[Lenovo legion y530] Latency problems
Vezovi
Active member
since i have this laptop, im struggling some weird mouse delay, cracking and popping sounds (these sounds are good now since i have updated ahci and sound driver). Latency mon shows that every mouse movement, the ISR and overall latency of WDF01000.sys is increasing. And acpi.sys latency is jumping every few seconds.
I tried changing drivers (from manufacturer, basic windows update drivers, from external programs like driverbooster) - still same.
Clean boot also shows same problem.
Power plane is set to high performance.
I did read every possible thread on multiple forums to search for the solution- nothing worked. (changing sata mode from ahci to intel rst, changing slow slew rate, turning off power management options in bios).
CONCLUSION
LatencyMon has been analyzing your system for 0:01:10 (h:mm:ss) on processors 0,1,2 and 3.
SYSTEM INFORMATION
Computer name: DESKTOP-LJ41MRP
OS version: Windows 10 , 10.0, build: 18363 (x64)
Hardware: 81FV, LENOVO, LNVNB161216
CPU: GenuineIntel Intel(R) Core(TM) i5-8300H CPU @ 2.30GHz
Logical processors: 8
Processor groups: 1
RAM: 16256 MB total
CPU SPEED
Reported CPU speed: 2304 MHz
Highest measured interrupt to process latency (µs): 3428,90
Average measured interrupt to process latency (µs): 3,752632
Highest measured interrupt to DPC latency (µs): 3390,90
Average measured interrupt to DPC latency (µs): 1,246940
REPORTED ISRs
Highest ISR routine execution time (µs): 312,106771
Driver with highest ISR routine execution time: Wdf01000.sys - Aparat wykonawczy struktury sterowników trybu jądra, Microsoft Corporation
Highest reported total ISR routine time (%): 0,006241
Driver with highest ISR total time: Wdf01000.sys - Aparat wykonawczy struktury sterowników trybu jądra, Microsoft Corporation
Total time spent in ISRs (%) 0,008224
ISR count (execution time <250 µs): 27800
ISR count (execution time 500-999 µs): 1
REPORTED DPCs
Highest DPC routine execution time (µs): 3607,871528
Driver with highest DPC routine execution time: ACPI.sys - Sterownik ACPI dla systemu NT, Microsoft Corporation
Highest reported total DPC routine time (%): 0,108501
Driver with highest DPC total execution time: Wdf01000.sys - Aparat wykonawczy struktury sterowników trybu jądra, Microsoft Corporation
Total time spent in DPCs (%) 0,248296
DPC count (execution time <250 µs): 178045
DPC count (execution time 500-999 µs): 125
DPC count (execution time 2000-3999 µs): 3
REPORTED HARD PAGEFAULTS
Process with highest pagefault count: chrome.exe
Total number of hard pagefaults 98
Hard pagefault count of hardest hit process: 54
Number of processes hit: 5
PER CPU DATA
CPU 0 Interrupt cycle time (s): 2,541423
CPU 0 ISR highest execution time (µs): 312,106771
CPU 0 ISR total execution time (s): 0,045856
CPU 0 ISR count: 27561
CPU 0 DPC highest execution time (µs): 3607,871528
CPU 0 DPC total execution time (s): 1,107544
CPU 0 DPC count: 171960
CPU 1 Interrupt cycle time (s): 1,237901
CPU 1 ISR highest execution time (µs): 17,171875
CPU 1 ISR total execution time (s): 0,000262
CPU 1 ISR count: 240
CPU 1 DPC highest execution time (µs): 243,956597
CPU 1 DPC total execution time (s): 0,014142
CPU 1 DPC count: 1104
CPU 2 Interrupt cycle time (s): 1,927677
CPU 2 ISR count: 0
CPU 2 DPC highest execution time (µs): 1042,303819
CPU 2 DPC total execution time (s): 0,266526
CPU 2 DPC count: 4370
CPU 3 Interrupt cycle time (s): 1,592222
CPU 3 ISR count: 0
CPU 3 DPC highest execution time (µs): 275,238715
CPU 3 DPC total execution time (s): 0,004113
CPU 3 DPC count: 740
  • System Manufacturer? Lenovo
  • Laptop or Desktop? laptop
  • Exact model number: legion y530
  • OS ? 10 home
  • x86 (32bit) or x64 (64bit)? 64bit
  • Age of system? (hardware) 6 months
  • Age of OS installation? week (did reinstall)
  • Have you re-installed the OS? yes, many times
  • CPU i5 8300h
  • RAM 8 gb ramaxel ddr4 2666mhz, 8gb kingston ddr4 2666mhz
  • Video Card gtx 1050 4gb
  • Is driver verifier enabled or disabled? enabled
  • What security software are you using? windows defender
  • Are you using proxy, vpn, ipfilters or similar software? no
  • Are you using Disk Image tools? (like daemon tools, alcohol 52% or 120%, virtual CloneDrive, roxio software) no
  • Are you currently under/overclocking? Are there overclocking software installed on your system? no
http://speccy.piriform.com/results/pfiuBgpSyM3dmHehfxeWP7s
TRACE:
trace.zip
Hi, My name is Rob. Welcome to Sysnative!
Open an elevated command prompt: Hit start type cmd CTRL + Shift + ENTER, an elevated prompt should open.
In this prompt, type verifier, choose Delete Existing Settings and Finish. Reboot and see if your problems go away.
Let us know.
Yes, still the same.
Forgot to add: latency over ACPI.sys is getting worse while using FN + function (FN+ volume/touchpad etc.)
Thanks! Standby for others with more experience with latencymon.
I see you have both Nvidia and Intel graphics. Make sure the Intel onboard is disabled. You'll probably have to this from the BIOS.
I would really like to disable intel graphics but its connected to the screen, so from my knowledge it's impossible to switch screen physically to nvidia (or i am just wrong).
Let us know.
Thank you very much Rob! You just helped me to solve a problem which has been messing my pc and activities during this whole week.
All the best.
You can actually go into the device manager and right click the intel video driver and disable. If its the one your using all that will happen is the system will revert to the generic driver and you can simply right click the driver in device manager and enable.
Even after disabling intel graphics in device manager, latency mon shows the same latency spikes on ACPI.sys and wdf01000.sys.
I tried disabling all possible settings in bios (audio, wlan, c states, intel ME etc.), problem still persists.
I've seen those topics, nothing of this worked.
Try to update the SSD firmware using the Western Digital SSD Dashboard (if you didn't already do it): WD Software
Already tried that, it's up to date :/
Thank you for trying to help me .
Those 2 topics cover dang near everything one could think of shy of obtaining a new computer. :-)
One of those suggestions of getting rid of all the Lenovo (may be called IBM) bloatware and its corresponding services, also disable Adobe services as well.
Hit Start, type services, upper left corner Services will pop out, right click and run as Administrator.
Anything that says Lenovo can be disabled, you will lose functionality of Lenovo apps but you won't lose functionality of your computer.
This happens even on fresh windows install, without any bloatware/drivers etc.
There is nothing from Lenovo, just intel services.
Funny fact: if i use (hold) FN+ touchpad in game, i can see fps drops and little stuttering... So i can only imagine how hard are these latency problems affect my mouse movement/performance.
