[SOLVED] KB4483187 caused problems, then wouldn't uninstall
annah
Shoshoni, WY, USA
Hi, I'm running Windows Embedded Standard 7 x64. When I ran the update KB4483187, the next time I booted my computer, the keyboard and mouse no longer worked. I had to boot with driver signature enforcement disabled in order to use my computer. Many hours of troubleshooting and browsing forums and running scans and fixes, and the driver signature issue seems to be repaired. At least, my keyboard and mouse work again after booting normally.
However, the update, which must not have installed correctly, also would not uninstall correctly. I had tried to uninstall the update from cmd using wusa /uninstall / kb:4483187...this now yields error code 0x80070490 "element not found." However, then I try to install the update again and it says the update is already installed. It does not show up in the installed updates list. The .dll file the update addressed is now the most recent version, indicating that the update at least did that much right...but I would still like to fix this, in case it causes more problems down the road.
Here is a link to my CBS file on Google Drive:
CBS.zip - Google Drive
Let me know what you think...Thanks!
Hello and welcome!
Please run System Update Readiness Tool and attach CheckSUR.log once it completes. Please refer to Step #3 of the Windows Update Posting Instructions if you are in need of additional guidance.
Let me know if you encounter any issues.
Hi!
  8. Copy (Ctrl+C) and Paste (Ctrl+V) the contents of this file into your next post for me to analyse please - put
Afterwards, please run SURT again and attach CheckSUR.log.
Hi, here is the txt file. I will put the new scan results in a separate post after it runs.
SFCFix version 3.0.1.0 by niemiro.Start time: 2019-01-07 10:11:38.572
Using .zip script file at C:\Users\Teledyne\Desktop\SFCFix.zip [0]
Successfully took permissions for file or folder C:\Windows\Temp\CheckSur\Servicing\Packages
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1026_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1026_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1026_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1026_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1082_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1082_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1082_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1082_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1083_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1083_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1083_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1083_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1084_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1084_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1084_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1084_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1085_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1085_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1085_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1085_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1086_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1086_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1086_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1086_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1087_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1087_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1087_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1087_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1088_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1088_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1088_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1088_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1089_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1089_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1089_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1089_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1090_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1090_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1090_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1090_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1092_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1092_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1092_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1092_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1093_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1093_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1093_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1093_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1097_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1097_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1097_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1097_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1099_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1099_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1099_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1099_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_10_for_KB4470641~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_10_for_KB4470641~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_10_for_KB4470641~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_10_for_KB4470641~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1102_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1102_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1102_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1102_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1106_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1106_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1106_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1106_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1108_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1108_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1108_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1108_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1125_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1125_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1125_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1125_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1127_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1127_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1127_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1127_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1128_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1128_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1128_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1128_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1144_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1144_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1144_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1144_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1145_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1145_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1145_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1145_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1146_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1146_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1146_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1146_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1147_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1147_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1147_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1147_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1148_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1148_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1148_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1148_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1149_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1149_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1149_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1149_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1150_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1150_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1150_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1150_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1151_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1151_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1151_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1151_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1152_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1152_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1152_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1152_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1155_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1155_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1155_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1155_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1157_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1157_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1157_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1157_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1160_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1160_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1160_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1160_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1162_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1162_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1162_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1162_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1171_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1171_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1171_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1171_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1173_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1173_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1173_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1173_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1174_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1174_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1174_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1174_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1175_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1175_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1175_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1175_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1176_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1176_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1176_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1176_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1177_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1177_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1177_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1177_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1178_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1178_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1178_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1178_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1179_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1179_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1179_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1179_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1181_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1181_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1181_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1181_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1184_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1184_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1184_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1184_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1186_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1186_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1186_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1186_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1189_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1189_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1189_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1189_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1191_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1191_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1191_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1191_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_11_for_KB4470641~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_11_for_KB4470641~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_11_for_KB4470641~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_11_for_KB4470641~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_11_for_KB4483187~31bf3856ad364e35~amd64~~11.2.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_11_for_KB4483187~31bf3856ad364e35~amd64~~11.2.1.0.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_11_for_KB4483187~31bf3856ad364e35~amd64~~11.2.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_11_for_KB4483187~31bf3856ad364e35~amd64~~11.2.1.0.