Laptop creating loads of pops and clicks, and VERY high latency. Help?
asintoras
Hello everyone,
I learned about this website from Focusrite (audio interface manufacturer). I have a Dell 1545 Inspiron whose BIOS have been updated today. The Windows 7 is setup for high performance in audio (as per Focusrite suggestions). All drivers are up to date but still I am experiencing a lot of latency as well as clicks and pops, which make recording just impossible.
The laptop had wi-fi turned off and there is no anti-virus or anti-malware program installed (and no firewall either). My wife has a MacBook Pro (2011) which I used just to compare, and there is no latency issue with it, so the fault is not on the audio interface or driver.
Any ideas on what can I do to amend this, I would really appreciate.
I run a Latency Monitor Check, which I paste here:
CONCLUSION
LatencyMon has been analyzing your system for 0:02:36 (h:mm:ss) on all processors.
SYSTEM INFORMATION
Computer name: ASINTORAS-PC
Hardware: Inspiron 1545 , Dell Inc., 0G848F
CPU: GenuineIntel Pentium(R) Dual-Core CPU T4400 @ 2.20GHz
Logical processors: 2
Processor groups: 1
RAM: 4056 MB total
CPU SPEED
Reported CPU speed: 2194 MHz
Highest measured interrupt to process latency (µs): 21511.853613
Average measured interrupt to process latency (µs): 12.350102
Highest measured interrupt to DPC latency (µs): 442.340785
Average measured interrupt to DPC latency (µs): 2.805915
REPORTED ISRs
Highest ISR routine execution time (µs): 200.005469
Driver with highest ISR routine execution time: USBPORT.SYS - USB 1.1 & 2.0 Port Driver, Microsoft Corporation
Highest reported total ISR routine time (%): 0.201432
Driver with highest ISR total time: USBPORT.SYS - USB 1.1 & 2.0 Port Driver, Microsoft Corporation
Total time spent in ISRs (%) 0.326558
ISR count (execution time <250 µs): 320036
REPORTED DPCs
Highest DPC routine execution time (µs): 3494.931632
Driver with highest DPC routine execution time: USBPORT.SYS - USB 1.1 & 2.0 Port Driver, Microsoft Corporation
Highest reported total DPC routine time (%): 6.101485
Driver with highest DPC total execution time: USBPORT.SYS - USB 1.1 & 2.0 Port Driver, Microsoft Corporation
Total time spent in DPCs (%) 6.903414
DPC count (execution time <250 µs): 941194
DPC count (execution time 500-999 µs): 20005
DPC count (execution time 1000-1999 µs): 4
DPC count (execution time 2000-3999 µs): 9
REPORTED HARD PAGEFAULTS
Total number of hard pagefaults 848
Hard pagefault count of hardest hit process: 624
Highest hard pagefault resolution time (µs): 354295.759799
Total time spent in hard pagefaults (%): 5.997567
Number of processes hit: 8
PER CPU DATA
CPU 0 Interrupt cycle time (s): 13.915864
CPU 0 ISR highest execution time (µs): 39.397448
CPU 0 ISR total execution time (s): 0.635322
CPU 0 ISR count: 237664
CPU 0 DPC highest execution time (µs): 2439.643573
CPU 0 DPC total execution time (s): 11.725608
CPU 0 DPC count: 818199
CPU 1 Interrupt cycle time (s): 11.604927
CPU 1 ISR highest execution time (µs): 200.005469
CPU 1 ISR total execution time (s): 0.385382
CPU 1 ISR count: 82372
CPU 1 DPC highest execution time (µs): 3494.931632
CPU 1 DPC total execution time (s): 9.851978
CPU 1 DPC count: 143013
