[SOLVED] KB3191566 problem installation
moustik90
Hello,
I have a problem installing the KB3191566.
I tried a SFCFIX, here is attached the report.
On the other hand, when I run the command "dism / online / cleanup-image / scanhealth", I get the error "0x80004005, DISM failed, no operation was performed"
I am also attaching the latest CBS.log and DISM.log
Thank you in advance for your help.
Hello and welcome!
Retrieve Components Hive
Hello,
Thank you for your quick reply.
The problem is not on my computer but that of a friend, so I do not have access now.
But as soon as I have access I will post the file requested.
Sorry for the delay
Hello and welcome!
Hello,
Sorry again for the response time.
Here is the file requested : COMPONENTS.zip
Thank you.
I believe I haven't.
Is regedit backup on C:\Windows\System32\config\RegBack ? If it is, there isn't file named "COMPONENTS"
Yes. The one you provided is bad and has likely been replaced at an earlier time.
You can try to do a repair install.
If that fails, do a clean install, I'd recommend going straight for Windows 10 1909.
OK, but is it not possible to recover a COMPONENTS "virgin" and healthy file and replace it on the PC in error?
The repair install, is it like I'm doing a new installation?
Thank you
Hi
So I finally reinstalled the system, I have no restore point sufficiently old, dating from before the appearance of the problem.
Thanks for your help.
