Need Help Please! SFCFix FAILED TO REPAIR CORRUPTED DATA
philspectre79
Start time: 2020-11-28 07:06:14.568
Microsoft Windows 7 - amd64
CORRUPT: C:\Windows\winsxs\amd64_microsoft-windows-s..on-wizard-framework_31bf3856ad364e35_6.1.7600.16385_none_1247d6dd6b2a4026\spwizimg.dll
CORRUPT: C:\Windows\winsxs\amd64_microsoft-windows-s..on-wizard-framework_31bf3856ad364e35_6.1.7600.16385_none_1247d6dd6b2a4026\spwizres.dll
CORRUPT: C:\Windows\winsxs\amd64_microsoft-windows-setup-component_31bf3856ad364e35_6.1.7600.16385_none_8e216ff5c6f34f3e\W32UIRes.dll
CORRUPT: C:\Windows\winsxs\amd64_microsoft-windows-setup-component_31bf3856ad364e35_6.1.7600.16385_none_8e216ff5c6f34f3e\Setup.exe
CBS & SFC total detected corruption count: 4
Finish time: 2020-11-28 07:22:56.958
Start time: 2020-11-28 12:20:18.492
Using .zip script file at C:\Users\Spectre\Desktop\SFCFix.zip [0]
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-setup-component_31bf3856ad364e35_6.1.7600.16385_none_8e216ff5c6f34f3e\Setup.exe
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-setup-component_31bf3856ad364e35_6.1.7600.16385_none_8e216ff5c6f34f3e\W32UIRes.dll
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-s..on-wizard-framework_31bf3856ad364e35_6.1.7600.16385_none_1247d6dd6b2a4026\spwizimg.dll
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft-windows-s..on-wizard-framework_31bf3856ad364e35_6.1.7600.16385_none_1247d6dd6b2a4026\spwizres.dll
Successfully copied file C:\Users\Spectre\AppData\Local\niemiro\Archive\amd64_microsoft-windows-setup-component_31bf3856ad364e35_6.1.7600.16385_none_8e216ff5c6f34f3e\Setup.exe to C:\Windows\winsxs\amd64_microsoft-windows-setup-component_31bf3856ad364e35_6.1.7600.16385_none_8e216ff5c6f34f3e\Setup.exe.
Successfully copied file C:\Users\Spectre\AppData\Local\niemiro\Archive\amd64_microsoft-windows-setup-component_31bf3856ad364e35_6.1.7600.16385_none_8e216ff5c6f34f3e\W32UIRes.dll to C:\Windows\winsxs\amd64_microsoft-windows-setup-component_31bf3856ad364e35_6.1.7600.16385_none_8e216ff5c6f34f3e\W32UIRes.dll.
Successfully copied file C:\Users\Spectre\AppData\Local\niemiro\Archive\amd64_microsoft-windows-s..on-wizard-framework_31bf3856ad364e35_6.1.7600.16385_none_1247d6dd6b2a4026\spwizimg.dll to C:\Windows\winsxs\amd64_microsoft-windows-s..on-wizard-framework_31bf3856ad364e35_6.1.7600.16385_none_1247d6dd6b2a4026\spwizimg.dll.
Successfully copied file C:\Users\Spectre\AppData\Local\niemiro\Archive\amd64_microsoft-windows-s..on-wizard-framework_31bf3856ad364e35_6.1.7600.16385_none_1247d6dd6b2a4026\spwizres.dll to C:\Windows\winsxs\amd64_microsoft-windows-s..on-wizard-framework_31bf3856ad364e35_6.1.7600.16385_none_1247d6dd6b2a4026\spwizres.dll.
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-setup-component_31bf3856ad364e35_6.1.7600.16385_none_8e216ff5c6f34f3e\Setup.exe
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-setup-component_31bf3856ad364e35_6.1.7600.16385_none_8e216ff5c6f34f3e\Setup.exe
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-setup-component_31bf3856ad364e35_6.1.7600.16385_none_8e216ff5c6f34f3e\W32UIRes.dll
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-setup-component_31bf3856ad364e35_6.1.7600.16385_none_8e216ff5c6f34f3e\W32UIRes.dll
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-s..on-wizard-framework_31bf3856ad364e35_6.1.7600.16385_none_1247d6dd6b2a4026\spwizimg.dll
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-s..on-wizard-framework_31bf3856ad364e35_6.1.7600.16385_none_1247d6dd6b2a4026\spwizimg.dll
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft-windows-s..on-wizard-framework_31bf3856ad364e35_6.1.7600.16385_none_1247d6dd6b2a4026\spwizres.dll
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft-windows-s..on-wizard-framework_31bf3856ad364e35_6.1.7600.16385_none_1247d6dd6b2a4026\spwizres.dll
Finish time: 2020-11-28 12:20:28.679
Script hash: +399uWfJZg+X8CkbE2AdEaZj89Dzzdna1ixhJEzDXUQ=
Great.
Double-click SFCFix.exe to run the tool. A dialog may come up asking for approval. If it does go ahead and allow.
On completion a log file (SFCFix.txt) will be opened. Copy and Paste its content into your next reply.
