Hello, i have a strange problem in FPS game where my crosshair is not moving well in a straight line horizontal/vertical. It goes slightly wide or slalom. Here is a video i recorded to show this issue: YouTube
What's interesting, in windows/browser or in paint if i draw some lines and try to follow them it seems ok. But if i launch the game and play it's so strange. I have win 8.1, my settings in windows are like people recommend so mouse speed is middle 6/12, acceleration is unticked. I play with 800 DPI and lower sens in game because 800 DPI is what i want outside the game when i use my PC. My mouse is A4tech X-748K but don't know which one because there are different versions. I found an image which is the same as my mouse at the bottom:
Also, i tried contacting the game support and they replied this:
"This seems to be something depending on your mouse, your mouse acceleration and/or compensation and your DPI settings as well as how skilled you are in moving the mouse. This depends a lot of the sensor quality of the mouse. I can just say, that the sensitivity and many other options can cause that. Maybe microsoft uses some sort of "compensation" so you're not recognizing when not ingame. Unfortunately I'm not able to check your setup/installation from here."
So.. i have no idea what's the reason for this. Maybe you guys will have some ideas, maybe there is something i can do. Thanks in advance.