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1200_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1200_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1200_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1200_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1202_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1202_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1202_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1202_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1203_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1203_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1203_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1203_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1204_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1204_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1204_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1204_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1205_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1205_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1205_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1205_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1206_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1206_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1206_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1206_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1207_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1207_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1207_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1207_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1208_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1208_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1208_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1208_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1209_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1209_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1209_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1209_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1210_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1210_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1210_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1210_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1211_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1211_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1211_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1211_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1212_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1212_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1212_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1212_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1213_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1213_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1213_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1213_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1215_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1215_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1215_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1215_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1216_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1216_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1216_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1216_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1217_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1217_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1217_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1217_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1219_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1219_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1219_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1219_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1221_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1221_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1221_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1221_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1222_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1222_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1222_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1222_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1223_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1223_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1223_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1223_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1224_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1224_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1224_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1224_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1225_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1225_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1225_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1225_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1227_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1227_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1227_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1227_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1228_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1228_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1228_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1228_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1233_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1233_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1233_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1233_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1235_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1235_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1235_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1235_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1238_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1238_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1238_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1238_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1242_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1242_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1242_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1242_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1244_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1244_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1244_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1244_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1261_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1261_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1261_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1261_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1262_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1262_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1262_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1262_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1263_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1263_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1263_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1263_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1265_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1265_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1265_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1265_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1266_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1266_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1266_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1266_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1269_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1269_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1269_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1269_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1270_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1270_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1270_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1270_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1271_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1271_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1271_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1271_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1277_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1277_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1277_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1277_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1279_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1279_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1279_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1279_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1282_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1282_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1282_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1282_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1286_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1286_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1286_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1286_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1288_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1288_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1288_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1288_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_12_for_KB4470641~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_12_for_KB4470641~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_12_for_KB4470641~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_12_for_KB4470641~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1305_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1305_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1305_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1305_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1306_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1306_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1306_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1306_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1307_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1307_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1307_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1307_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1308_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1308_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1308_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1308_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1309_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1309_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1309_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1309_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1310_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1310_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1310_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1310_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1314_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1314_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1314_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1314_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1316_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1316_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1316_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1316_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1318_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1318_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1318_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1318_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1321_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1321_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1321_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1321_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1323_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1323_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1323_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1323_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1332_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1332_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1332_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1332_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1333_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1333_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1333_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1333_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1334_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1334_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1334_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1334_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1335_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1335_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1335_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1335_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1336_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1336_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1336_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1336_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1337_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1337_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1337_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1337_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1338_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1338_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1338_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1338_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1343_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1343_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1343_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1343_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1345_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1345_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1345_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1345_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1348_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1348_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1348_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1348_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1352_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1352_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1352_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1352_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1354_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1354_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1354_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1354_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1371_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1371_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1371_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1371_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1372_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1372_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1372_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1372_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1373_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1373_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1373_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1373_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1374_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1374_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1374_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1374_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1375_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1375_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1375_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1375_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1376_