[SOLVED] Laptop used sfc scan got problems..used dism still doesn't fix the problem
Hi xordin :)
My name is Aura and I'll be assisting you with your issue. Restart your computer, and run a new SFC scan please.
System File Checker (SFC)
    Run as Administrator
I already include my CBS file in the first post,anyway I rescan my laptop.Here is the newest CBC file.
I know you did, but the DISM operation was asking for a restart to repair a component, hence why I asked for a restart and a new scan :) Follow the instructions below please.
SFCFix - Fix Time
SFCFix.zip
Start time: 2015-12-04 08:22:08.892
Microsoft Windows 8.1 - x86
Using .zip script file at C:\Users\XD\Desktop\SFCFix.zip [0]
Successfully took permissions for file or folder C:\WINDOWS\winsxs\x86_microsoft-windows-autochk_31bf3856ad364e35_10.0.10586.0_none_125aea1eb3bae4ea\autochk.exe
Successfully copied file C:\Users\XD\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-autochk_31bf3856ad364e35_10.0.10586.0_none_125aea1eb3bae4ea\autochk.exe to C:\WINDOWS\winsxs\x86_microsoft-windows-autochk_31bf3856ad364e35_10.0.10586.0_none_125aea1eb3bae4ea\autochk.exe.
Successfully restored ownership for C:\WINDOWS\winsxs\x86_microsoft-windows-autochk_31bf3856ad364e35_10.0.10586.0_none_125aea1eb3bae4ea\autochk.exe
Successfully restored permissions on C:\WINDOWS\winsxs\x86_microsoft-windows-autochk_31bf3856ad364e35_10.0.10586.0_none_125aea1eb3bae4ea\autochk.exe
Finish time: 2015-12-04 08:22:09.558
Script hash: h5J17QREJf3T0a59TVE/LN9P6Y/dztq8Fywh3LESvHk=
problem soved. thanks
No problem xordin, you're welcome :)
