Hello, and thanks for reading this thread, I'm a bit out of my comfort zone here, as I dont know how to proceed after this report I got from LatencyMon, any help would be apreciated.
CONCLUSION
________________________________________________________________________________________________________
LatencyMon has been analyzing your system for 11:29:52 (h:mm:ss) on all processors.
SYSTEM INFORMATION
Computer name: DANIEL-PC
Hardware: All Series, ASUS, ASUSTeK COMPUTER INC., Z97-PRO GAMER
CPU: GenuineIntel Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz
Logical processors: 8
Processor groups: 1
RAM: 8134 MB total
CPU SPEED
Reported CPU speed: 3997 MHz
Highest measured interrupt to process latency (µs): 181379,452373
Average measured interrupt to process latency (µs): 10,461156
Highest measured interrupt to DPC latency (µs): 12014,471156
Average measured interrupt to DPC latency (µs): 4,669185
REPORTED ISRs
Highest ISR routine execution time (µs): 679,529647
Highest reported total ISR routine time (%): 0,030884
Driver with highest ISR total time: hal.dll - Hardware Abstraction Layer DLL, Microsoft Corporation
Total time spent in ISRs (%) 0,073821
ISR count (execution time <250 µs): 29135794
ISR count (execution time 500-999 µs): 36120
REPORTED DPCs
Highest DPC routine execution time (µs): 20369,447085
Driver with highest DPC routine execution time: ataport.SYS - ATAPI Driver Extension, Microsoft Corporation
Highest reported total DPC routine time (%): 0,994475
Driver with highest DPC total execution time: ndis.sys - NDIS 6.20 driver, Microsoft Corporation
Total time spent in DPCs (%) 1,19590
DPC count (execution time <250 µs): 284910382
DPC count (execution time 500-999 µs): 1373154
DPC count (execution time 1000-1999 µs): 52430
DPC count (execution time 2000-3999 µs): 1299
REPORTED HARD PAGEFAULTS
Process with highest pagefault count: ekrn.exe
Total number of hard pagefaults 506837
Hard pagefault count of hardest hit process: 124745
Highest hard pagefault resolution time (µs): 2953137,637978
Total time spent in hard pagefaults (%): 0,230602
Number of processes hit: 49
PER CPU DATA
CPU 0 Interrupt cycle time (s): 4575,647257
CPU 0 ISR highest execution time (µs): 679,529647
CPU 0 ISR total execution time (s): 236,208751
CPU 0 ISR count: 28726114
CPU 0 DPC highest execution time (µs): 20369,447085
CPU 0 DPC total execution time (s): 3771,144987
CPU 0 DPC count: 246578599
CPU 1 Interrupt cycle time (s): 806,894977
CPU 1 ISR highest execution time (µs): 427,415562
CPU 1 ISR total execution time (s): 2,971790
CPU 1 ISR count: 154508
CPU 1 DPC highest execution time (µs): 978,088566
CPU 1 DPC total execution time (s): 14,247686
CPU 1 DPC count: 1475403
CPU 2 Interrupt cycle time (s): 791,259213
CPU 2 ISR highest execution time (µs): 463,717788
CPU 2 ISR total execution time (s): 0,416888
CPU 2 ISR count: 20328
CPU 2 DPC highest execution time (µs): 1653,910433
CPU 2 DPC total execution time (s): 50,976130
CPU 2 DPC count: 12361579
CPU 3 Interrupt cycle time (s): 659,042814
CPU 3 ISR highest execution time (µs): 507,190393
CPU 3 ISR total execution time (s): 1,740567
CPU 3 ISR count: 109426
CPU 3 DPC highest execution time (µs): 888,566425
CPU 3 DPC total execution time (s): 10,194048
CPU 3 DPC count: 895746
CPU 4 Interrupt cycle time (s): 794,703889
CPU 4 ISR highest execution time (µs): 558,433825
CPU 4 ISR total execution time (s): 0,472462
CPU 4 ISR count: 24644
CPU 4 DPC highest execution time (µs): 988,866650
CPU 4 DPC total execution time (s): 48,101867
CPU 4 DPC count: 11676845
CPU 5 Interrupt cycle time (s): 665,834453
CPU 5 ISR highest execution time (µs): 510,738054
CPU 5 ISR total execution time (s): 1,408650
CPU 5 ISR count: 74252
CPU 5 DPC highest execution time (µs): 767,510633
CPU 5 DPC total execution time (s): 6,938280
CPU 5 DPC count: 550054
CPU 6 Interrupt cycle time (s): 728,300969
CPU 6 ISR highest execution time (µs): 381,46610
CPU 6 ISR total execution time (s): 0,305841
CPU 6 ISR count: 16037
CPU 6 DPC highest execution time (µs): 904,573430
CPU 6 DPC total execution time (s): 51,177894
CPU 6 DPC count: 11746237
CPU 7 Interrupt cycle time (s): 602,684743
CPU 7 ISR highest execution time (µs): 466,304729
CPU 7 ISR total execution time (s): 0,925952
CPU 7 ISR count: 46605
CPU 7 DPC highest execution time (µs): 1633,720290
CPU 7 DPC total execution time (s): 7,321641
CPU 7 DPC count: 1052824