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1376_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1376_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1376_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1377_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1377_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1377_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1377_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1378_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1378_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1378_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1378_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1379_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1379_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1379_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1379_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1380_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1380_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1380_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1380_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1382_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1382_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1382_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1382_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1383_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1383_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1383_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1383_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1387_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1387_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1387_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1387_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1389_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1389_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1389_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1389_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1391_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1391_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1391_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1391_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1394_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1394_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1394_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1394_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1396_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1396_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1396_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1396_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_13_for_KB4470641~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_13_for_KB4470641~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_13_for_KB4470641~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_13_for_KB4470641~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1405_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1405_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1405_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1405_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1406_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1406_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1406_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1406_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1407_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1407_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1407_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1407_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1409_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1409_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1409_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1409_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1410_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1410_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1410_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1410_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1411_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1411_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1411_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1411_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1412_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1412_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1412_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1412_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1415_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1415_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1415_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1415_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1416_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1416_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1416_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1416_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1417_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1417_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1417_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1417_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1418_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1418_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1418_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1418_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1419_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1419_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1419_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1419_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1420_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1420_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1420_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1420_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1421_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1421_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1421_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1421_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1422_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1422_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1422_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1422_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1423_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1423_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1423_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1423_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1424_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1424_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1424_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1424_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1425_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1425_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1425_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1425_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1426_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1426_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1426_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1426_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1427_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1427_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1427_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1427_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1428_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1428_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1428_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1428_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1429_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1429_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1429_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1429_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1430_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1430_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1430_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1430_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1431_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1431_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1431_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1431_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1433_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1433_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1433_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1433_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1434_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1434_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1434_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1434_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1435_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1435_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1435_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1435_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1436_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1436_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1436_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1436_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1437_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1437_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1437_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1437_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1438_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1438_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1438_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1438_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1439_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1439_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1439_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1439_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1440_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1440_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1440_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1440_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1441_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1441_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1441_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1441_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1442_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1442_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1442_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1442_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1443_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1443_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1443_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1443_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1444_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1444_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1444_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1444_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1445_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1445_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1445_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1445_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1446_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1446_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1446_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1446_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1447_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1447_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1447_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1447_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1448_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1448_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1448_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1448_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1449_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1449_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1449_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1449_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1450_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1450_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1450_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1450_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1451_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1451_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1451_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1451_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1452_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1452_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1452_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1452_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1453_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1453_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1453_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1453_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1454_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1454_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1454_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1454_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1455_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1455_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1455_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1455_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1495_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1495_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1495_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1495_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_14_for_KB4470641~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_14_for_KB4470641~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_14_for_KB4470641~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_14_for_KB4470641~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1501_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1501_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1501_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1501_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1577_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1577_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1577_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1577_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1582_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1582_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1582_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1582_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1584_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1584_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1584_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1584_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1585_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1585_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1585_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1585_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1588_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1588_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1588_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1588_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1592_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1592_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1592_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1592_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1594_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1594_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1594_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1594_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_15_for_KB4470641~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_15_for_KB4470641~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_15_for_KB4470641~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_15_for_KB4470641~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_15_for_KB4483187~31bf3856ad364e35~amd64~~11.2.