[SOLVED] KB2984972 fails upon install and reboot (will edit after running SFCFix))
Hello and welcome to the forum.
After running SFCFix, please also do the following.
Export CBS folder
  1. Click the Start button
    then click Computer.
  2. Double-click on the C: drive, under the Hard Disk Drives category, and then scroll down to, and double click on the Windows folder.
  3. Find and double click on the Logs folder.
  4. Right-click on the CBS folder, and select Copy.
  5. Go back to your Desktop, right-click on it, and select Paste. You should now see a copy of the CBS folder appear on your Desktop called CBS.
  6. Right-click on this new folder, and navigate through Send to, and select Compressed (zipped) folder.
  7. A new file, also called CBS (CBS.zip), but this time with a different icon, will be created.
  8. Attach this to your next post please.
Please Note:: if the file is too big to upload to you next post please upload via Dropbox or One Drive
Start time: 2014-10-29 14:40:38.163
CORRUPT: C:\Windows\winsxs\amd64_microsoft-windows-t..instationextensions_31bf3856ad364e35_6.1.7601.17828_none_f83075d781b149cb\rdpcorekmts.dll
CORRUPT: C:\Windows\winsxs\amd64_microsoft-windows-t..instationextensions_31bf3856ad364e35_6.1.7601.17828_none_f83075d781b149cb\rdpwsx.dll
CORRUPT: C:\Windows\winsxs\amd64_microsoft-windows-t..instationextensions_31bf3856ad364e35_6.1.7601.17828_none_f83075d781b149cb\rdrmemptylst.exe
CBS & SFC total detected corruption count: 3
SURT total detected corruption count: 3
Finish time: 2014-10-29 14:43:25.850
CBS.log file:
https://www.dropbox.com/s/dwzjwuujgnvytqx/CBS.zip?dl=0
SFC /SCANNOW
  1. Click on the
  4. Please wait for this to Finish before continuing with the rest of the steps.
Convert CBS.log to CBS.txt
  1. Click on the
    button => Inside the search box copy and paste the following command:
  2. Press Enter
  3. Once this has completed please go to your Desktop and you will find CBS.txt => Please upload CBS.txt to this thread
