MIT Develops Accurate System for Tracking People, Objects via WiFi
JMH
Emeritus, Contributor
MIT's Computer Science and Artificial Intelligence Laboratory (CSAIL) has created a new system called Chronos that can accurately detect the position of a person or object inside a room within tens of centimeters, using WiFi signals only.
Chronos works without the aid of any secondary sensors, only using a technology called time-of-flight calculation, which measures the time it takes data to travel from the WiFi access point to the user's device.
Chronos is more accurate than current triangulation-based systems According to MIT, this new system is 20 times more accurate than the current WiFi-based tracking systems.
Researchers say that Chronos was 94 percent successful in detecting which room a person is currently in, and 97 percent successful in determining if a shop's customer was inside or outside the store.
Researchers say that coffee shops and stores can benefit from something like Chronos because it will allow them to use passwordless WiFi connections for their clients, preventing nearby users from loitering on their WiFi.
Additionally, since Chronos can locate persons within tens of centimeters, researchers say that they could be mounted on drones and allow them to survey indoor locations while also keeping away from room occupants.
Where are all the tin-foil hat wearing conspiracy theorist complaining about Big Brother watching and taking away their privacy? I guess because Microsoft and Windows 10 is not behind this, it's okay. :noidea: :r1:
Within centimeters???? And marketing weenies are not going to figure how to target these users with ads for the products they are standing in front of? Yeah, right.
Don't get me wrong. As an electronics technician with roots set in radio equipment maintenance, I think the technology is amazing and fascinating. It is the disparate, inconsistent if not clearly biased reporting of it that disgusts me.
In searching on mit wifi tracking, there is barely a mention anywhere about spying on users and it is immediately blown off with the excuse there will be "regulations" and user controlled "blockers" put in place. Again, yeah right! :(