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_15_for_KB4483187~31bf3856ad364e35~amd64~~11.2.1.0.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_15_for_KB4483187~31bf3856ad364e35~amd64~~11.2.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_15_for_KB4483187~31bf3856ad364e35~amd64~~11.2.1.0.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1611_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1611_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1611_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1611_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1613_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1613_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1613_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1613_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1622_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1622_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1622_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1622_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_16_for_KB4470641~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_16_for_KB4470641~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_16_for_KB4470641~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_16_for_KB4470641~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_17_for_KB4470641~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_17_for_KB4470641~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_17_for_KB4470641~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_17_for_KB4470641~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_17_for_KB4483187~31bf3856ad364e35~amd64~~11.2.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_17_for_KB4483187~31bf3856ad364e35~amd64~~11.2.1.0.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_17_for_KB4483187~31bf3856ad364e35~amd64~~11.2.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_17_for_KB4483187~31bf3856ad364e35~amd64~~11.2.1.0.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_18_for_KB4470641~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_18_for_KB4470641~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_18_for_KB4470641~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_18_for_KB4470641~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_196_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_196_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_196_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_196_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1_for_KB4483187~31bf3856ad364e35~amd64~~11.2.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1_for_KB4483187~31bf3856ad364e35~amd64~~11.2.1.0.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_1_for_KB4483187~31bf3856ad364e35~amd64~~11.2.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1_for_KB4483187~31bf3856ad364e35~amd64~~11.2.1.0.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_202_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_202_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_202_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_202_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_204_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_204_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_204_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_204_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_207_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_207_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_207_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_207_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_211_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_211_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_211_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_211_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_213_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_213_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_213_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_213_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_230_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_230_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_230_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_230_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_232_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_232_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_232_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_232_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_233_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_233_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_233_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_233_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_234_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_234_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_234_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_234_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_236_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_236_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_236_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_236_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_34_for_KB4483187~31bf3856ad364e35~amd64~~11.2.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_34_for_KB4483187~31bf3856ad364e35~amd64~~11.2.1.0.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_34_for_KB4483187~31bf3856ad364e35~amd64~~11.2.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_34_for_KB4483187~31bf3856ad364e35~amd64~~11.2.1.0.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_36_for_KB4483187~31bf3856ad364e35~amd64~~11.2.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_36_for_KB4483187~31bf3856ad364e35~amd64~~11.2.1.0.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_36_for_KB4483187~31bf3856ad364e35~amd64~~11.2.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_36_for_KB4483187~31bf3856ad364e35~amd64~~11.2.1.0.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_378_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_378_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_378_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_378_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_37_for_KB4483187~31bf3856ad364e35~amd64~~11.2.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_37_for_KB4483187~31bf3856ad364e35~amd64~~11.2.1.0.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_37_for_KB4483187~31bf3856ad364e35~amd64~~11.2.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_37_for_KB4483187~31bf3856ad364e35~amd64~~11.2.1.0.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_38_for_KB4483187~31bf3856ad364e35~amd64~~11.2.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_38_for_KB4483187~31bf3856ad364e35~amd64~~11.2.1.0.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_38_for_KB4483187~31bf3856ad364e35~amd64~~11.2.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_38_for_KB4483187~31bf3856ad364e35~amd64~~11.2.1.0.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_39_for_KB4483187~31bf3856ad364e35~amd64~~11.2.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_39_for_KB4483187~31bf3856ad364e35~amd64~~11.2.1.0.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_39_for_KB4483187~31bf3856ad364e35~amd64~~11.2.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_39_for_KB4483187~31bf3856ad364e35~amd64~~11.2.1.0.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_40_for_KB4483187~31bf3856ad364e35~amd64~~11.2.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_40_for_KB4483187~31bf3856ad364e35~amd64~~11.2.1.0.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_40_for_KB4483187~31bf3856ad364e35~amd64~~11.2.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_40_for_KB4483187~31bf3856ad364e35~amd64~~11.2.1.0.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_423_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_423_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_423_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_423_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_656_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_656_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_656_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_656_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_662_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_662_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_662_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_662_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_664_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_664_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_664_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_664_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_667_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_667_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_667_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_667_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_671_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_671_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_671_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_671_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_673_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_673_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_673_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_673_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_690_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_690_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_690_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_690_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_692_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_692_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_692_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_692_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_693_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_693_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_693_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_693_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_694_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_694_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_694_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_694_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_696_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_696_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_696_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_696_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_6_for_KB4483187~31bf3856ad364e35~amd64~~11.2.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_6_for_KB4483187~31bf3856ad364e35~amd64~~11.2.1.0.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_6_for_KB4483187~31bf3856ad364e35~amd64~~11.2.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_6_for_KB4483187~31bf3856ad364e35~amd64~~11.2.1.0.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_8_for_KB4483187~31bf3856ad364e35~amd64~~11.2.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_8_for_KB4483187~31bf3856ad364e35~amd64~~11.2.1.0.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_8_for_KB4483187~31bf3856ad364e35~amd64~~11.2.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_8_for_KB4483187~31bf3856ad364e35~amd64~~11.2.1.0.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_983_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_983_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_983_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_983_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_for_KB4470641_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_for_KB4470641_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_for_KB4470641_SP1~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_for_KB4470641_SP1~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_for_KB4470641~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_for_KB4470641~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_for_KB4470641~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_for_KB4470641~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_for_KB4471318_SP1~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_for_KB4471318_SP1~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_for_KB4471318_SP1~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_for_KB4471318_SP1~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_for_KB4483187_RTM~31bf3856ad364e35~amd64~~11.2.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_for_KB4483187_RTM~31bf3856ad364e35~amd64~~11.2.1.0.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_for_KB4483187_RTM~31bf3856ad364e35~amd64~~11.2.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_for_KB4483187_RTM~31bf3856ad364e35~amd64~~11.2.1.0.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_for_KB4483187~31bf3856ad364e35~amd64~~11.2.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_for_KB4483187~31bf3856ad364e35~amd64~~11.2.1.0.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_for_KB4483187~31bf3856ad364e35~amd64~~11.2.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_for_KB4483187~31bf3856ad364e35~amd64~~11.2.1.0.mum.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_for_RollupFix~31bf3856ad364e35~amd64~~7601.24312.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_for_RollupFix~31bf3856ad364e35~amd64~~7601.24312.1.5.cat.
