Need help fixing stuff from CBS log
ClarkKent
Hey, I've recently encountered an issue where my disk C was getting checked and repaired on every boot and the Event Logger showed Windows could not launch launch Microsoft Office Click-to-Run service, and since it's been a long time since I've used Office anyway I decided to just disable the service and remove Office altogether. But the issue didn't go away. So I did the SFC scan and Windows found a problem it couldn't solve itself, so here's the CBS log.
Any help would be greatly appreciated.
Hi!
SFC Scan
Hey! Thanks for the help. This is what was in the .txt file:
Start time: 2020-06-03 18:34:40.787
Microsoft Windows 10 Build 18363 - amd64
Using .zip script file at C:\Users\User\Desktop\SFCFix.zip [0]
Successfully took permissions for file or folder C:\Windows\Winsxs\x86_netfx35linq-system.data.entity_31bf3856ad364e35_10.0.18362.1_none_a9530b46a06ea15d\System.Data.Entity.dll
Successfully copied file C:\Users\User\AppData\Local\niemiro\Archive\WinSxS\x86_netfx35linq-system.data.entity_31bf3856ad364e35_10.0.18362.1_none_a9530b46a06ea15d\System.Data.Entity.dll to C:\Windows\Winsxs\x86_netfx35linq-system.data.entity_31bf3856ad364e35_10.0.18362.1_none_a9530b46a06ea15d\System.Data.Entity.dll.
Successfully restored ownership for C:\Windows\Winsxs\x86_netfx35linq-system.data.entity_31bf3856ad364e35_10.0.18362.1_none_a9530b46a06ea15d\System.Data.Entity.dll
Successfully restored permissions on C:\Windows\Winsxs\x86_netfx35linq-system.data.entity_31bf3856ad364e35_10.0.18362.1_none_a9530b46a06ea15d\System.Data.Entity.dll
Finish time: 2020-06-03 18:36:57.289
Script hash: Txolx3sSDGNTZVA09HmkHmGHp/Cjx/SNwffE9mHloNg=
