  3. Press Enter
i really appreciate your quick help. cheers henryk
Start time: 2015-02-14 14:46:57.079
Using .zip script file at C:\Users\HP\Desktop\SFCFix.zip [0]
Successfully  took permissions for file or folder  C:\WINDOWS\winsxs\amd64_prncacla.inf_31bf3856ad364e35_6.3.9600.17415_none_95dd5540d57f8c01\Amd64\CNBJ2530.DPB
Successfully   copied file  C:\Users\HP\AppData\Local\niemiro\Archive\winsxs\amd64_prncacla.inf_31bf3856ad364e35_6.3.9600.17415_none_95dd5540d57f8c01\Amd64\CNBJ2530.DPB   to  C:\WINDOWS\winsxs\amd64_prncacla.inf_31bf3856ad364e35_6.3.9600.17415_none_95dd5540d57f8c01\Amd64\CNBJ2530.DPB.
Successfully  restored ownership for  C:\WINDOWS\winsxs\amd64_prncacla.inf_31bf3856ad364e35_6.3.9600.17415_none_95dd5540d57f8c01\Amd64\CNBJ2530.DPB
Successfully  restored permissions on  C:\WINDOWS\winsxs\amd64_prncacla.inf_31bf3856ad364e35_6.3.9600.17415_none_95dd5540d57f8c01\Amd64\CNBJ2530.DPB
Finish time: 2015-02-14 14:47:01.688
Script hash: GhhUvOeEUSNjYMg+4QHIarotrhsC9PjiKZQXoww/2Sg=
cbs.txt: https://www.dropbox.com/s/xee7qphopt3t2fs/CBS.txt?dl=0