Successfully copied file C:\Users\Teledyne\AppData\Local\niemiro\Archive\Packages\Package_for_RollupFix~31bf3856ad364e35~amd64~~7601.24312.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_for_RollupFix~31bf3856ad364e35~amd64~~7601.24312.1.5.mum.
Successfully restored ownership for C:\Windows\Temp\CheckSur\Servicing\Packages
Successfully restored permissions on C:\Windows\Temp\CheckSur\Servicing\Packages
SFCFix version 3.0.1.0 by niemiro has completed.
Finish time: 2019-01-07 10:11:43.954
Script hash: EDOMEmYED8yRgrPOIpeSuoZrkRen+pecaU42mNSLIBQ=
CheckSUR says it fixed all the errors
Binary Version 6.1.7601.22471
Package Version 26.0
2019-01-07 10:17
Checking Package Watchlist
Checking Component Watchlist
Checking Packages
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1026_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1026_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1026_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1082_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1082_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1082_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1083_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1083_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1083_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1084_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1084_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1084_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1085_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1085_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1085_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1086_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1086_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1086_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1087_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1087_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1087_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1088_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1088_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1088_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1089_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1089_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1089_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1090_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1090_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1090_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1092_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1092_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1092_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1093_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1093_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1093_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1097_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1097_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1097_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1099_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1099_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1099_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_10_for_KB4470641~31bf3856ad364e35~amd64~~6.1.1.0.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_10_for_KB4470641~31bf3856ad364e35~amd64~~6.1.1.0.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_10_for_KB4470641~31bf3856ad364e35~amd64~~6.1.1.0.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1102_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1102_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1102_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1106_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1106_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1106_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1108_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1108_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1108_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1125_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1125_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1125_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1127_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1127_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1127_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1128_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1128_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1128_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1144_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1144_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1144_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1145_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1145_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1145_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1146_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1146_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1146_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1147_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1147_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1147_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1148_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1148_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1148_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1149_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1149_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1149_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1150_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1150_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1150_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1151_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1151_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1151_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1152_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1152_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1152_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1155_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1155_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1155_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1157_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1157_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1157_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1160_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1160_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1160_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1162_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1162_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1162_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1171_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1171_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1171_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1173_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1173_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1173_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1174_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1174_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1174_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1175_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1175_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1175_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1176_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1176_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1176_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1177_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1177_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1177_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1178_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1178_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1178_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1179_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1179_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1179_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1181_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1181_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1181_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1184_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1184_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1184_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1186_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1186_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1186_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1189_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1189_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1189_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1191_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1191_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1191_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_11_for_KB4470641~31bf3856ad364e35~amd64~~6.1.1.0.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_11_for_KB4470641~31bf3856ad364e35~amd64~~6.1.1.0.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_11_for_KB4470641~31bf3856ad364e35~amd64~~6.1.1.0.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_11_for_KB4483187~31bf3856ad364e35~amd64~~11.2.1.0.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_11_for_KB4483187~31bf3856ad364e35~amd64~~11.2.1.0.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_11_for_KB4483187~31bf3856ad364e35~amd64~~11.2.1.0.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1200_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1200_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1200_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1202_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1202_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1202_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1203_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1203_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1203_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1204_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1204_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1204_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1205_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1205_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1205_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1206_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1206_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1206_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1207_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1207_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1207_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1208_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1208_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1208_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1209_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1209_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1209_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1210_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1210_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1210_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1211_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1211_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1211_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1212_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1212_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1212_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1213_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1213_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1213_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1215_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1215_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1215_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1216_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1216_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1216_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1217_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1217_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1217_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1219_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1219_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1219_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1221_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1221_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1221_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1222_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1222_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1222_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1223_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1223_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1223_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1224_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1224_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1224_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1225_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1225_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1225_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1227_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1227_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1227_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1228_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1228_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1228_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1233_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1233_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1233_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1235_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1235_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1235_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1238_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1238_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1238_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1242_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1242_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1242_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1244_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1244_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1244_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1261_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1261_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1261_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1262_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1262_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1262_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1263_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1263_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1263_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1265_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1265_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1265_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1266_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1266_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1266_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1269_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1269_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1269_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1270_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1270_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1270_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1271_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1271_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1271_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1277_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1277_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1277_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1279_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1279_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1279_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1282_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1282_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1282_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1286_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1286_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1286_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1288_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1288_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1288_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_12_for_KB4470641~31bf3856ad364e35~amd64~~6.1.1.0.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_12_for_KB4470641~31bf3856ad364e35~amd64~~6.1.1.0.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_12_for_KB4470641~31bf3856ad364e35~amd64~~6.1.1.0.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1305_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1305_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1305_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1306_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1306_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1306_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1307_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1307_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1307_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1308_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1308_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1308_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1309_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1309_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1309_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1310_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1310_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1310_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1314_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1314_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1314_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1316_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1316_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1316_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1318_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1318_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1318_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1321_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1321_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1321_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1323_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1323_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1323_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1332_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1332_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1332_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1333_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1333_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1333_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1334_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1334_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1334_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1335_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1335_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1335_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1336_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1336_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1336_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1337_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1337_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1337_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1338_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1338_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1338_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1343_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1343_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1343_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1345_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1345_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1345_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1348_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1348_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1348_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1352_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1352_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1352_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1354_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1354_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1354_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1371_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1371_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1371_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1372_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1372_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1372_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1373_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1373_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1373_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1374_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1374_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1374_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1375_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1375_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1375_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1376_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1376_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1376_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1377_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1377_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1377_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1378_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1378_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1378_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1379_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1379_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1379_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1380_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1380_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1380_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1382_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1382_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1382_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1383_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1383_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1383_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1387_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1387_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1387_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1389_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1389_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1389_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1391_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1391_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1391_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1394_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1394_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1394_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1396_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1396_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1396_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_13_for_KB4470641~31bf3856ad364e35~amd64~~6.1.1.0.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_13_for_KB4470641~31bf3856ad364e35~amd64~~6.1.1.0.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_13_for_KB4470641~31bf3856ad364e35~amd64~~6.1.1.0.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1405_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1405_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1405_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1406_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1406_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1406_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1407_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1407_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1407_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1409_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1409_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1409_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1410_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1410_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1410_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1411_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1411_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1411_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1412_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1412_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1412_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1415_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1415_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1415_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1416_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1416_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1416_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1417_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1417_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1417_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1418_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1418_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1418_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1419_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1419_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1419_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1420_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1420_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1420_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1421_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1421_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1421_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1422_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1422_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1422_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1423_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1423_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1423_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1424_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1424_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1424_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1425_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1425_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1425_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1426_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1426_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1426_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1427_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1427_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1427_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1428_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1428_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1428_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1429_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1429_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1429_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1430_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1430_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1430_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1431_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1431_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1431_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1433_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1433_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1433_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1434_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1434_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1434_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1435_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1435_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1435_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1436_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1436_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1436_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1437_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1437_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1437_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1438_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1438_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1438_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1439_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1439_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1439_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1440_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1440_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1440_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1441_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1441_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1441_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1442_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1442_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1442_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1443_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1443_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1443_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1444_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1444_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1444_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1445_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1445_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1445_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1446_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1446_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1446_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1447_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1447_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1447_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1448_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1448_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1448_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1449_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1449_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1449_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1450_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1450_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1450_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1451_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1451_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1451_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1452_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1452_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1452_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1453_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1453_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1453_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1454_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1454_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1454_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1455_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1455_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1455_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1495_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1495_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1495_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_14_for_KB4470641~31bf3856ad364e35~amd64~~6.1.1.0.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_14_for_KB4470641~31bf3856ad364e35~amd64~~6.1.1.0.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_14_for_KB4470641~31bf3856ad364e35~amd64~~6.1.1.0.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1501_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1501_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1501_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1577_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1577_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1577_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1582_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1582_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1582_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1584_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1584_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1584_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1585_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1585_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1585_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1588_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1588_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1588_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1592_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1592_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1592_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1594_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1594_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1594_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_15_for_KB4470641~31bf3856ad364e35~amd64~~6.1.1.0.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_15_for_KB4470641~31bf3856ad364e35~amd64~~6.1.1.0.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_15_for_KB4470641~31bf3856ad364e35~amd64~~6.1.1.0.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_15_for_KB4483187~31bf3856ad364e35~amd64~~11.2.1.0.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_15_for_KB4483187~31bf3856ad364e35~amd64~~11.2.1.0.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_15_for_KB4483187~31bf3856ad364e35~amd64~~11.2.1.0.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1611_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1611_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1611_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1613_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1613_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1613_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1622_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1622_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1622_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_16_for_KB4470641~31bf3856ad364e35~amd64~~6.1.1.0.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_16_for_KB4470641~31bf3856ad364e35~amd64~~6.1.1.0.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_16_for_KB4470641~31bf3856ad364e35~amd64~~6.1.1.0.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_17_for_KB4470641~31bf3856ad364e35~amd64~~6.1.1.0.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_17_for_KB4470641~31bf3856ad364e35~amd64~~6.1.1.0.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_17_for_KB4470641~31bf3856ad364e35~amd64~~6.1.1.0.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_17_for_KB4483187~31bf3856ad364e35~amd64~~11.2.1.0.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_17_for_KB4483187~31bf3856ad364e35~amd64~~11.2.1.0.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_17_for_KB4483187~31bf3856ad364e35~amd64~~11.2.1.0.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_18_for_KB4470641~31bf3856ad364e35~amd64~~6.1.1.0.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_18_for_KB4470641~31bf3856ad364e35~amd64~~6.1.1.0.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_18_for_KB4470641~31bf3856ad364e35~amd64~~6.1.1.0.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_196_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_196_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_196_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_1_for_KB4483187~31bf3856ad364e35~amd64~~11.2.1.0.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_1_for_KB4483187~31bf3856ad364e35~amd64~~11.2.1.0.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_1_for_KB4483187~31bf3856ad364e35~amd64~~11.2.1.0.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_202_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_202_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_202_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_204_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_204_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_204_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_207_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_207_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_207_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_211_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_211_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_211_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_213_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_213_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_213_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_230_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_230_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_230_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_232_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_232_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_232_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_233_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_233_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_233_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_234_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_234_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_234_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_236_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_236_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_236_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_34_for_KB4483187~31bf3856ad364e35~amd64~~11.2.1.0.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_34_for_KB4483187~31bf3856ad364e35~amd64~~11.2.1.0.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_34_for_KB4483187~31bf3856ad364e35~amd64~~11.2.1.0.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_36_for_KB4483187~31bf3856ad364e35~amd64~~11.2.1.0.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_36_for_KB4483187~31bf3856ad364e35~amd64~~11.2.1.0.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_36_for_KB4483187~31bf3856ad364e35~amd64~~11.2.1.0.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_378_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_378_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_378_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_37_for_KB4483187~31bf3856ad364e35~amd64~~11.2.1.0.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_37_for_KB4483187~31bf3856ad364e35~amd64~~11.2.1.0.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_37_for_KB4483187~31bf3856ad364e35~amd64~~11.2.1.0.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_38_for_KB4483187~31bf3856ad364e35~amd64~~11.2.1.0.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_38_for_KB4483187~31bf3856ad364e35~amd64~~11.2.1.0.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_38_for_KB4483187~31bf3856ad364e35~amd64~~11.2.1.0.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_39_for_KB4483187~31bf3856ad364e35~amd64~~11.2.1.0.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_39_for_KB4483187~31bf3856ad364e35~amd64~~11.2.1.0.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_39_for_KB4483187~31bf3856ad364e35~amd64~~11.2.1.0.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_40_for_KB4483187~31bf3856ad364e35~amd64~~11.2.1.0.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_40_for_KB4483187~31bf3856ad364e35~amd64~~11.2.1.0.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_40_for_KB4483187~31bf3856ad364e35~amd64~~11.2.1.0.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_423_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_423_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_423_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_656_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_656_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_656_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_662_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_662_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_662_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_664_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_664_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_664_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_667_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_667_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_667_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_671_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_671_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_671_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_673_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_673_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_673_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_690_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_690_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_690_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_692_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_692_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_692_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_693_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_693_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_693_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_694_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_694_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_694_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_696_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_696_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_696_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_6_for_KB4483187~31bf3856ad364e35~amd64~~11.2.1.0.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_6_for_KB4483187~31bf3856ad364e35~amd64~~11.2.1.0.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_6_for_KB4483187~31bf3856ad364e35~amd64~~11.2.1.0.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_8_for_KB4483187~31bf3856ad364e35~amd64~~11.2.1.0.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_8_for_KB4483187~31bf3856ad364e35~amd64~~11.2.1.0.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_8_for_KB4483187~31bf3856ad364e35~amd64~~11.2.1.0.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_983_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_983_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_983_for_KB4471318~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_for_KB4470641_SP1~31bf3856ad364e35~amd64~~6.1.1.0.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_for_KB4470641_SP1~31bf3856ad364e35~amd64~~6.1.1.0.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_for_KB4470641_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_for_KB4470641~31bf3856ad364e35~amd64~~6.1.1.0.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_for_KB4470641~31bf3856ad364e35~amd64~~6.1.1.0.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_for_KB4470641~31bf3856ad364e35~amd64~~6.1.1.0.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_for_KB4471318_SP1~31bf3856ad364e35~amd64~~6.1.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_for_KB4471318_SP1~31bf3856ad364e35~amd64~~6.1.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_for_KB4471318_SP1~31bf3856ad364e35~amd64~~6.1.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_for_KB4483187_RTM~31bf3856ad364e35~amd64~~11.2.1.0.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_for_KB4483187_RTM~31bf3856ad364e35~amd64~~11.2.1.0.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_for_KB4483187_RTM~31bf3856ad364e35~amd64~~11.2.1.0.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_for_KB4483187~31bf3856ad364e35~amd64~~11.2.1.0.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_for_KB4483187~31bf3856ad364e35~amd64~~11.2.1.0.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_for_KB4483187~31bf3856ad364e35~amd64~~11.2.1.0.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_for_RollupFix~31bf3856ad364e35~amd64~~7601.24312.1.5.mum
(fix)    CBS MUM Missing    CBS File Replaced    Package_for_RollupFix~31bf3856ad364e35~amd64~~7601.24312.1.5.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
(fix)    CBS Paired File    CBS File also Replaced    Package_for_RollupFix~31bf3856ad364e35~amd64~~7601.24312.1.5.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab1.cab.
Checking Component Store
Summary:
Seconds executed: 959
 Found 239 errors
 Fixed 239 errors
  CBS MUM Missing Total count: 239
  Fixed: CBS MUM Missing.  Total count: 239
  Fixed: CBS Paired File.  Total count: 239
As of now, my machine says it is up to date, and the problem update from the beginning of the thread shows it is installed. Next time it updates, I will let you know how it goes. Thanks a lot for your help, this really saved me a lot of trouble!
